Parts from 01 TJ - Page 2 - JeepForum.com
Go Back   JeepForum.com > Jeep Classifieds > Parts For Sale > Part-Out
Register FAQ Search Today's Posts Mark Forums Read Unanswered Threads Search Members
Unread 05-23-2014, 10:26 AM   #16
theblackbox
View My Classifieds
 theblackbox's Profile
Also have the fuel lines that go from fuel tank to motor (both supply and evap line) as well as the OEM fuel filter. And a np231 factory input shaft.
01 TJ - 5.3 and a built 4L60E, 31x10.5 BFG AT on Dick Cepek wheels, LED headlights, and LED fogs.
theblackbox is offline   Reply With Quote
Unread 06-07-2014, 08:33 PM   #17
CountryTJ01
Tranny sent to 14712? And will it fit in a 01 5sd 6cyl?
CountryTJ01 is offline   Reply With Quote
Unread 06-09-2014, 10:22 PM   #18
joepat19
View My Classifieds
 joepat19's Profile
You still have the exhaust? mainly the pipe/cat converter.
joepat19 is offline   Reply With Quote
Unread 06-10-2014, 05:45 PM   #19
theblackbox
View My Classifieds
Yes sure do. PM me if your still interested in it.
Unread 06-22-2014, 10:50 PM   #20
richclan
1982 CJ8
View My Classifieds
 richclan's Profile
still have the bellhousing?
82 CJ-8 Laredo 258cid Dana 300.T4, blk dia 3" lift w/shocks, YJ brake booster, ARB Air Lockers Front & Rear 456 ratio, Warn Hubs 1" boomerang lift shackles. Superior 1 piece axles. 1" Daystar body lift, contour elect. fans. Ricochet Rockers and Crusher Corners Build= [URL]http://www.jeepforum.com/forum/f22/cj-8-scrambler-1106529/[/URL]
richclan is offline   Reply With Quote
Unread 06-23-2014, 06:26 AM   #21
theblackbox
View My Classifieds
Yes sir. I still have the whole transmission, clutch/master cylinder, and clutch/brake pedal assembly. Also have exhaust.
Unread 06-23-2014, 08:51 AM   #22
richclan
1982 CJ8
View My Classifieds
 richclan's Profile
pm me your location and what you want for the bell
tks
Unread 06-24-2014, 03:19 PM   #23
sdjp
Patriot
sdjp's Avatar
View My Classifieds
 sdjp's Profile
happen to have any male 2 prong electrical connectors (looking for 2)? I need them for some aftermarket fogs but i believe the same ones are used all over the TJ
sdjp is offline   Reply With Quote
Unread 06-26-2014, 07:22 PM   #24
CountryTJ01
How much for transmission?
Unread 07-06-2014, 01:06 PM   #25
dncnbear1
View My Classifieds
 dncnbear1's Profile
Do you have ebrake adjuster assembly? If so how much to 11778?
dncnbear1 is offline   Reply With Quote
The time now is 02:45 PM.
Jeep®, Wrangler, Cherokee, Grand Cherokee, and other models are copyrighted and trademarked to Jeep/Chrysler Corporation.
JeepForum.com is not in any way associated with Jeep or the Chrysler Corp.
