08/29 Q/A Session - Commander - Page 4 - JeepForum.com
post #46 of 133 Old 08-29-2007, 04:47 PM
Crashnburn80
Crashnburn80's Avatar
The multispeed overdrive automatic 545RFE 5spd transmission has an "alternate 2nd gear for smoother downshifting at higher speeds." So is this really a 6spd auto that selects which '2nd' gear to use based on speed/load?
Seems like an interesting approach, but why not just call it a 6spd, distribute the ratios a little more evenly and have it select 2nd or 3rd based on need (vs 2nd or alternate 2nd)?
| 1.25" BL |
| Riddler diff covers |
| 33" MTRs | Warn M8000 |
and much more...
Crashnburn80 is offline
post #47 of 133 Old 08-29-2007, 04:48 PM
GenoSport
Originally Posted by JeepEngineers
Sorry to hear the problems with your Jeep. Unfortunately I don't have the history of your vehicle to perform a specific root cause. Some things that I can recommend off the record: There is a final drive control module software reflash that was made available to our customers a couple months ago (part number ending in AM). This reflash helps eliminate false failures. Second, check the connector going into your transfer case. Look to see if any corrosion is built up on your terminals. If so have your dealer clean it out and reseal it.
Regarding your key issue. We've recognized our customers concerns and Jeep has made a design change requiring more force to move the key to the off position. The change was implemented late 2007 model year.
Thanks for your comments. Hope this information helps.
Keep JEEP'n
Thanks for the info on the 4wd.
And I think its great that you fixed the issue with the key, My only question about the key issue is can my jeep be retro fitted with this fix. As it is a saftey issue, When we drive it now we make a point not to bump the keychain at all, BTW there are only 3 keys on the key chain, so its not exssive.
White 03 TJ
Green 06 XK
GenoSport is offline
post #48 of 133 Old 08-29-2007, 04:48 PM
XJK
The Guru of Nothing
XJK's Avatar
besides the "comfort" factor what was (if there was a reason) for doing away with the solid front axle? Im sure some of your vehicals would have a lot more support if you brought back a solid axle at least as an option.
-Kyle
It's Not Just a Jeep, It's a Lifestyle
XJK is offline
post #49 of 133 Old 08-29-2007, 04:50 PM
creature
creature's Avatar
Which engine are you referring to?
oops, I didn't think that one all the way through
What kind of ignition system is in the 5.7 hemi commander?
-Shawn
creature is offline
post #50 of 133 Old 08-29-2007, 04:51 PM
Crookster777
2015 WK
What are you guys doing about the hemi shudder/tick?
HEMI CLUB #1
2016 Hellcat Charger
SOLD: 2015 WK2 SRT
SOLD: 2010 WK1 SRT
Crookster777 is offline
post #51 of 133 Old 08-29-2007, 04:53 PM Thread Starter
JeepEngineers
JeepEngineers's Avatar
-Kyle
Competitive forces drive everything in this industry. In order to achieve competitive levels of ride and handling, we had to change to IFS. Unfortunately, offering both configurations would entail too many design compromises and neither setup would be as good as it could be.
JeepEngineers "INTRODUCING THE GREATEST JEEP LINEUP EVER"
JeepEngineers is offline
post #52 of 133 Old 08-29-2007, 04:53 PM Thread Starter
JeepEngineers
The ignition system on the 5.7L Hemi is distributorless, with a separate coil for each cylinder. (COP - Coil On Plug). The system is controlled by the NGC, powertrain control module.
post #53 of 133 Old 08-29-2007, 04:54 PM
schitzangiggles
King of Macastan
schitzangiggles's Avatar
Will adding a lift void the lifetime warranty?
"Axeheads are supposed to be sharp, but you are one blunt tool."
FLynes
If you love wealth more than liberty,the tranquility of servitude more than the animating contest of freedom, go home from us in peace. We seek not your counsel nor your arms. Crouch down and lick the hand that feeds you. May your chains sit lightly on your shoulders and may posterity forget that you were our countrymen.
-Samual Adams
A government big enough to give you everything you want is big enough to take everything you have.
Thomas Jefferson
Calling Illegal Aliens "Undocumented Immigrants" is like calling drug dealers "Unlicensed Pharmacists"
Nemo Me Impune Lacessit
"No one provokes (attacks) me with impunity".
