08/29 Q/A Session - Commander - Page 9 - JeepForum.com
Closed Thread
post #121 of 133 Old 08-29-2007, 05:51 PM Thread Starter
JeepEngineers
JeepEngineers's Avatar
Originally Posted by RWB214
Why was the 4.0 Inline 6 engine ditched? It was a tried and tested design. Was it too reliable?
There were a number of reasons why the 4.0L had to be retired. Volume was one consideration - obviously we need to build a certain number of them to justify the expense. Secondly, inline 6 cylinder engines are much more difficult to package in the vehicle and still obtain acceptable crash test results. The 4.0L is both long and tall - a packaging nightmare in a modern vehicles.
JeepEngineers "INTRODUCING THE GREATEST JEEP LINEUP EVER"
JeepEngineers is offline
post #122 of 133 Old 08-29-2007, 05:51 PM Thread Starter
JeepEngineers
Originally Posted by Crashnburn80
The multispeed overdrive automatic 545RFE 5spd transmission has an "alternate 2nd gear for smoother downshifting at higher speeds." So is this really a 6spd auto that selects which '2nd' gear to use based on speed/load?
Seems like an interesting approach, but why not just call it a 6spd, distribute the ratios a little more evenly and have it select 2nd or 3rd based on need (vs 2nd or alternate 2nd)?
If you use the Electronic Range Select (ERS) it will toggle through all 6 gears. If you leave it in Drive it will not go through all gears - it will depend on temperature, speed, and load. Since some of the transmission internals are carryover it would have been more difficult to change all of the gears.
post #123 of 133 Old 08-29-2007, 05:54 PM Thread Starter
JeepEngineers
Originally Posted by Crookster777
It sounds like an exhaust leak but. I think it has to do something with the TCC. I put my Overland in tow/haul and the shudder is gone.
Ah - now I see! When you are in Tow/Haul, MDS is deactivated. What you are hearing when not in Tow/Haul is the exhaust sound caused by 4 cylinder mode. We did our best to make it as transparent as possible while still maintaining that signature V-8 sound (when in 8-cyl mode) and needless to say that's quite a challenge.
post #124 of 133 Old 08-29-2007, 05:54 PM
5.9 ANDY
zj tractor
5.9 ANDY's Avatar
Originally Posted by JeepEngineers
MotorWeek reported the 2006 5.7L Commander as follows:
Horsepower: 330
Torque: 375 lb feet
0-60 mph: 7.8 seconds
1/4 mile: 16.0 seconds @87 mph
60 - 0 mph: 146 feet
EPA: 14 city/ 19 highway mpg
mixed loog: 16 mpg.
You can look up this data on www.motorweek.com. Go to the Road Test tab and search on 'JEEP'
SWEET!!! my ZJ can beet a 5.7 hemi at the drag strip!!! SWEET!
hard working private first class in the United States Marine Corps.
Originally Posted by shift_grind View Post
It's threads like this that make me wonder why people lift there jeeps
its comments like this that make me wonder why some people are jerks.
build thread:
5.9 ANDY is offline
post #125 of 133 Old 08-29-2007, 05:58 PM
mendelmax
I may have one simple question: since XK and WK are on the same platform, and XK diesel is already available in europe, why didn't you offer it on US market? I guess it was done to check how will WK diesel sales look like, but I'm not sure.
Don't think, that I encourage you to do it, diesels suck But I'm just curious.
Ps. Will we ever have WJ related thread?
POLISH JEEP OWNERS CLUB #11
Anyway, nothing will beat Suzuki :D
mendelmax is offline
post #126 of 133 Old 08-29-2007, 06:00 PM Thread Starter
JeepEngineers
Originally Posted by flyrx
My question concerns my 2007 WK CRD Limited 4x4. The owners manual recommends running 5w30 engine oil. Most of the oil available here (without importing from Europe) that meets the MB 229.51 spec is 5w40. Is it possible to run the 5w40 oil without risking engine damage/warranty problems?
BTW, I gotta say, I love the CRD Jeep! May I recommend building a CRD Wrangler...
We are a bit confused, which Chrysler document references the MB spec?... glad to hear you love the CRD, its one of our favorites too!!
post #127 of 133 Old 08-29-2007, 06:00 PM
Crashnburn80
Crashnburn80's Avatar
The necessity of multi-platform support can be a pain.
Thanks for spending time here to answer our questions.
| 1.25" BL |
| Riddler diff covers |
| 33" MTRs | Warn M8000 |
and much more...
Crashnburn80 is offline
post #128 of 133 Old 08-29-2007, 06:01 PM Thread Starter
JeepEngineers
Thanks for the suggestion, but you know our motto - can't comment on future product!
post #129 of 133 Old 08-29-2007, 06:02 PM Thread Starter
JeepEngineers
Thanks for taking the time to respond but what I'm actually looking at is integrating aftermarket Bluetooth and Aftermarket Navigation with the factory head unit.
For example, other manufacturers have a "Mute" wire or at least a mute terminal on the head unit if the wire does not exist.
We've been unable to find this on the JK and I was wondering if we would be able to find this on the Commanders.
At this time I cannot locate an appropriate pin either as a mute input into the radio. This seems like a feature that you are definately interested in. I'll take this idea back to our audio team. Thanks for the thought. Keep any comments coming.
Keep Jeeping in Oman.
post #130 of 133 Old 08-29-2007, 06:03 PM Thread Starter
JeepEngineers
It's 7:00 again folks - we'll try to get to anything left unanswered over the next several days. Thanks for your questions!
post #131 of 133 Old 08-31-2007, 09:51 PM Thread Starter
JeepEngineers
Originally Posted by HeavyMetal
Sure does, that actually sounds pretty cool. As far as spline-age in the axle shafts, 29 spliners? or different?
The Commander 8 1/4 rear axle shafts have 30 splines at the differential.
post #132 of 133 Old 08-31-2007, 10:34 PM Thread Starter
JeepEngineers
Originally Posted by millhousenator
So your saying that if i buy a commander i cant wheel it on the moon? What kind of business are you!
Just curious. How long did you guys spend designing the Commander, and what are some things that inspired ideas (like the little windows in the roof)
You get it to the moon and we will 'wheel it there with you!
We have advanced groups working on vehicles 2+ years before they become a program - the bulk of the engineering is done in the last 2 years before it is launched to the public. The inspiration comes from past vehicles, concept vehicles, current trends, and market demands among others.
post #133 of 133 Old 08-31-2007, 10:43 PM Thread Starter
JeepEngineers
Originally Posted by Rossta
As engineers of the Commander, what feature(s) are you most proud of? or what part do you stand back and say "Hey, I really like how we did that!"
Does that make sense?
Makes perfect sense - that's one reason we do these sessions. It depends on which group of engineers you ask, but one specific item most of us are impressed with is the QuadraDrive II four wheel drive system. (And it's fun testing it too!)
Closed Thread
7/29 Q/A Session - 2007-2008 MK JeepEngineers Jeep Engineering - Q&A Archive 108 07-29-2008 06:03 PM
05/13 Q/A Session - Jeep Commander JeepEngineers Jeep Engineering - Q&A Archive 92 05-13-2008 06:10 PM
10/24 Q/A Session - Grand Cherokee JeepEngineers Jeep Engineering - Q&A Archive 123 11-03-2007 01:30 PM
04/18 Q/A session - 2007 Liberty JeepEngineers Jeep Engineering - Q&A Archive 174 04-18-2007 06:14 PM
03/14 Q/A session - 2007 Wrangler JeepEngineers Jeep Engineering - Q&A Archive 329 03-22-2007 07:58 PM
You may not post new threads
