09/09 Q/A Session - Jeep Wrangler and Wrangler Unlimited
#61 | ||
Only if you make one for a TJ at the same time!!!
#62 |
What are your thoughts on the subtle "steering column clunk" that a lot of us are putting up with? Do we keep injecting high tack/thicker grease?
#63 |
You guys do realise that a 5.7L V8 Wrangler would sell like hotcakes out here in the Middle East right?
#64 | |
Perhaps not as acceptable to the traditional jeeper, but what can you do. I had plans of a carpet job in the old YJ before the spontanious engine fire RIP |
#65 |
Just bought new 98 TJ Wrangler Hardtop. It did not come with rear defrost. I want to find a rear window with defrost. BUT here's the QUESTION:
Does the factory wiring harness already support that modification? and Where do I find the switch that goes in the dash? |
#66 |
I have an 07 Sahara Unlimited soft top.
Is there an aftermarket kit to add a center hold-down latch for the soft top? Not sure if that is the right term. The latches that secure the top to the windshield frame. It could hook to the windshield tie down that is already welded there. If it is a windy day, at highway speeds the wind noise is god awful. I have to reach up and pull down on it and the noise goes away. A third latch would solve that. |
#67 | |
Just there, huh ?? ![]()
[FONT="Arial Black"][SIZE="4"]JeepEngineers[/SIZE][/FONT] "INTRODUCING THE GREATEST JEEP[SIZE="1"]®[/SIZE] LINEUP EVER" [I][URL="http://www.jeep.com/"]http://www.jeep.com/[/URL] [URL="http://www.jeep.com/en/experience/community/have_fun_out_there/"]Have Fun Out There![/URL] [URL="http://www.facebook.com/jeep"]Check out Jeep on Facebook[/URL] [URL="http://www.youtube.com/thejeepchannel"]Check out Jeep on YouTube[/URL] [URL="http://www.flickr.com/groups/jeepexperience/"]Check out Jeep on Flickr[/URL][/I] |
#68 |
Are there any plans to place the Inline 6 back in to wranglers?
2000 Solar Yellow TJ - 4.5" SA Lift - 2" Body Lift (Gross) - 35x12.50xR15 BFG KM's - 8500 lb. Smittybilt XRC8 Check out my build thread! Coming soon: (Green=Done, Red=In Process) HP Dana 44, Ford 9", 4340 35 spline shafts, 101" wheelbase, Aussie Front, Detroit Rear, 4.88 Gears, 38x13.50x16 IROK's |
#69 | |
#70 | |
Nope - Impact and emissions . . . ![]()
#71 |
Where do you do winter testing on the JK?
I know land rover does winter testing in Thompson, Manitoba, Canada. It can be as low as -45. |
#72 |
JF Administrator, eh?
I would love to see a factory 1-ton version of the JK-4door that comes with 37" tires stock, Dana60's front/rear and a towing capacity that will haul a decent sized camping-trailer. Right now we are limited to only 3500lbs towing behind the Jeep, and the options for trailers are very limited in that kind of class.
I just purchased a Fleetwood Evolution E1 trailer to tow behind my Jeep and the power department is very lacking on hills, I cannot locate side-mirrors to see around the trailer and the tail of my Jeep sits close to the bump-stops. I will be installing helper-air-bags this weekend to try to compensate for the sagging - but - is there anything else that I can do?
Hello, my name is Vance and I am a Jeepaholic. Its better to be naked with your friends, than to be clothed with your enemies #1 From street to trail, '88 YJ on 38" tires does it all well #2 Silver 2006 TJ Unlimited, zombie ready as the daily-driver .. and now a Kawasaki KLR650 DualSport bike TEOTWAWKI |
#73 |
Why doesnt jeep make a wrangler with a pick-up bed option from the factory?
#74 |
Hi,
I have an 06 TJ Unlimited and it doesn't have the factory auto dim mirror. I want to upgrade to the factory style auto dim mirror with compass, temp, and map lights. I did notice that there is a temp probe behind the grille. I have heard that a wiring harness is already installed on these, but when I removed the top cover on my dash, it was nowhere to be found. Where would this harness be or don't the 06's have this? |
#75 | |
![]() A few places.... usually like 20 to 30 below zero for cold starts, warm ups, and defroster performance. Not the fun trips.... BRRR !
| Thread Tools | |
Previous Thread
Next Thread
| Suggested Threads |
