Quantcast 09/09 Q/A Session - Jeep Wrangler and Wrangler Unlimited - Page 10 - JeepForum.com
Go Back JeepForum.com > General Jeep Forums > Jeep Engineering - Q&A > 09/09 Q/A Session - Jeep Wrangler and Wrangler Unlimited
Closed Thread
Old 09-09-2008, 05:52 PM   #136
frumpy
Originally Posted by JeepEngineers View Post
Dealer communication is about to go out and the Dana 60 rear is available now as a "builder's kit" with leaf spring mounts and limited slip differential.
if you can, any idea on price?
2002 Dodge Dakota quad cab V8
2011 Dodge Grand Caravan
frumpy is offline
Old 09-09-2008, 05:53 PM   #137
JeepEngineers
Originally Posted by djmiani View Post
Have a quick question... I have an 04 tj x and there seems to be grease (?) leaking from the back of the front axle where the drive shaft connects to it. I have very little knowledge of axels. Is this normal or is this a serious problem? How can I stop it?
Some minor seepage is not abnormal. To totally stop it, it would need a new seal.
Is it leaving a puddle? If so - get on it and get it fixed. If it's just wet, probably OK.
[FONT="Arial Black"][SIZE="4"]JeepEngineers[/SIZE][/FONT] "INTRODUCING THE GREATEST JEEP[SIZE="1"]®[/SIZE] LINEUP EVER"
[I][URL="http://www.jeep.com/"]http://www.jeep.com/[/URL]
[URL="http://www.jeep.com/en/experience/community/have_fun_out_there/"]Have Fun Out There![/URL]
[URL="http://www.facebook.com/jeep"]Check out Jeep on Facebook[/URL]
[URL="http://www.youtube.com/thejeepchannel"]Check out Jeep on YouTube[/URL]
[URL="http://www.flickr.com/groups/jeepexperience/"]Check out Jeep on Flickr[/URL][/I]
JeepEngineers is offline
Old 09-09-2008, 05:53 PM   #138
Panici
(O|||||||O)
Panici's Avatar
Hey guys, i'm doing some wiring, and I need to find a highbeam trigger wire in the dash.
I'm looking to get a splice off this highbeam wire to the OEM switch panel/cigar lighter area, so closest to there would be best
_______
|_Jeep_|
(OlllllllO)
590nm Jeep TJ Build+Life
Panici is offline
Old 09-09-2008, 05:53 PM   #139
jeepcrd2010
$1000 per jeep reduction?
Corporate is mandating $1000 reduction per jeep, what zones are you looking to trim.
My votes: lighten up the unlimited by 500 lbs.
How can you cut weight and cost?
Rhino coat instead of carpet?
Take off plastic trim (but paint under it).
Simple light cheap slider window doors?
jeepcrd2010 is offline
Old 09-09-2008, 05:53 PM   #140
JeepEngineers
Thank you all for your feedback on the headliner for the Hardtop! We would want to make it to cover the majority of the interior surfaces. Thanks again.
Old 09-09-2008, 05:55 PM   #141
JeepEngineers
It sounds like you have a pinion seal leak. At the very least you should check the level of the fluid. A minor leak can look like a lot of oil, but over time will diminish the fluid level. It's also possible there may be grease coming from the u-joint which should also be checked. If you are not comfortable looking at these items have your dealer inspect them.
Old 09-09-2008, 05:56 PM   #142
iagainsti
I searched the other qtr engineer threads but couldnt find an answer to my question so hopefully this hasnt been asked already. I just purchased a 08 2 door Wrangler X and I dont have a passenger airbag disable light like all the 07's seem to have. Next to my hazard light is just a blank. It appears some 08s have this option while others do not ? Do you know why the disable sensors in the passenger seat are only in certain 08 vehicles ?
iagainsti is offline
Old 09-09-2008, 05:56 PM   #143
JeepEngineers
Best thing to do would be to get a factory shop manual at www.techauthority.com
Be careful tapping into existing circuits though, we design the circuit protection around the "factory" load placed on the circuit. Adding any additional load could cause some problems.
Old 09-09-2008, 05:57 PM   #144
JeepEngineers
Tick Toc - Time is running out !
Last chance guys - ask away . . .
Old 09-09-2008, 05:57 PM   #145
broncofire75
Any changes coming up in the next few years to the Rubicons with all the emissions and crap they have to pass?
Any chance on making them bigger? LOL
-1998 XJ Sport 4.0L-
-6.5" RE/Rustys/RC lift, Custom Y-link LAs, custom shackle relocation boxes, Pro Comp/RE monos-
-315/75/16 Toyo MTs on Moabs-
-Shaved 8.25 w/HD shafts/Auburn LS/4:10s, HP30 w/ Lock-right, sliders, HD track bar bracket, AA SYE, AppA TC skid, AFE intake, Magnaflow exhaust, Bored TB-
broncofire75 is offline
Old 09-09-2008, 05:58 PM   #146
frumpy
frumpy is offline
Old 09-09-2008, 05:58 PM   #147
Matt08jk
JK Wrangler
Where it's dam cold !
A few places.... usually like 20 to 30 below zero for cold starts, warm ups, and defroster performance.
Not the fun trips.... BRRR !
Well I am available to help out during the next winter run, any intern vacancies?....which engineering/design program/school do you guys hire from the most?
Matt08jk is offline
Old 09-09-2008, 05:58 PM   #148
Panici
(O|||||||O)
Panici's Avatar
Alright, i'll look into getting a shop manual then.
I'm just using this tap to trigger a relay for my Aux. Lights.
_______
|_Jeep_|
(OlllllllO)
Panici is offline
Old 09-09-2008, 05:59 PM   #149
JeepEngineers
While we are always trying to control costs of the vehicles we offer, we are currently not under a edict to remove $1000 per vehicle. Thanks for the suggestions.
Old 09-09-2008, 05:59 PM   #150
Elev8orman
Junior Member
a/c
Hi, I have a '97 TJ which loses fan speed when on the highway.
The fan is on med-hi and after maybe half an hour I'm down to
a trickle out of the vents. After an hour parked it works fine, like
nothing was wrong. Any ideas?
Thanks in advance.
Elev8orman is offline
Closed Thread
Glock Forum
