08/29 Q/A Session - Commander - Page 3 - JeepForum.com
Closed Thread
post #31 of 133 Old 08-29-2007, 03:35 PM
Oman Jeep
Oman Jeep's Avatar
Is there a possibility of the Liberty's Sky Slider Roof appearing on other models like the Cherokee.
Continuing the open air themes, has Jeep explored a roll down window instead of the lift up glass on the tailgate...
Oman Jeep is offline
post #32 of 133 Old 08-29-2007, 03:35 PM
ginald
Geeky engineering question:
I'm a stress analyst and we use a finite element program called ANSYS. It's real popular in the gas turbine business. I would LOVE to do some work on Jeeps.
What program do you guys use for your stress analysis? Any use for an ANSYS guy?
ginald is offline
post #33 of 133 Old 08-29-2007, 03:37 PM Thread Starter
JeepEngineers
JeepEngineers's Avatar
Well, as usual we can't comment on future products but keep the suggestions coming!
JeepEngineers "INTRODUCING THE GREATEST JEEP LINEUP EVER"
JeepEngineers is offline
post #34 of 133 Old 08-29-2007, 03:37 PM
Oman Jeep
Oman Jeep's Avatar
Sorry, it's late here, I meant to write other models like the Commander!
post #35 of 133 Old 08-29-2007, 03:38 PM Thread Starter
JeepEngineers
Gotcha.....
post #36 of 133 Old 08-29-2007, 03:39 PM
Oman Jeep
Oman Jeep's Avatar
Another question... CAN Bus head units... does Jeep provide a way to mute them? I have a mute output from my Navigation System and my Bluetooth hands free system. I know people have difficulty in the JK Wrangler, is the Commander the same and is there a solution?
post #37 of 133 Old 08-29-2007, 03:41 PM
creature
creature's Avatar
what kind of ignition system is in the commander?
-Shawn
creature is offline
post #38 of 133 Old 08-29-2007, 03:42 PM
Rossta
Rossta's Avatar
As engineers of the Commander, what feature(s) are you most proud of? or what part do you stand back and say "Hey, I really like how we did that!"
Does that make sense?
Rossta is offline
post #39 of 133 Old 08-29-2007, 03:42 PM
PeteC
Isn't it nice to say you work for "CHRYSLER" again? I know i like saying it.
Anyway, there is a problem with the Tire Pressure Monitor light coming on at random times. Has there been a solution implemented yet? I would like to see this fixed before I get my '08 vehicle.
It's funny, I have the name of my contacts when it went into the hands of the engineers back in November, but I never think about sending an e-mail. Well, now I thought of it.
'00 TJ With toys, lift and tires.
'10 Dodge Ram 1500 Quad 4x4. Daily driver and tow rig
'05 Dodge Neon. Wifes daily driver and gas sipper.
There is no Bandaid for Stupidity
Sorry if my support of legal wheeling offends you
PeteC is offline
post #40 of 133 Old 08-29-2007, 03:42 PM Thread Starter
JeepEngineers
Which engine are you referring to?
post #41 of 133 Old 08-29-2007, 03:43 PM Thread Starter
JeepEngineers
Originally Posted by GenoSport
we bought one of the first commanders when they came out we have had an issue that is driving me nuts the service, 4wd light will come on and stay on until the commander is turned off then when we restart it the light is out.
We have taken it into the dealer 5 times with the light on and off the jeep has not pulled any codes at all, for any of the times we have taken it in. But every time we restart it the light goes out.
This has happened a total of about 8 times and is very random.
The jeep is a 06 commander 65th anv green with the 4.7 and Quadra Track II system. Other then this issue and the sensitive ing key turning off the jeep on the highway We love the commander
Sorry to hear the problems with your Jeep. Unfortunately I don't have the history of your vehicle to perform a specific root cause. Some things that I can recommend off the record: There is a final drive control module software reflash that was made available to our customers a couple months ago (part number ending in AM). This reflash helps eliminate false failures. Second, check the connector going into your transfer case. Look to see if any corrosion is built up on your terminals. If so have your dealer clean it out and reseal it.
Regarding your key issue. We've recognized our customers concerns and Jeep has made a design change requiring more force to move the key to the off position. The change was implemented late 2007 model year.
Thanks for your comments. Hope this information helps.
Keep JEEP'n
post #42 of 133 Old 08-29-2007, 03:43 PM
JeepMan1975
When I went to order my JK, there was one very nice 4x4 Jeep Commander that was being sold with a factory lift on it.
I wanted to know more about the lift, but the dealership only said that it was a factory lift. Can you share some insight about what kind of lift is available either from the factory or through the Jeep parts department and what size wheel/tire combo can be fitted without having to do extensive modifications to the driveline equipment?
Thanks in advance and thanks again for being here.
JeepMan1975 is offline
post #43 of 133 Old 08-29-2007, 03:45 PM Thread Starter
JeepEngineers
There are no factory lifts offered at this time. Unfortunately your dealer was incorrect. There are a number of aftermarket alternatives, but naturally we can't endorse any of them for legal reasons.
post #44 of 133 Old 08-29-2007, 03:47 PM Thread Starter
JeepEngineers
Do you have a premium Tire pressure system in your '07 (you can read the pressures in the cluster)?
As far as 2008, the Tire pressure system has changed, so you will not see the exact same issues between the two model years.
post #45 of 133 Old 08-29-2007, 03:47 PM
HeavyMetal
Forum God
HeavyMetal's Avatar
1997 XJ Cherokee
what kind of transmission gearing is there (1st gear) across the various engines?
Though I wheel through the valley of the shadow of death,
I will fear no evil: For thou lockers are with me;
Thy lift and thy tires, they comfort me.
Thou preparest a spotter before me in the presence of mine obstacles;
HeavyMetal is offline
Closed Thread
7/29 Q/A Session - 2007-2008 MK JeepEngineers Jeep Engineering - Q&A Archive 108 07-29-2008 05:03 PM
05/13 Q/A Session - Jeep Commander JeepEngineers Jeep Engineering - Q&A Archive 92 05-13-2008 05:10 PM
10/24 Q/A Session - Grand Cherokee JeepEngineers Jeep Engineering - Q&A Archive 123 11-03-2007 12:30 PM
04/18 Q/A session - 2007 Liberty JeepEngineers Jeep Engineering - Q&A Archive 174 04-18-2007 05:14 PM
03/14 Q/A session - 2007 Wrangler JeepEngineers Jeep Engineering - Q&A Archive 329 03-22-2007 06:58 PM
You may not post new threads
