Quantcast 09/29 Q/A Session - Jeep Wrangler and Wrangler Unlimited - Page 7 - JeepForum.com
Go Back JeepForum.com > General Jeep Forums > Jeep Engineering - Q&A > 09/29 Q/A Session - Jeep Wrangler and Wrangler Unlimited
Closed Thread
Old 09-29-2009, 04:32 PM   #91
JeepEngineers
Originally Posted by xplodn View Post
What do you recommend to fix the constant exhaust cracks in the older TJ 4.0L models? A nice flex pipe? There is all sorts of opinions on it so Id like the Jeep designers take. Will a 00-06 bolt right up with header back modifications?
The 2-piece cast iron unit will bolt up, but as you noted, you'll have to do a custom job on the rest of the system unless you want all those catalysts...
[FONT="Arial Black"][SIZE="4"]JeepEngineers[/SIZE][/FONT] "INTRODUCING THE GREATEST JEEP[SIZE="1"]®[/SIZE] LINEUP EVER"
[I][URL="http://www.jeep.com/"]http://www.jeep.com/[/URL]
[URL="http://www.jeep.com/en/experience/community/have_fun_out_there/"]Have Fun Out There![/URL]
[URL="http://www.facebook.com/jeep"]Check out Jeep on Facebook[/URL]
[URL="http://www.youtube.com/thejeepchannel"]Check out Jeep on YouTube[/URL]
[URL="http://www.flickr.com/groups/jeepexperience/"]Check out Jeep on Flickr[/URL][/I]
JeepEngineers is offline
Old 09-29-2009, 04:32 PM   #92
yoda13
Force Wheeler
yoda13's Avatar
Originally Posted by ZJones View Post
Absolutely. I would hate to see no solid front axle on a wrangler.
Yes, please ALWAYS keep the solid front axle on the Wrangler...to me, it wouldn't be a Wrangler without it....
2007 White Jeep Wrangler X-auto, black freedom top, 15x8 Pro Comp Rock Crawlers, 33x12.5x15 BFG KM2s, Superchips Flashpaq, 2" OME Spring Lift, Rancho RS5000 shocks, Rusty's Adjustable front and rear trac-bar, JKS Quicker Disconnects, Rusty's adjustable lower control arms (front and rear), PolyPerformance adjustable upper control arms (front and rear), OEM Rubicon Rock Rails, Finishlinewest Stonehenge Series rear bumper, Smittybuilt winch, Body Armor Front High Clearance Bumper w/ KC Highlights mounted, Roadmaster towbar, Valley 2" receiver hitch, Skid Row Engine Transmission skid, sPod switching system, KC Highlights windshield mounted lights, and Bestop saddlebags-Member of the United Four Wheel Drive Association and Blue Ribbon Coalition, John 3:16
If you want to help the sport of off-roading, and protect your right to do so, please visit the Envirobeat
forum...
yoda13 is offline
Old 09-29-2009, 04:32 PM   #93
BODiSek
Originally Posted by JeepEngineers View Post
I am sorry to hear that you are having continued issues with steering shimmy. It is not a Jeep issue it is more of an issue related to the fundamental architecture of a solid front axle suspensions system. If you have had your steering stabilizer replaced multiple times and have verified that your tires are in balance then it is most likely contributed to your steering stabilizer. There is a new improved steering stabilizer service fix that should be out by years end that will resolve your issue. Another option is to install a aftermarket stabilizer that is larger than the current production
Well, I already had larger aftermarket (Rancho) stabilizer put on, which kept the steerign in check for about 3-4k, after that the wobble kept creeping back in stronger and stronger to the point when even this stablizier started leaking fluid... I think the problem have to be somewhere else - I cannot change steering stabilizer with every oil change
BODiSek is offline
Old 09-29-2009, 04:33 PM   #94
Jordon83
2009 JK Wrangler
What can be done to help the zipper on the rear window zip easier? On my JK the teeth get unaligned very easily making it hard to unzip.
Jordon83 is offline
Old 09-29-2009, 04:33 PM   #95
JeepEngineers
Originally Posted by Jordon83 View Post
Stupid question: Why the name change from X to Sport??
Marketing speak... packaging content stuff . . .
Old 09-29-2009, 04:33 PM   #96
GRN_BEAST95
okay heres my queation. My jeep is throwing the code 41 whick i understand is the alternator field. Now what exactly does that mean?? and also my alternator makes a loud hissing nois when im driving and it gets louder with the rpms. My jeep is hiccuping alot and i believe the Alt. is the problem. Can you confirm or refute?
1995 YJ emerald green
4" RC lift & 2" BL
33x12.5x15 BFG AT's
Green Jeep member 153
Originally Posted by yellojeeper View Post
Guam. I spent a week there one night.
