Quantcast 09/29 Q/A Session - Jeep Wrangler and Wrangler Unlimited - Page 8 - JeepForum.com
Go Back JeepForum.com > General Jeep Forums > Jeep Engineering - Q&A > 09/29 Q/A Session - Jeep Wrangler and Wrangler Unlimited
Closed Thread
Old 09-29-2009, 04:39 PM   #106
JeepEngineers
Originally Posted by Jordon83 View Post
What can be done to help the zipper on the rear window zip easier? On my JK the teeth get unaligned very easily making it hard to unzip.
There is a zipper lubricant available thru your dealer. it is a lube and brush item and helps with the zippers.
The old stand by is rubbing a bar of soap on the zipper teeth - but it can create a mess too!
[FONT="Arial Black"][SIZE="4"]JeepEngineers[/SIZE][/FONT] "INTRODUCING THE GREATEST JEEP[SIZE="1"]®[/SIZE] LINEUP EVER"
[I][URL="http://www.jeep.com/"]http://www.jeep.com/[/URL]
[URL="http://www.jeep.com/en/experience/community/have_fun_out_there/"]Have Fun Out There![/URL]
[URL="http://www.facebook.com/jeep"]Check out Jeep on Facebook[/URL]
[URL="http://www.youtube.com/thejeepchannel"]Check out Jeep on YouTube[/URL]
[URL="http://www.flickr.com/groups/jeepexperience/"]Check out Jeep on Flickr[/URL][/I]
JeepEngineers is offline
Old 09-29-2009, 04:39 PM   #107
JeepEngineers
Originally Posted by waterboarder View Post
Is this true even if the vehicle came with the tow package from the factory, but with a 4-pin connector?
Factory tow packages should come with the 7 pin connector anyway - by the way. The Commander does - why not the JK? (:
If your vehicle has the 4 way factory installed trailer wiring you will not need the update to the vehicle configuration.
Old 09-29-2009, 04:39 PM   #108
JWA
I recently noticed a high-pitched whine which seems to be coming from the engine bay when I am at steady part-throttle on my '09 Rubicon with an automatic tranny (6K miles). Backing off of the throttle stops it, and I can't tell if giving it more stops it or it gets too loud to hear it. Do you have any ideas what this could be?
JWA is offline
Old 09-29-2009, 04:40 PM   #109
JeepEngineers
Originally Posted by Boston_JK View Post
I read on another forum that there was a recall on the center console lock/latch as it can be opened even when locked. Any truth to this? If so, what's the recall/TSB notice number. I checked my VIN for a recall (09 JK built 4/2009, took delivery 2 days before bankruptcy). My center console can be opened when locked when a bit of pressure by hand is applied to the push-in latch. Asked the dealer about it (5/1/2009) and they couldn't repair it, and the remaining JK's on their lot had the same issue at that time.
Thanks,
-Michael
There is a TSB for this very issue - it's number 23-018-09. Your dealer can find it on DealerConnect (they'll know what that is)
Old 09-29-2009, 04:40 PM   #110
Agent 000
Secret Agent Man
Agent 000's Avatar
Big thanks to whomever made the tow hooks, fog lamps and stain-repel seats standard on the '10 Wrangler's. Nice to see that the engineers listen to the owners, and can accommidate our requests.
Now, can we please get the Yellow Paint back?
Heritage Region Jeep Alliance
http://www.hrja.com
Forest Green 2000 Jeep Cherokee Sport
Chili Pepper Red 1998 Jeep Cherokee Classic
Agent 000 is offline
Old 09-29-2009, 04:41 PM   #111
JeepEngineers
Have you added a cold air intake to the vehicle? We've seen this noise too, and it seems to be more prone to happening with a CAI...
Old 09-29-2009, 04:42 PM   #112
JeepEngineers
Originally Posted by Marauder_Pilot View Post
I think the premium that the current crop of diesel vehicles cost over the gas equivalents is pretty reasonable, especially in Canada (Since diesel is back to being noticeably cheaper then gas).
I know that current regs really do a number on your ability to use diesel engines, but hopefully Fiat holds the answer here. At the very least, you know there's an eager and devoted market.
Diesels - lots of goverment regulations... LOTS.
