08/29 Q/A Session - Commander - Page 5 - JeepForum.com
post #61 of 133 Old 08-29-2007, 04:59 PM
XJK
The Guru of Nothing
XJK's Avatar
Originally Posted by JeepEngineers
We do offer the Wrangler and Wrangler Unlimited, don't forget.
ya that is true, the wrangler is nice but the unlimited just isnt my cup of tea
-Kyle
It's Not Just a Jeep, It's a Lifestyle
XJK is offline
post #62 of 133 Old 08-29-2007, 05:01 PM Thread Starter
JeepEngineers
JeepEngineers's Avatar
Originally Posted by Crashnburn80
Like the 4 door JK.
What he said!
JeepEngineers "INTRODUCING THE GREATEST JEEP LINEUP EVER"
JeepEngineers is offline
post #63 of 133 Old 08-29-2007, 05:01 PM
solarpower
I want to thank you guys for designing a Jeep with enough power/size to tow my Rubicon, yet keeps my wifes "cushy areas" heated in the winter. We absolutely love the ride quality on road, but I can't take it off-road.
I wish I had something good to ask, but the brake controller thing gave me an answer.
Ask the guy a cubicle over (the TJ engineer) about the fill plug clearance with the locker actuator on a Rubicon rear D-44. I measured it at less than .125 in with 15 lbs of torque.
Anyway thanks again, I will be towing the Rubi to IN this weekend, and my family of 4 are going to enjoy the ride there and back just slightly less than playing on rocks.
04 TJ "U" package
06 XK Commaddy 4.7
solarpower is offline
post #64 of 133 Old 08-29-2007, 05:03 PM
schitzangiggles
King of Macastan
schitzangiggles's Avatar
What is the largest tire size that can be fitted with out a lift?
"Axeheads are supposed to be sharp, but you are one blunt tool."
FLynes
If you love wealth more than liberty,the tranquility of servitude more than the animating contest of freedom, go home from us in peace. We seek not your counsel nor your arms. Crouch down and lick the hand that feeds you. May your chains sit lightly on your shoulders and may posterity forget that you were our countrymen.
-Samual Adams
A government big enough to give you everything you want is big enough to take everything you have.
Thomas Jefferson
Calling Illegal Aliens "Undocumented Immigrants" is like calling drug dealers "Unlicensed Pharmacists"
Nemo Me Impune Lacessit
"No one provokes (attacks) me with impunity".
"Your right, the Tea Party and the OWS are the same, just like the America Revolution and the French Revolution were the same. The only problem is the American Revolution ended with Liberty, Freedom, Justice for all and a shining light upon a hill. The French Revolution ended with lynchings, guillotines, murder and socialism. So yeah, I could see how one could confuse the two..."
Mac Wilson
schitzangiggles is offline
post #65 of 133 Old 08-29-2007, 05:03 PM Thread Starter
JeepEngineers
Originally Posted by HeavyMetal
what kind of transmission gearing is there (1st gear) across the various engines?
The 3.7L has a 3.59 first gear and the 4.7L/5.7L have a 3.0 first gear.
post #66 of 133 Old 08-29-2007, 05:03 PM
Oman Jeep
Oman Jeep's Avatar
First off, I hope I understand your question correctly. If my answer sounds far off of what you're looking for, please reply back.
Jeep Grand Cherokee and Commander have used CAN bus radios since 2005 MY. The Navigation radio (REJ) is used in 2005 - 2007MY and the new My GIG Navigation radio (RER) is used in 2008 MY. Both of these radios have the ability to mute Navigation feed back. The REJ radio provides a hard key mute button that mutes both radio and navigation. The RER allows you to mute the navigation using the system setup for audible feedback.
Hope this is on target for what you're looking for.
Keep on Jeepin
Thanks for taking the time to respond but what I'm actually looking at is integrating aftermarket Bluetooth and Aftermarket Navigation with the factory head unit.
For example, other manufacturers have a "Mute" wire or at least a mute terminal on the head unit if the wire does not exist.
We've been unable to find this on the JK and I was wondering if we would be able to find this on the Commanders.
Oman Jeep is offline
post #67 of 133 Old 08-29-2007, 05:04 PM Thread Starter
JeepEngineers
Originally Posted by schitzangiggles
Will adding a lift void the lifetime warranty?
