08/29 Q/A Session - Commander - Page 2 - JeepForum.com
Closed Thread
post #16 of 133 Old 08-29-2007, 04:22 PM Thread Starter
JeepEngineers
JeepEngineers's Avatar
Originally Posted by tube yj
What is the tow rating for the commander?
It varies with engine and axle ratio of course. There's a handy little tool on the jeep website that can help you determine your tow capacity based on your vehicle's configuration.
Click here and all will be revealed:
http://www.jeep.com/vehsuite/TowingGuide.jsp
JeepEngineers "INTRODUCING THE GREATEST JEEP® LINEUP EVER"
JeepEngineers is offline
post #17 of 133 Old 08-29-2007, 04:23 PM
BeachinXJ
Resident McGeek
BeachinXJ's Avatar
Does the commander come prewired with an under dash hookup for a trailer brake controller? (Like a truck for instance).
- Chopped / Locked
- Daily Driver
2003 Dodge Ram 2500 CTD - 6-speed, 4" MBRP Turbo Back Exhaust
Rule #1 - No talking about the weather!
BeachinXJ is offline
post #18 of 133 Old 08-29-2007, 04:23 PM Thread Starter
JeepEngineers
Originally Posted by bfr
Do the different HVAC systems (auto vs manual)have unique ducting/doors or is the primary difference the controllers themselves?
The difference between the (2) systems is the control heads. The HVAC unit (ducting and doors) is identical.
post #19 of 133 Old 08-29-2007, 04:23 PM Thread Starter
JeepEngineers
Originally Posted by HeavyMetal
What rear axle is in the back of this thing anyway? always wondered that randomly (and gear ratio)
All 4x4 Commanders have a Chrysler Corporate C213R rear axle also known as the 8 1/4" (the front axle is a Chrysler Corporate C200F). 213 is the ring gear diameter in mm and the front is 200 mm - that's actually about 8 3/8" for the rear and 7 7/8" for the front.
The 3.7L was available with 3.07 axles with the single speed transfer case and with 4x2 and with 3.55 axles with the 2-speed transfer case.
The 4.7L/5.7L all have 3.73 axles.
post #20 of 133 Old 08-29-2007, 04:24 PM
dawnskaybug
dawnskaybug's Avatar
Any significant changes or price increases for 08?
05 LJ
RE 4.5 SA 1inch BL
Aussie front Detroit rear 4.88s
1200 series Tractor tires (37x10)
Warn winch stinger
Lotsa trail damage
dawnskaybug is offline
post #21 of 133 Old 08-29-2007, 04:25 PM
HeavyMetal
Forum God
HeavyMetal's Avatar
1997 XJ Cherokee
is this 8.25 found in the commander a beefed up version of the one found in the cherokees of old? whether that be housing-wise or shaft-wise or whatever-wise
width between wheel mounting surfaces, any input in inches?
Though I wheel through the valley of the shadow of death,
I will fear no evil: For thou lockers are with me;
Thy lift and thy tires, they comfort me.
Thou preparest a spotter before me in the presence of mine obstacles;
HeavyMetal is offline
post #22 of 133 Old 08-29-2007, 04:26 PM
ginald
Originally Posted by JeepEngineers
With any new Jeep vehicle, we look at our heritage and use cues that we think represent the brand and fit that particular vehicle. Note though that the Commander is much larger than the Cherokee and features 3 rows of seating, something the Cherokee never offered, so of course it was not intended to be a direct replacement.
First off, thanks for being here and for being willing to answer all these questions.
I had a similar question in mind. The question I had was more along the lines of styling. I couldn't help notice how much the Commander looked like an XJ on steroids. Was the styling of the Commander intentionally trying to make it look like an XJ?
Thanks again!
ginald is offline
post #23 of 133 Old 08-29-2007, 04:27 PM Thread Starter
JeepEngineers
Can't comment on pricing, but there are many improvements to the instrument panel that are similar to the changes made on the 2008 Grand Cherokee. Stay tuned!
post #24 of 133 Old 08-29-2007, 04:28 PM
ArloGuthroJeep
Mr. Hyde!
