#76 | ||
#77 | |
The most likely cause of the TJ Rubicon lockers not locking was the air hose being pulled off. The new JK lockers have avoided this by getting rid of the need for air lines at all. The air pumps that were mounted to the TJ skid plate have been removed and replaced by an electromagetic coil installed directly in the axle. The lock mechanism is beefed up too to account for the larger tires.
[FONT="Arial Black"][SIZE="4"]JeepEngineers[/SIZE][/FONT] "INTRODUCING THE GREATEST JEEP[SIZE="1"]®[/SIZE] LINEUP EVER" [I][URL="http://www.jeep.com/"]http://www.jeep.com/[/URL] [URL="http://www.jeep.com/en/experience/community/have_fun_out_there/"]Have Fun Out There![/URL] [URL="http://www.facebook.com/jeep"]Check out Jeep on Facebook[/URL] [URL="http://www.youtube.com/thejeepchannel"]Check out Jeep on YouTube[/URL] [URL="http://www.flickr.com/groups/jeepexperience/"]Check out Jeep on Flickr[/URL][/I] |
#78 | |
One more question- what kind of electrical connections does the JK systems have with T-case? Is it only an information about being in 4lo or what? I would like to know how hard rewiring it would be
POLISH JEEP OWNERS CLUB #11 Anyway, nothing will beat Suzuki :D |
#79 |
Cut to Fit-Paint to Match
Hello, and thank you for taking the time.
I just bought an '05 TJ. It has the D35 rear axle with 3.07 gearing. I'm think of lifting it a little and putting 33" tires on it. Many folks have varying opinions here about the D35, but most warn me about breakage with tires of that size and advise of the need for a regear to 4.10 or 4.56. What advice can you give me on this subject?
We save dogs: http://www.secondchanceshepherds.org/ |
#80 | |
Tires would be the only part to influence lift. There is no suspension height difference.
#81 |
Future suggestions:
Make the mirrors mounted to the body not the doors. Put in a door defeat switch standard. Use a flat Transfer Case skid or at least one that does not hang down 4" and gets nicknamed "The shovel" Have the transfer case shifter linkage attached to the transfer case and not the body. Have a full roll cage built in to every model. The paint on my 05 is horrible, for as much as these cost new can you spend a little more for some tougher paint on. (many have complained about this on the newer models) Some of these might have been addressed in the JK and I applaud you for that. I love my LJ, so glad to have the extra room and towing. Thanks again for your time designing our jeeps and the time answering our questions on here. <-- not while your designing. (probably how that shovel got over looked) |
#82 | |
Welcome to my midlife crisis. ;) '89 YJ Wrangler, 4.2L, MC2100 Nutted Carburator |
#83 | |
The stock alternator is rated at 160 amps on a 2008 Rubicon.
I would assume the vehcile running all electronics could not draw more than 70 amps or 80 amps at most. Correct? I would think I have the headroom with a stock alternator to draw an additional 60 amps...no? Quote:
#84 | |
#85 | |
#86 | |
[FONT="Arial Black"][SIZE="4"]JeepEngineers[/SIZE][/FONT] "INTRODUCING THE GREATEST JEEP[SIZE="1"]®[/SIZE] LINEUP EVER" [I][URL="http://www.jeep.com/"]http://www.jeep.com/[/URL] [URL="http://www.jeep.com/en/experience/community/have_fun_out_there/"]Have Fun Out There![/URL] [URL="http://www.facebook.com/jeep"]Check out Jeep on Facebook[/URL] [URL="http://www.youtube.com/thejeepchannel"]Check out Jeep on YouTube[/URL] [URL="http://www.flickr.com/groups/jeepexperience/"]Check out Jeep on Flickr[/URL][/I] Last edited by JeepEngineers; 07-12-2007 at 05:26 PM.. |
#87 | |
The rear locker axle has 32 splines. The open and Trac-Lok axles have 30 splines. The model 30 front axle will have 27 splines, while the Rubicon front axle will have 30 splines.
#88 | |
#89 |
Any chance on getting a "how-to" video for lowering the soft-top on the four door?I broke the two front plastic knuckles when lowering the last section.Thanks again.
#90 | |
I know many have done it with sucess, but drive with a light foot !! Bigger is better when it comes to axles Have fun !
| Thread Tools | |
Previous Thread
Next Thread
| Suggested Threads |
