10/24 Q/A Session - Grand Cherokee - Page 4 - JeepForum.com
post #46 of 124 Old 10-24-2007, 04:55 PM Thread Starter
JeepEngineers
JeepEngineers's Avatar
Originally Posted by jeepinjunkie
Thanks for the answer.....I was told that the torque management program limited the throttle in first gear.
6.1L SRT8 only.
JeepEngineers "INTRODUCING THE GREATEST JEEP LINEUP EVER"
JeepEngineers is offline
post #47 of 124 Old 10-24-2007, 04:56 PM Thread Starter
JeepEngineers
Originally Posted by zaq123
Will there be an issue with parts/service support for Diesel WKs since DaimlerChrysler split? As I understand it's Daimler's 3L engine
The 3.0L diesel will continue to be serviced quite well. Daimler still owns a portion of Chrysler. The 3.0L engine is also used in the Sprinter van. I can't address future product plans to help give you more reassurance on this question.
post #48 of 124 Old 10-24-2007, 04:56 PM
diegom6
Hi,
why does the WK 05 questions :
-Sounds like a orquesta (sp) inside with only 10K mile son the clock? Seems Jeep didn't master the quality of parts for the interior makng them more "tight" between each other....they all sound.
Have many customers that complain about this and of corse pisss them off, as well piss me off because I have to add foam here, add some vaseline there at my own cost because this won't pass through warranty.
-Why the fron suspension makes so much noise every bump stop? they seem to colapse for being too soft? Add stiffer shocks!!!
-2008 models will be improoved the A/C slots seal? They don't seal any...either for the rear passengers, need to put a towel there to keep the air blow away from the passengers if they don't want it. Yes, even in Lo position for the blower
-Many customers complain about the a pillar for rest or support the hands there, it makes worse the visibillity (sp?) already than it is with a tight roof.
-Why the 4.7L v8 either, in XK's or WK's shut doewn or die from the nowhere and still, almost 3 years now, Chrysler can't fix this issue? Will the new 4.7L V8 have this problem...?! That's what some customers are asking me that are thingking to buy the 2008 model because they lsot their hopes to fix thsi big issue.
Thanks for your time
Cheers from Lima-PERU
-Diego
XJ: 4.6L High Output Stroker Forged Bottom
- Powerdyne Supercharger
- WJ Twin Caliper/Big Rotor Custom Kit
- ARB Lockers
-Dana30 -Dana44 Rear
- AX15
diegom6 is offline
post #49 of 124 Old 10-24-2007, 04:58 PM Thread Starter
JeepEngineers
Originally Posted by 2007GC Overland
Hi Folks
I know this has been posted before. During Lunch I had to go to another building, started the Jeep and notice the temperature was only 58 degrees (wrong - I know this is an issue with the system or how jeep set it up) and had to drive for a while before the temperature read correctly - 78 degrees.
JEEP ENGINEERS: a simple solution to this is when a Jeep is first powered up and you know that by many indicates (engine temperature, etc), read the outside temperature and set the display. Then keep your other requirements in place. A simple software fix and the system will be better for this. Just a suggestion.
Thanks
Bill
We understand the concern and have addressed the concern with our dealers. Thanks for the suggestion,we continue to strive to improve our vehicles.
post #50 of 124 Old 10-24-2007, 04:58 PM Thread Starter
JeepEngineers
Originally Posted by Decipticon
Well, no ones asked it yet....lol
Any chance of the next model having a solid axle in the front? It should.
Also if I were buying a new vehicle in this class, I would be looking for mechanical options not luxury "fluff" such as lockers, gearing, and skid plates. Also I would definitely give preference to whichever model offered a manual transmission, as would a diesel option (where I didnt have to pay 40k for unneeded options, and that wasnt a Mercedes engine with no parts available).
Thanks for hearing my opinions.
While the standard "we cannot comment on future product" statement applies...
I would be remiss in not bringing up the advantages the IFS has on steering and handling. I think you'll find the IFS equiped WK will best the solid front axle WJ in most any offroad venue. Believe me we checked.
