06 rubicon tire clearance ? - JeepForum.com
Go Back JeepForum.com > General Technical Discussions > Tires & Wheels > 06 rubicon tire clearance ?
Memorial Day Sale at Under Cover Fabworks! 15% Discount oNOTCH CUSTOMS - Max Clearance Fender FlaresIntroducing MONSTALINER™ UV Permanent DIY Roll On Bed Line
Unread 06-15-2012, 03:44 PM   #1
jrauch357
hey guys i just bought a 2 inch skyjacker budget boost with hydro shocks for my 2006 jeep rubicon, i want to put 295-75-16 (33s) on my stock rims. Am I going rub? Do I need a one inch body lift for extra clearance, do i need wheel spacers? or am I all set with just the budget boost? Can anyone help? Please!
Thanks
jrauch357 is offline   Reply With Quote
Unread 06-15-2012, 03:47 PM   #2
Gary2
I would say no less than 3" total lift . I would do the 1-1.25" BL and also a JKS 1" budget MML . If you have tire rub it will be when you turn the front wheels to far . a couple washers added to your steering stops fixes that
O5 Rubi TJ, 3"BDS, Currie Currectlync, Rokmen BL , Savvy arms with Metalcloak Duroflex joints , Bilstein 5100, 33" Cooper STTs
Gary2 is offline   Reply With Quote
Unread 06-16-2012, 11:18 AM   #3
jrauch357
Thanks for the advise on the body lift but the washers doesent sound like the best idea I don't want to mess with that if rather just lift it higher
Unread 06-16-2012, 01:09 PM   #4
Gary2
go as high as you want the control arms will still be the rubbing issue not the height , Its the Back spacing of the wheels in most cases. The washers are how we all adjust our steering stops which will stop your trad from encountering the control arms . Its not some kind of half as@ed way of fixing things . Maybe also try using the search and see what others have done .
33s , clearance , rubicon , suspension , tires