"Your right, the Tea Party and the OWS are the same, just like the America Revolution and the French Revolution were the same. The only problem is the American Revolution ended with Liberty, Freedom, Justice for all and a shining light upon a hill. The French Revolution ended with lynchings, guillotines, murder and socialism. So yeah, I could see how one could confuse the two..."
Mac Wilson
schitzangiggles is offline
post #54 of 133 Old 08-29-2007, 04:55 PM Thread Starter
JeepEngineers
Originally Posted by HeavyMetal
is this 8.25 found in the commander a beefed up version of the one found in the cherokees of old? whether that be housing-wise or shaft-wise or whatever-wise
width between wheel mounting surfaces, any input in inches?
It is a similar ring and pinion size. The ring gear bolts are larger, the axle housing is stiffer, and the axle tubes are also larger. The 8.25 in the Commander is a full floating design - that means that the axle shaft does not carry the weight of the vehicle. The ELSD model has stronger side gears and differential case and has enough torque capacity to act as a locker.
I believe the wheel mounting surface is approximately 65.9".
Hope that answers it!
post #55 of 133 Old 08-29-2007, 04:55 PM
XJK
The Guru of Nothing
XJK's Avatar
Have you guys thought about or been considering bringing back a solid front axle SUV? dont know if you can say that, it may be "future thinking"
-Kyle
XJK is offline
post #56 of 133 Old 08-29-2007, 04:57 PM Thread Starter
JeepEngineers
Could you be more specific? The Hemi has a canted valve arrangement and these are typically noisier than inline valves due to the forces involved, you have both up and down movment and a certain degree of side loading, and the result is a certain amount of noise. Rest assured it will not result in a durability issue.
post #57 of 133 Old 08-29-2007, 04:58 PM Thread Starter
JeepEngineers
-Kyle
We do offer the Wrangler and Wrangler Unlimited, don't forget.
post #58 of 133 Old 08-29-2007, 04:58 PM
HeavyMetal
Forum God
HeavyMetal's Avatar
1997 XJ Cherokee
Sure does, that actually sounds pretty cool. As far as spline-age in the axle shafts, 29 spliners? or different?
Though I wheel through the valley of the shadow of death,
I will fear no evil: For thou lockers are with me;
Thy lift and thy tires, they comfort me.
Thou preparest a spotter before me in the presence of mine obstacles;
HeavyMetal is offline
post #59 of 133 Old 08-29-2007, 04:59 PM Thread Starter
JeepEngineers
Another question... CAN Bus head units... does Jeep provide a way to mute them? I have a mute output from my Navigation System and my Bluetooth hands free system. I know people have difficulty in the JK Wrangler, is the Commander the same and is there a solution?
First off, I hope I understand your question correctly. If my answer sounds far off of what you're looking for, please reply back.
Jeep Grand Cherokee and Commander have used CAN bus radios since 2005 MY. The Navigation radio (REJ) is used in 2005 - 2007MY and the new My GIG Navigation radio (RER) is used in 2008 MY. Both of these radios have the ability to mute Navigation feed back. The REJ radio provides a hard key mute button that mutes both radio and navigation. The RER allows you to mute the navigation using the system setup for audible feedback.
Hope this is on target for what you're looking for.
Keep on Jeepin
post #60 of 133 Old 08-29-2007, 04:59 PM
Crashnburn80
-Kyle
Like the 4 door JK.
| 1.25" BL |
and much more...
Closed Thread
7/29 Q/A Session - 2007-2008 MK JeepEngineers Jeep Engineering - Q&A Archive 108 07-29-2008 06:03 PM
05/13 Q/A Session - Jeep Commander JeepEngineers Jeep Engineering - Q&A Archive 92 05-13-2008 06:10 PM
10/24 Q/A Session - Grand Cherokee JeepEngineers Jeep Engineering - Q&A Archive 123 11-03-2007 01:30 PM
04/18 Q/A session - 2007 Liberty JeepEngineers Jeep Engineering - Q&A Archive 174 04-18-2007 06:14 PM
03/14 Q/A session - 2007 Wrangler JeepEngineers Jeep Engineering - Q&A Archive 329 03-22-2007 07:58 PM
You may not post new threads