GRN_BEAST95 is offline
Old 09-29-2009, 04:34 PM   #97
Mean Max
Mean Max's Avatar
We can only recommend the correct lubricant as found in your owners manual or service literature, so we can't speak to the use of alternate lubricants. In terms of the synchros, there again, all we would be able to suggest are the O.E. parts, assuming they are are still available from your dealer...if the aftermarket has come up with different materials, we wouldn't necessarily be aware of that or be able to recommend them.
Originally Posted by JeeperDon View Post
How about a rephrase? What do dealer service shops put in the AX5/15 of a YJ when it is in for service and needs fluid? I do not believe there is a GL-4 Mopar fluid available.
Like JeeperDon, I would like some clarification on that point.
Here is what I use, and the advice I give others here on the forum (actually copied from a previous post of mine), it's based on my own research and I would like to know if it's accurate information.
Here's why I use 10W-30 motor oil.
The Mopar gear oil part number used to be 4897622aa, but when you search that part number you'll see it has been superceded by part number 4761839AC which comes up as 10w-30 motor oil. Here's a link to search the Mopar part numbers.
Discount Mopar Parts Jeep Dodge Chrysler parts & accessories with great service
Max
Click here to see all of my different albums on Photobucket.
Choose any album to see all of my pics!
Mean Max is setting up his Jeep shop!
Picture history of my progress here.
Originally Posted by UltimatE View Post
Max has a picture of every Jeep part ever made.
Originally Posted by Benderff View Post
No one here knows what they are talking about. You should try Pirate 4x4 they will be happy to help you.
There is no situation that cannot be improved with a small but well-placed explosive.
Mean Max is offline
Old 09-29-2009, 04:34 PM   #98
waterboarder
waterboarder's Avatar
Lubing the zipper helps a lot. I use the same stuff I use for my drysuit - bee's wax.
waterboarder is offline
Old 09-29-2009, 04:34 PM   #99
JeepEngineers
Mopar does sell a zipper lubricant that helps with this...
Old 09-29-2009, 04:34 PM   #100
jay-h
Yes ... the dealer must update the software of the vehicle. This is required to ensure that the computer understands that there may be an additional electrical load placed by the property in tow. Without this update, the vehicle may think there is an electical issue, when there is not
This is why I am SO GLAD to be driving an older, computer free Wrangler.
jay-h is offline
Old 09-29-2009, 04:35 PM   #101
Marauder_Pilot
Marauder_Pilot's Avatar
specify "wack"...unfortunately with the diesel emission regulations, it'll take a whole lot of it....
I think the premium that the current crop of diesel vehicles cost over the gas equivalents is pretty reasonable, especially in Canada (Since diesel is back to being noticeably cheaper then gas).
I know that current regs really do a number on your ability to use diesel engines, but hopefully Fiat holds the answer here. At the very least, you know there's an eager and devoted market.
"Buying a Jeep for on-road handling is like downloading porn to savor the cinematography."
-TTAC
Marauder_Pilot is offline
Old 09-29-2009, 04:35 PM   #102
JeepEngineers
Originally Posted by yoda13 View Post
is there any reason that you can not put an auto in the JK with more gear ratios? Will it not fit, I would think this would help with both power and economy....
oh yeah, please build a diesel....
Given enough funding you can put any transmission in any vehicle. In the beginning of a new vehicle program , a powertrain is chosen based on many factors ( package space, gear ratios, cost etc.). The calibrators then spend many months programming the computer to meet the vehicle requirements. When a vehicle is in production, the costs to revise a trans are very high so there generally needs to be an engine revision or new model to justify a new trans.
Old 09-29-2009, 04:35 PM   #103
Boston_JK
2009 JK Wrangler
Center Console lock recall???
I read on another forum that there was a recall on the center console lock/latch as it can be opened even when locked. Any truth to this? If so, what's the recall/TSB notice number. I checked my VIN for a recall (09 JK built 4/2009, took delivery 2 days before bankruptcy). My center console can be opened when locked when a bit of pressure by hand is applied to the push-in latch. Asked the dealer about it (5/1/2009) and they couldn't repair it, and the remaining JK's on their lot had the same issue at that time.
Thanks,
-Michael
Boston_JK is offline
Old 09-29-2009, 04:36 PM   #104
JeepEngineers
Solid axles forever- this will never happen on my watch.....
Old 09-29-2009, 04:39 PM   #105
rustywrangler
Got my eye on you.....
rustywrangler's Avatar
THERE IS A GOD, YOU. Thankyou for saying this. No more questions need to be asked tonight.
http://i131.photobucket.com/albums/p...k_banner-1.gif
Congenital Heart Disease is a reality for me, BOTH of my children have it. Please read up and become aware for future generations
Lydia Ann-Acquired 08/05/05 Open Heart surgery 08/10/05
Jacob Patrick-Acquired 01/17/08 Open Heart surgery 02/15/08
rustywrangler is offline
Closed Thread
Glock Forum