Emissions are a huge challange for certification....
Old 09-29-2009, 04:42 PM   #113
JeepEngineers
[QUOTE=Kip03TJ;8016340]I have a 03 Sahara and I'm putting selectable lockers in it. My instrument panel shows the front lock and rear lock at the top right but since I don't have the rubicon I don't have the wiring harness so I think I'm SOL. Do you know how I'd be able to light up each one without a harness? Possibly getting 12v to the lights back there somehow? Any ideas? I want a real clean look like from factory. Thanks!
Here's the back side of it. I'm thinking I'll have to take it apart but I'm not sure if that will screw things up or not.
You should be able to remove the back cover carefully and trace the lamp circuits on the board. You may be able to attach to the connector, but the light wiring will not be in the harness. Just be careful with the board.
Old 09-29-2009, 04:42 PM   #114
Jordon83
2009 JK Wrangler
Ditto. Who's crazy idea was it to pull yellow? I was very surprised to hear that it was dropped.
Jordon83 is offline
Old 09-29-2009, 04:43 PM   #115
CCJ
Are you all preparing for the Hummer HX (some now it as an H4) rumored to come late 2010? I think a V-8 2-door JK is the answer.
CCJ is offline
Old 09-29-2009, 04:44 PM   #116
waterboarder
waterboarder's Avatar
Thanks (:
I didn't have my computer "updated" after adding the 7-way harness. I was just curious if I should or not. You answered it (:
waterboarder is offline
Old 09-29-2009, 04:44 PM   #117
JeepEngineers
Originally Posted by BODiSek View Post
Well, I already had larger aftermarket (Rancho) stabilizer put on, which kept the steerign in check for about 3-4k, after that the wobble kept creeping back in stronger and stronger to the point when even this stablizier started leaking fluid... I think the problem have to be somewhere else - I cannot change steering stabilizer with every oil change
Just a few simple questions please do not be offended:
Have the tires been confirmed to be in balance?
Alignment been confirmed in spec?
Have the dealer verify the front axle is in spec for caster?
Has the vehicle been wheeled off road? Potentially bent an axle tube.
Old 09-29-2009, 04:44 PM   #118
JeepEngineers
Originally Posted by flame0086 View Post
Not sure if this is a JK specific thread or all wranglers. I was eventually going to go to a dealer and ask about this issue. My 91 YJ has an issue with the parking break. I believe that I took it in for a recall about six years ago. My new issue is that the parking break will not say locked in when under pressure.
For example, the parking break will hold the jeep on a hill if and only if I hold the pedal down with my foot. Once I release my foot 95% of the time the parking break will unlock and snap back, thus no longer holding on the hill.
I have not looked at the break pedal assembly, but I am wondering if this is a recall? It sounds familiar to what the recall was fixing.
I would take the vehicle to the dealer, it sound like the mechanism could be broken.
Old 09-29-2009, 04:44 PM   #119
yoda13
Force Wheeler
yoda13's Avatar
I have faith....
2007 White Jeep Wrangler X-auto, black freedom top, 15x8 Pro Comp Rock Crawlers, 33x12.5x15 BFG KM2s, Superchips Flashpaq, 2" OME Spring Lift, Rancho RS5000 shocks, Rusty's Adjustable front and rear trac-bar, JKS Quicker Disconnects, Rusty's adjustable lower control arms (front and rear), PolyPerformance adjustable upper control arms (front and rear), OEM Rubicon Rock Rails, Finishlinewest Stonehenge Series rear bumper, Smittybuilt winch, Body Armor Front High Clearance Bumper w/ KC Highlights mounted, Roadmaster towbar, Valley 2" receiver hitch, Skid Row Engine Transmission skid, sPod switching system, KC Highlights windshield mounted lights, and Bestop saddlebags-Member of the United Four Wheel Drive Association and Blue Ribbon Coalition, John 3:16
If you want to help the sport of off-roading, and protect your right to do so, please visit the Envirobeat
forum...
yoda13 is offline
Old 09-29-2009, 04:45 PM   #120
JWA
No, completely stock. It takes a split second for it to set up once you go to the throttle. I generally have the radio on, so I don't hear it.
JWA is offline
Closed Thread
Glock Forum
