Quantcast 09/29 Q/A Session - Jeep Wrangler and Wrangler Unlimited - Page 10 - JeepForum.com
Go Back JeepForum.com > General Jeep Forums > Jeep Engineering - Q&A > 09/29 Q/A Session - Jeep Wrangler and Wrangler Unlimited
Closed Thread
Old 09-29-2009, 04:50 PM   #136
CCJ
TJ questions welcomed?
Any reason for the sudden jerk forward without stepping on the gas when turning full lock while goin between 2-5 mph? Doesn't happen all the time...but it happened today. Jeep is a 2006 TJ sport with the 42RLE auto
My TJ also does this. About 60% of the time. Very odd.
CCJ is offline
Old 09-29-2009, 04:51 PM   #137
JeepEngineers
Originally Posted by ZJones View Post
Any chance of seeing an unlimited model like the LJ? I really liked the two door design with a longer wheel base.
No comments on the future stuff.
But, we like hearing stuff . . .
[FONT="Arial Black"][SIZE="4"]JeepEngineers[/SIZE][/FONT] "INTRODUCING THE GREATEST JEEP[SIZE="1"]®[/SIZE] LINEUP EVER"
[I][URL="http://www.jeep.com/"]http://www.jeep.com/[/URL]
[URL="http://www.jeep.com/en/experience/community/have_fun_out_there/"]Have Fun Out There![/URL]
[URL="http://www.facebook.com/jeep"]Check out Jeep on Facebook[/URL]
[URL="http://www.youtube.com/thejeepchannel"]Check out Jeep on YouTube[/URL]
[URL="http://www.flickr.com/groups/jeepexperience/"]Check out Jeep on Flickr[/URL][/I]
JeepEngineers is offline
Old 09-29-2009, 04:51 PM   #138
JeepEngineers
Originally Posted by bunkrdfool View Post
Any chance we can get a add-on to the owners manual about the Jeep wave?
Im tired of driving to work and having 1 out of 5 Jeeps wave. Maybe just a little sheet would be fine.
And thanks for the Q&A!
See you are finding out that you have to be in the know - the secret society!
Old 09-29-2009, 04:52 PM   #139
JeepEngineers
When a vehicle is at full lock it takes more power to move forward than when the wheels are pointed straight. The engine will need more fuel to keep the it from stalling. The surge you feel is the push of fuel to maintain engine speed under full lock conditions.
Old 09-29-2009, 04:53 PM   #140
JeepEngineers
Originally Posted by waterboarder View Post
I really need an answer to this one (:
I realize you recommend not modifying anything for any reason. CorporateSpeak(tm) understood (:
That said, although while it may not be recommended - if someone WERE to tap into the brake wire "hot side" so that their trailer brake controller would work, and if one found trying to access that wire under the steering wheel too painful and difficult (ask me how I know), where could one find the appropriate wire under the hood? What colour and where is it, and picture would help (: Rumour is that it can be tapped over there, rather than under the steering wheel.
Thanks a bunch!
Do not modify the brake wiring....
We will not help on this one.. sorry.
Old 09-29-2009, 04:53 PM   #141
JeepEngineers
Originally Posted by JWA View Post
No, completely stock. It takes a split second for it to set up once you go to the throttle. I generally have the radio on, so I don't hear it.
Ok...it's a fairly rare occurence, but we have seen a few do this even with the stock intake system. We did issue a TSB for a similar condition on 3.7L, TSB # 09-001-07, you can perform (or have your dealer perform) the same procedure on a 3.8L. Essentially what is happening is that as air passes over the joint/seal in between the throttle body, if there are any voids at all in that joint it creates noise. Essentially the TSB shows you where to judiciously apply RTV in that area to fill in any voids.
Old 09-29-2009, 04:53 PM   #142
FIRE14
I have an 02 sahara all of it is in factory form except for the 31x10.50r15 tires. it has had the axle seals replaced by the dealership and front swaybar end links replaced by a local garage tires and wheels are in balance and allinement is good but still have a vibration coming from all four cornners, what do I need to check now
FIRE14 is offline
Old 09-29-2009, 04:54 PM   #143
2006_Sport
Thanks so much! I knew that there was a logical reason for it
SUPPORT THE TROOPS
2006 Jeep Wrangler|BDS|BFGoodrich|Uniden|Upol|HiLift|Cragar| Hella|Alpine|JKS|PoisonSpyder|Delta|Aussie Locker|Bluetorch Fab|Novak|Trail Gear
-Zach
2006_Sport is online now
Old 09-29-2009, 04:54 PM   #144
Jones
Infowars.com
Jones's Avatar
Fair enough.
The only things holding me back from buying a wrangler are - no v8 option (I love the 5.9 v8 in my ZJ and don't think I would be happy with the v6), no long wheel base 2 door option like the LJ.
What is it about Ron Paul?
Jones is online now
Old 09-29-2009, 04:54 PM   #145
CCJ
I'd simply like to add.... V-8. Please. Burnsville off road is doing it with no problems. AEV-conversions is doing it with no problems. I'm ready for DC to start doing it.... w/ warranty of course. It's the only reason I haven't sold my TJ yet. I love the JK's but I'll patiently wait for that V-8 to make that next purchase. To hell with the "economy" & "no-one would buy it" remarks that some members are going to post.
CCJ is offline
Old 09-29-2009, 04:55 PM   #146
waterboarder
waterboarder's Avatar
So your recommendation then is NOT to use trailer brake controllers?????
waterboarder is offline
Old 09-29-2009, 04:55 PM   #147
JeepEngineers
Originally Posted by xplodn View Post
Has there been any official fixes for rough shifting in the AX-15 with 100K+ miles? 10W-30 or what? I currently am running Redline MT-90 (around 90W) in it but even that is not helping.
No official fixes.. baby it.
Sycros wear out. Let it spool down a bit before shifting into next gear
Old 09-29-2009, 04:56 PM   #148
xplodn
fair enough.
xplodn is offline
Old 09-29-2009, 04:56 PM   #149
BODiSek
Just a few simple questions please do not be offended:
Have the tires been confirmed to be in balance?
Alignment been confirmed in spec?
Have the dealer verify the front axle is in spec for caster?
Has the vehicle been wheeled off road? Potentially bent an axle tube.
Tires have been checked and balanced, alignment done two times. Most recent numbers are caster 4.25, toe 3/16, BUT camber -1 and -3/8 which got me thinking about bent axle as well. However I've been told that camber will have no influence on this issue, and those numbers are pretty common even if out of factory specs. I doubt it would be possible to bend axle with stock tires with only mild off-road (forest service roads and such)?
BODiSek is online now
Old 09-29-2009, 04:57 PM   #150
JeepEngineers
Next I would look at the upper control arm bushings and the steering stabilizer.
Closed Thread
Glock Forum
