08/29 Q/A Session - Commander - Page 6 - JeepForum.com
post #76 of 133 Old 08-29-2007, 04:13 PM
Thunderstrike
Thunderstrike's Avatar
2009 JK Wrangler
Some parts of chassis or underneath are not rust protected. For example, knuckle or parts of drive drain/shaft are bare metal with NO type of paint to protect from rust. Can Jeep start putting rust-resistant paint or coating?
2009 JK Rubicon
Shrockworks Mid-width, Warn 9.5Ti; Skid Row Engine Skid, LCA & Evaporator Skid; Rock Hard Gas Tank Skid; Warn Stainless Steel Diff Skids, 11,000# Pull-Pal. Uniden 520XL CB; 1" Front & 1/2" Coil Spacer Rear; Aeroforce Interceptor, Valentine 1.
Moab - TJ-4/2006, TJ-5/2008, 4/2009, 5/2011, 4/2013, 5/2016, 4/2017
Ouray - TJ-8/2007
Rubicon - TJ-9/2008
Thunderstrike is offline
post #77 of 133 Old 08-29-2007, 04:13 PM Thread Starter
JeepEngineers
JeepEngineers's Avatar
Originally Posted by Sporer65
What was the reasoning behind using the 3.7L V6? I can sorta understand it being used in the WK, but the XK just seems too heavy for the 6 cylinder and with the same gas mileage, it just doesn't make sense to me.
Also, how different is the drag between the WK and XK? It seems like the aerodynamics would take a big hit but if you look at similar models (specifically the GM900 SUVs) they have pretty good drag characteristics.
There's a lot of reasons for offering the 3.7L - naturally CAFE is one of them, as well as offering an affordable base model.
Although I can't quote specific aerodynamic drag value differences between Grand Cherokee and Commander, the more upright windshield and greater frontal area will naturally increase wind resistance. If all cars were designed solely around aero efficiency they wouldn't be much to look at!
JeepEngineers "INTRODUCING THE GREATEST JEEP LINEUP EVER"
JeepEngineers is offline
post #78 of 133 Old 08-29-2007, 04:14 PM Thread Starter
JeepEngineers
Originally Posted by GenoSport
Thanks for the info on the 4wd.
And I think its great that you fixed the issue with the key, My only question about the key issue is can my jeep be retro fitted with this fix. As it is a saftey issue, When we drive it now we make a point not to bump the keychain at all, BTW there are only 3 keys on the key chain, so its not exssive.
Your Jeep can be retrofitted with the new ignition lock housing. Latest part number is 56010568AE.
post #79 of 133 Old 08-29-2007, 04:14 PM
JeepMan1975
What's the reason behind outfitting Commanders with two tone leather or cloth seats? I cringe everytime I see that Yuma leather trim.
JeepMan1975 is offline
post #80 of 133 Old 08-29-2007, 04:15 PM Thread Starter
JeepEngineers
Originally Posted by ginald
Geeky engineering question:
I'm a stress analyst and we use a finite element program called ANSYS. It's real popular in the gas turbine business. I would LOVE to do some work on Jeeps.
What program do you guys use for your stress analysis? Any use for an ANSYS guy?
Actually for quality purposes, we use several different stress analysis programs, not any one specific. As for job opportunities go to http://www.careers.chrysler-group.com/ to access the corporate hiring site.
Thanks for the interest!
post #81 of 133 Old 08-29-2007, 04:15 PM Thread Starter
JeepEngineers
Originally Posted by Kyle Deidrick
also related to the transfercase, are they using a slip yoke as seen on the XJ's 231/242 or have you guys switched to a doublecardon driveshaft for the rear with a fixed yoke?
-Kyle
The rear driveshaft has a single cardan joint at each end with a slip joint in the middle. So both front and rear of the transfer case have a fixed yoke.
post #82 of 133 Old 08-29-2007, 04:15 PM Thread Starter
JeepEngineers
Consumer and styling trends drive many of these decisions.
post #83 of 133 Old 08-29-2007, 04:16 PM
XJK
The Guru of Nothing
XJK's Avatar
humm, so how does the single cardon joint perform when lifting the vehical? it seems to me that the vibrations would still be present.
-Kyle
It's Not Just a Jeep, It's a Lifestyle
XJK is offline
post #84 of 133 Old 08-29-2007, 04:17 PM
badfish488
why is the commander offered in 4x2? No jeep should have ever been offered in 4x2, now we the whole jeep lineup available in 4x2 and the wrangler of all cars is offered in 2 wheel drive Whats happening to Jeep?
badfish488 is offline
post #85 of 133 Old 08-29-2007, 04:18 PM Thread Starter
JeepEngineers
We're always looking for new ways to satisfy our customers and improve our product. Thank you for the suggestion. Keep them coming.
post #86 of 133 Old 08-29-2007, 04:19 PM Thread Starter
JeepEngineers
There have been many Jeeps offered in the past with 2wd - the Jeepster is but one example. What we're all about is choice. Many consumers dont want or need 4WD and without a 2wd option, they wouldn't consider buying from us.
post #87 of 133 Old 08-29-2007, 04:23 PM Thread Starter
JeepEngineers
-Kyle
Of course we don't endorse lifting a vehicle...
But, the rear driveshaft is reasonably long and we have had several modified show vehicles and have been 'wheeled all over the country without driveshaft modifications.
post #88 of 133 Old 08-29-2007, 04:25 PM Thread Starter
JeepEngineers
Originally Posted by rob92xj
Don't you still have to initallize the trailer brake light relays with the STAR SCAN?
On a Jeep (WK/XK) equipped with factory installed trailer tow, the relays in the front control module are already initialized in the plant. When installing an aftermarket Electric Trailer brake controller, you do not need to initialize anything with a Star Scan. The electric trailer brake controller is a module in itself and sends out an electronic signal to the trailer brakes based on vehicle brake switch input.
post #89 of 133 Old 08-29-2007, 04:25 PM
ginald
Do all of you guys / gals drive Jeeps?
ginald is offline
post #90 of 133 Old 08-29-2007, 04:26 PM Thread Starter
JeepEngineers
Got myself a nice TJ Sahara....can't speak for the rest of us....
Closed Thread
7/29 Q/A Session - 2007-2008 MK JeepEngineers Jeep Engineering - Q&A Archive 108 07-29-2008 05:03 PM
05/13 Q/A Session - Jeep Commander JeepEngineers Jeep Engineering - Q&A Archive 92 05-13-2008 05:10 PM
10/24 Q/A Session - Grand Cherokee JeepEngineers Jeep Engineering - Q&A Archive 123 11-03-2007 12:30 PM
04/18 Q/A session - 2007 Liberty JeepEngineers Jeep Engineering - Q&A Archive 174 04-18-2007 05:14 PM
03/14 Q/A session - 2007 Wrangler JeepEngineers Jeep Engineering - Q&A Archive 329 03-22-2007 06:58 PM
You may not post new threads