ArloGuthroJeep's Avatar
Does the Commander for non-US markets come with a different axle front and rear and if so, which axles?
'14 WK2 Limited w/5.7L, ORAI, & Tow Package
ArloGuthroJeep is offline
post #25 of 133 Old 08-29-2007, 04:28 PM Thread Starter
JeepEngineers
If an hvac controller is replaced does it need to be connected to a dealer computer to make the jeep recognize the new one?
No. As long as the controller is of the same type originally equipped in the vehicle. (Example: Manual control head with another manual control head.) An automatic control head will not work in a vehicle originally equipped with a manual head.
post #26 of 133 Old 08-29-2007, 04:28 PM
GenoSport
we bought one of the first commanders when they came out we have had an issue that is driving me nuts the service, 4wd light will come on and stay on until the commander is turned off then when we restart it the light is out.
We have taken it into the dealer 5 times with the light on and off the jeep has not pulled any codes at all, for any of the times we have taken it in. But every time we restart it the light goes out.
This has happened a total of about 8 times and is very random.
The jeep is a 06 commander 65th anv green with the 4.7 and Quadra Track II system. Other then this issue and the sensitive ing key turning off the jeep on the highway We love the commander
White 03 TJ
Green 06 XK
GenoSport is offline
post #27 of 133 Old 08-29-2007, 04:29 PM Thread Starter
JeepEngineers
Thanks again!
Well, the XJ was clearly a winner for Jeep and sold well around the world. Naturally we look to draw inspiration from some of our most beloved vehicles when coming up with new ones.
post #28 of 133 Old 08-29-2007, 04:31 PM Thread Starter
JeepEngineers
No factory install, but easy to do yourself.
Unfortunately, there is not a factory installed electronic brake controller connector. There are two pig-tail wires (brake switch input and output to trailer lights) in the harness under the dash that you can use instead of cutting into a harness. (look left of the brake switch). Mopar part number 82210512 is a wiring harness jumper that you can plug into the back of your front power outlet to power up your controller and it has the standard blue connector for e/e trailer brake. Basically, plug in the jumper (right power outlet), there are two spare wires on the jumper and those connect to the dash harness. Follow the color scheme and all should go well.
Good luck
post #29 of 133 Old 08-29-2007, 04:31 PM Thread Starter
JeepEngineers
The axles and axle ratios for the export Commanders are identical to the domestic offerings.
post #30 of 133 Old 08-29-2007, 04:34 PM Thread Starter
JeepEngineers
Originally Posted by JBassXJ
I'm not knowledgeable at all about the commander but is their a factory "non-stock" suspension lift that is offered with a certain package? (comparble to rubi TJ's and/or "going back" up-country xj's)
Also I think it's awesome you peeps come on here w/these Q/A's. Rock on!
There is no up-country suspension package available on Commanders (actually the Rubicon TJ/JK do not have any suspension lift over a standard TJ/JK).
Keep asking for it though - we'd love to offer it if there is enough demand for it!
Closed Thread
7/29 Q/A Session - 2007-2008 MK JeepEngineers Jeep Engineering - Q&A Archive 108 07-29-2008 06:03 PM
05/13 Q/A Session - Jeep Commander JeepEngineers Jeep Engineering - Q&A Archive 92 05-13-2008 06:10 PM
10/24 Q/A Session - Grand Cherokee JeepEngineers Jeep Engineering - Q&A Archive 123 11-03-2007 01:30 PM
04/18 Q/A session - 2007 Liberty JeepEngineers Jeep Engineering - Q&A Archive 174 04-18-2007 06:14 PM
03/14 Q/A session - 2007 Wrangler JeepEngineers Jeep Engineering - Q&A Archive 329 03-22-2007 07:58 PM
You may not post new threads
