02-07 ford explorer rims on zj?? - JeepForum.com
Go Back JeepForum.com > General Technical Discussions > Tires & Wheels > 02-07 ford explorer rims on zj??
Savvy Billet LED Tail LightsRough Country Jeep Suspension Deals at Rockridge 4WD!Alloy usa heavy duty ball joint kits
Unread 11-01-2014, 02:42 PM   #1
severous01
i have a 94 grand cherokee and am planning to run some ford explorer wheels on this with some 255/65/17 tires. this will be a 30.5" tire. the bolt pattern is good, i'm just worried about offset.
factory size jeep wheel is 15x7.5 ET20
explorer wheel size is 17x8.5 ET42
if the explorer hub size is smaller i have a die-grinder i can use to make it bigger, that wont be a problem. but, will the offset be ok?
1994 jeep cherokee, xj, 3" rough country springs / bilstein 5100's, 31" tires with trimmed fenders, aussie locked front diff, herculined ext, hella FF75 driving lights on factory fog location
[COLOR="Lime"]soon to be[/COLOR] 4.11 gear and and a ford 8.8 LSD rear and herc'd interior
severous01 is offline   Reply With Quote Quick reply to this message