That said, the beam axle does make it easier to modify the vehicle and softens the occational contact with terrain. Can I interest you in a JK Unlimited.
post #51 of 124 Old 10-24-2007, 04:59 PM Thread Starter
JeepEngineers
Originally Posted by HDC
Not nearly as ugly as it sounds!
Since I bought my Grand in March '05 I've been far more pleased with it than I ever expected. This is a fine car that has exceeded all of my expectations in a Jeep. But here's my list of various things I'd love to see in future Grands. You all don't need to respond directly unless you've got something other might find useful. Just sharing my thoughts!
Mechanical list:
-Make ESP defeat an EVIC option, not a short lived dash button
-Make the TPMS controller amenable to running on low pressure when offroading. Maybe have it silence warnings when in low range.
-What ever happened to DHS? I'd love to see this show up someday.
Thanks for your input - good list!
ESP and TPM are required by law (or soon will be). We do disable the TPM chime in low range, though the light will still be on. DHS was intended as an on-road enhancement but never made it to production because of development issues.
post #52 of 124 Old 10-24-2007, 04:59 PM Thread Starter
JeepEngineers
Hi Folks
Back in May I was interested Daytime Running Light for 07 Overland - Here is the response from Brian at Jeep.
"Hello Bill,
Thank you for question. I understand your request and the usefulness of this feature. You are correct that this feature is available in other countries because it is a country specific requirement. We are currently investigating the feasability of enabling the U.S. dealers to activate this feature upon customer request. Stay tuned.
Thanks,
Brian
Has there been a change in the status on the DRL? I would very much like to have this feature. I have to turn the light on each time I drive but don't need the tail light and dash lights on. An information would greatly appreciated.
thanks
Bill
Hello Bill,
I just tried contacting the engineer who is working on your request from the previous session. Unfortunately, he was not available right now. All I can suggest is to keep an eye out for an upcoming change.
post #53 of 124 Old 10-24-2007, 04:59 PM
Arcticcat843
dakuda is a god
Arcticcat843's Avatar
1980 CJ5
we have a 06 GC and the air bad light randomly goes on and off ( and dings) Any idea what could cause that? What should i do to fix it? We just don have the time to take it to the dealer not have it for a coupe days.
this might have already been said (im to lazy to read the other posts) but.....You should make a rubicon edition GC. Something with a little lift and some mud tires....maybe some e lockers and stuff.....I would buy one if you did
Arcticcat843 is offline
post #54 of 124 Old 10-24-2007, 05:00 PM
jscaffidi
Originally Posted by JeepEngineers
Depending on your type of radio (needs to be a AN level or later, check your p/n), you can install a rear view camera and the previous response was correct, you will need assistance from a dealer. Remember, in order to install this feature on your own, you can void your warranty. I would recommend the Mopar rear view camera system. If you do decide to proceed on your own (Caution, Caution.), you'll need the radio, rear brow with camera, wire, i/p bezel... etc. Once it's all installed, your dealer will need to configure the FCM (front control module) for rear camera using a Starscan.
1) Is this now a dealer option, and if not, when will it be?
2) What part of the warranty would be voided and why? On the radio or on everything?
3) If I have the dealer install it (when the scan update is available) would that also void the warranty?
4) What's the i/p bezel?
Thanks again for your time.
jscaffidi is offline
post #55 of 124 Old 10-24-2007, 05:01 PM
Decipticon
Hello Bill,
Make it an option at least, better yet dont do it. I hate drl's.
Jesus is coming. Look busy.
Decipticon is offline
post #56 of 124 Old 10-24-2007, 05:03 PM
oH2o
On a prior model WK I had the EVSII security system and really liked it. Unlike other aftermarket systems, the Mopar version never once produced a false alarm, it worked flawless. I notice in the new 2008 Mopar catalog that the EVSII is not compatible with new 2008 models, probably due to the new ignition system. Will Mopar be coming out with an updated version for the 2008 models?
oH2o is offline
post #57 of 124 Old 10-24-2007, 05:05 PM Thread Starter
JeepEngineers
I love my WK and the hemi is pure fun. But in the real world this gas burner is becoming less and less practical every day. So I've been looking towards replacing it with a diesel when the time comes to retire it. But so far most manufacturers will void your warranty if you run anything more than B5-B20 in your diesel, which has been a huge hindrance in going this route. Plus that little problem of not being able to get 50 state legal diesels in anything other than trucks!
