05 TJ SE wheel question - JeepForum.com
post #1 of 2 Old 06-22-2014, 06:42 PM Thread Starter
Bryce888
Recently bought 32x11.5 bfg km2s and they are sitting in the shop now. I am getting rims and I was looking at pro comp 7031s. They have 3.75 inch of backspacing and -.19mm offset. I don't have a lift but I have seen people run this setup before with a little rub. Would this be a good setup for the least amount of rub and would everything fit right? Jeep is sitting on stock wheels. I just want to make sure before I order them.
Bryce888 is offline
post #2 of 2 Old 06-23-2014, 11:26 AM
Wheelin98TJ
JEEP FREAK
Wheelin98TJ's Avatar
You can run up to a 12.50 or 13.50 wide tire on those wheels, so the 11.50 width will fit no problem.
As for the 32" height, you'll want 1" or 2" of lift in order to have enough room for clearance.
Wheelin98TJ is offline