Any damages to your Jeep that take place as a result of work performed anywhere other than an authorized Jeep Service Center using aftermarket parts will not be covered under your warranty.
post #68 of 133 Old 08-29-2007, 05:05 PM
schitzangiggles
King of Macastan
So if I am doing the things seen in the commercials, I will be ok as far as the warranty goes then?
FLynes
-Samual Adams
Thomas Jefferson
Mac Wilson
post #69 of 133 Old 08-29-2007, 05:06 PM
HeavyMetal
Forum God
HeavyMetal's Avatar
1997 XJ Cherokee
ok 1 more gearing question i promise, i keep forgetting one detail and cant edit my posts in here for some reason
what transfercase gearing is available? (trying to find a crawl ratio here )
are there multiple t-cases offered for the commander? or is it 1 common one across the board
Though I wheel through the valley of the shadow of death,
I will fear no evil: For thou lockers are with me;
Thy lift and thy tires, they comfort me.
Thou preparest a spotter before me in the presence of mine obstacles;
HeavyMetal is offline
post #70 of 133 Old 08-29-2007, 05:08 PM
rob92xj
1992 XJ Cherokee
Unfortunately, there is not a factory installed electronic brake controller connector. There are two pig-tail wires (brake switch input and output to trailer lights) in the harness under the dash that you can use instead of cutting into a harness. (look left of the brake switch). Mopar part number 82210512 is a wiring harness jumper that you can plug into the back of your front power outlet to power up your controller and it has the standard blue connector for e/e trailer brake. Basically, plug in the jumper (right power outlet), there are two spare wires on the jumper and those connect to the dash harness. Follow the color scheme and all should go well.
Good luck
Don't you still have to initallize the trailer brake light relays with the STAR SCAN?
rob92xj is offline
post #71 of 133 Old 08-29-2007, 05:08 PM Thread Starter
JeepEngineers
You think that clearance is tight - that's nothing!
post #72 of 133 Old 08-29-2007, 05:08 PM Thread Starter
JeepEngineers
No, you cannot drive your Commander under the ocean.
Obviously, some of our commercials are dramatizations.
post #73 of 133 Old 08-29-2007, 05:09 PM
Sporer65
Sporer65's Avatar
Location: Powder Springs, Georgia/University of Tennessee
What was the reasoning behind using the 3.7L V6? I can sorta understand it being used in the WK, but the XK just seems too heavy for the 6 cylinder and with the same gas mileage, it just doesn't make sense to me.
Also, how different is the drag between the WK and XK? It seems like the aerodynamics would take a big hit but if you look at similar models (specifically the GM900 SUVs) they have pretty good drag characteristics.
Ben
1993 Jeep Grand Wagoneer ZJ V8: Rear Aussie, 3.5" Lift, 31" M/Ts
Sporer65 is offline
post #74 of 133 Old 08-29-2007, 05:10 PM
XJK
The Guru of Nothing
XJK's Avatar
also related to the transfercase, are they using a slip yoke as seen on the XJ's 231/242 or have you guys switched to a doublecardon driveshaft for the rear with a fixed yoke?
-Kyle
XJK is offline
post #75 of 133 Old 08-29-2007, 05:13 PM Thread Starter
JeepEngineers
Transfer case low range ratio is 2.72 for the NV245. The NV140 is a single speed transfer case.
Closed Thread
7/29 Q/A Session - 2007-2008 MK JeepEngineers Jeep Engineering - Q&A Archive 108 07-29-2008 06:03 PM
05/13 Q/A Session - Jeep Commander JeepEngineers Jeep Engineering - Q&A Archive 92 05-13-2008 06:10 PM
10/24 Q/A Session - Grand Cherokee JeepEngineers Jeep Engineering - Q&A Archive 123 11-03-2007 01:30 PM
04/18 Q/A session - 2007 Liberty JeepEngineers Jeep Engineering - Q&A Archive 174 04-18-2007 06:14 PM
03/14 Q/A session - 2007 Wrangler JeepEngineers Jeep Engineering - Q&A Archive 329 03-22-2007 07:58 PM
You may not post new threads