Anyway, when I get around to replacing this Grand, I'd really love to do it with a non-NOx spewing (read Bluetec sort of clean) Grand Cherokee. And I'd like to be able to run B100 in it without having my servicing dealer chewing me out for doing so. Can you please push with your engine suppliers (Cummins, Mercedes, whomever it may end up being) to make bio a real option for us?
Thanks for your input! We will take this into consideration on future products.
We understand the desire to run bio-fuels, and we would like to do so in the future. There are 2 main issues with using bio-diesels more than B5-B20.
1. Cold start - biodiesel fuel have significant issues with gelling
2. High pressure fuel system durability - biodiesel lubricity is not well controlled
When the fuel industry have a standard for the fuel so the lubricity and chemistry of the fuel are standardized, then we can really work on solving the remaining issues.
post #58 of 124 Old 10-24-2007, 05:08 PM
diegom6
Just forgot to ask,
hope you don't take both posts of me in this thread bad and for being too long my questions
Just to ask if you can feel the 5.7L HEMI quite slow in reaction while you are about 5-10 MPH idling and then hit the gas pedal to whatever position, mainly half throttle or WOT...you can feel this delay in response.
For the record, the 05's HEMI's doesn't share this delay under the same situation (at least, not that notorious like the 06 and up), also the early 06's HEMI's doesn't too...I call early 06's HEMI's those that didn't get the rest arm in leather from factory, late 06's (made in that year) got the rest arm with leather.
I was looking for any update for the software for this problem but didn't find any
However this won't happen if you are idling and the Jeep it's stopped, like in a red light, you hit the gas pedal and it reacts inmediatly, no cmpliment there....but once you are about 5-10 MPH and do the same you can notice a delay. Many persons that tested these involved Jeeps felt the same and compliment about it.
Here are some pics I took from my StartScan
http://diegom6.m20turbo.com/Jeep/Tal...0sized%201.jpg
http://diegom6.m20turbo.com/Jeep/Tal...seized%202.jpg
http://diegom6.m20turbo.com/Jeep/Tal...seized%203.jpg
http://diegom6.m20turbo.com/Jeep/Tal...seized%204.jpg
Cheers from peru
-Diego
- ARB Lockers
- AX15
diegom6 is offline
post #59 of 124 Old 10-24-2007, 05:10 PM
CEPCNC
2005 WK
Is there any news on what Cummins' LDD program might be bringing to the linup other than Dakota? I've seen the engine in person and seen it in a few different non-Jeep vehicles as well? Looks like it could be a somewhat universal engine with the right base mounting? Any comments on this?
CEPCNC is offline
post #60 of 124 Old 10-24-2007, 05:11 PM Thread Starter
JeepEngineers
1.Yes, the Camera is a production(factory) option for 07 and beyond. However, for 2005 to 2007 it is not available through Mopar Accessories. It will be available for 2008 GC
2.Voiding warranty refers to changing wiring, lic plate brow, etc
3.If you have the dealer do (which is required because the vehicle must be programmed/told it is equipped with a back up camera)- No this should not void your warranty
4. I/P = Instrument Panel
Closed Thread
7/29 Q/A Session - 2007-2008 MK JeepEngineers Jeep Engineering - Q&A Archive 108 07-29-2008 06:03 PM
05/13 Q/A Session - Jeep Commander JeepEngineers Jeep Engineering - Q&A Archive 92 05-13-2008 06:10 PM
08/29 Q/A Session - Commander JeepEngineers Jeep Engineering - Q&A Archive 132 08-31-2007 10:43 PM
05/30 Q/A Session - 2005 - 2007 Grand Cherokee JeepEngineers Jeep Engineering - Q&A Archive 149 06-07-2007 07:19 PM
03/14 Q/A session - 2007 Wrangler JeepEngineers Jeep Engineering - Q&A Archive 329 03-22-2007 07:58 PM
You may not post new threads
