07-12-2007, 03:21 PM
#61
makes me feel better about building the jeep for this and not having a frame built
thanks
do you think 4500 is realistic
07-12-2007, 03:22 PM
#62
Originally Posted by rlabbott
HI. Love the JK... 5th Jeep in family!
Having the 'gym shoe squeak' after while letting out clutch, or even by hitting the accelerator some. Many have had it I see on this forum. Mine may be getting worse at 3K.
Any progress on that one? My plan is to ignore until I see a TSB or other good advice.
Thanks!
All I can say is, stay tuned.
[FONT="Arial Black"][SIZE="4"]JeepEngineers[/SIZE][/FONT] "INTRODUCING THE GREATEST JEEP[SIZE="1"]®[/SIZE] LINEUP EVER"
[I][URL="http://www.jeep.com/"]http://www.jeep.com/[/URL]
[URL="http://www.jeep.com/en/experience/community/have_fun_out_there/"]Have Fun Out There![/URL]
[URL="http://www.facebook.com/jeep"]Check out Jeep on Facebook[/URL]
[URL="http://www.youtube.com/thejeepchannel"]Check out Jeep on YouTube[/URL]
[URL="http://www.flickr.com/groups/jeepexperience/"]Check out Jeep on Flickr[/URL][/I]
#63
Originally Posted by JLH
Suggestions – Not seeking future model info, just making a few constructive suggestions.
I understand that the economics of producing a vehicle may not allow for a lot of these suggestions to be implemented, but your due consideration would be greatly appreciated.
I have talked with a few guys that have re-geared to 4.88 or 5.13 gears. To summarize, the automatic guys tell me they picked up 2 – 3 MPG with 4.88 gears and stock 32” tires. The manual guys tell me MPG is about the same, but drivability is much improved. Automatic guys tell me 4.88 gears are good for up to 33.5” tall tire. Taller than 33.5” really needs the 5.13 gears. Manual guys say they can run up to 35” tires with 4.88 gears, but 37” tires really need the 5.13 gears.
Considering the above, it would be great to have a 4.56 or 4.88 gear offered as a factory option. I don’t think the 5.13 gears would be in the cards for a factory vehicle; too many soccer moms that wouldn’t know what to do with it.
It would be great if the back seat in the Unlimited could be reclined (adjustable seat back) a few more degrees. The upright seat back is uncomfortable for anyone that is not a small kid.
With most of the JK’s competition having 5 speed automatic transmissions ( FJ Cruiser & Xterra ) or a V-8 coming ( H3 ), it would be great to have another engine choice for the JK. Another option that would be good in my opinion would be to offer the new 62TE transmission. The 4.127 first gear would be wonderful for day-to-day drivability.
Lastly, if you guys are going to be in the Indianaplois area, PM me here and I'll take you to one of our micro brew houses. The first round is on me.
The higher gearing allows the engine to operate in the rpm and map range that give higher rates of EGR. Engine noise is probably higher though.
No seat engineers here today but maybe the suggestion will be taken forward.
07-12-2007, 03:23 PM
#64
Originally Posted by DILYSI Dave
The OE front bumper includes crush cans. A couple of aftermarket offerings do as well, but the vast majority do no. My assumption is that these are responsible for 5mph performance, but have little to no impact on airbag performance. Does Jeep have an opinion on the elimination of these cans?
Hello- The crush cans on the production bumper are part of the the air bag system. Without the crush cans the system operation is affected. As far as I know the only bumper that incorporates the crust cans is the winch bumper form Mopar.
I hope that helps.
#65
Is there added lift on a stock Rubicon over a Sahara or X Model? It appears there may be...can you confirm and how much if any?
07-12-2007, 03:24 PM
#66
Originally Posted by Filmpros
Are there any specific chnages to the 2008 models? We are ordering a 2008 Rubicon 2 Door.
Tire Pressure Monitoring, Sunrider Soft Top (on 2-door), and Sirius Sat Radio were made standard. Remote start was added as an option. The rest is pretty much carry over from 2007.
#67
I am running a ham radio and amp and need at least 60 amps of pwoer...with the stock 160 amp alternator have the headroom to handle this?
Is there a larger alternator available from the factory?
I assume you have a JK and you would need to upgrade the alternator if you want 60 amps. We do not sell a larger alternator for JK
#68
First off thanks for taking the time to awnser our questions on the forum.
I have a TJ wrangler question: I just changed my axle fluids in my 04 Rubicon. My 2004 FSM says both front and rear D44s require 75w-140. However when changing the fluid I noticed the tag on the rear diff said 75w-140 (as expected) while the tag front diff said 80w-90 (same as D30).
So what weight is right for the front D44, the 75-140 specified by the FSM or the 80w-90 specified by the diff tag?
07-12-2007, 03:25 PM
#69
Originally Posted by howellru
Oh yeah, thanks for chatting with us.
I have another question, if that's okay.
Each morning when I first put my YJ automatic into gear, the transmission or rearend hesitates; sort of like a cold engine. It feels as if gears are spinning, but not grabbing. It only happens for a few seconds and only when I first put it into drive. After that, everything seems normal. And, it hasn't gotten any worse or better over the year I've had it.
Any clues or suggestions on what to check out. I can tell you the rear diff and transfer both leak.
Thanks agian for the forum.
Without experiencing it myself, I'm going to hazard a guess that you've got engagement delay. This could be as simple as burnt fluid that needs to be changed or your transmission may need a complete overhaul. My suggestion would be to change/flush all the fluid, change the filter and adjust the bands before condemning the unit to a rebuild.
#70
Originally Posted by scottlaroc
Question regards to the leaking Freedom Top.I had the leaks at the center seam and the dealer used a black chaulking to fix it.It didn't seem like a professional job and was wondering if Jeep will replace the original seals instead of the having black goop all over when removing them.Thanks.
Your vehicle is under warrenty and the dealer should be replacing the original seals.
07-12-2007, 03:26 PM
#71
Originally Posted by jeeparoo
On the 2006 Jeep Wrangler TJ, it seems the A/C cycles out at 30-35 PSI on the gauges even when spec says 25 PSI... have been through 3 pressure switches with this...and the dealers and they all cycle at 30-35..
is there an adjustable Low PSI switch made? or a way to get in contact with the OEM for those low PSI switches? to see if other models are made?
also even when lowering refrigerant levels.. seems the compressor wants to hold 25-30 PSI on suction side regardless of refrigerant temp.. is there any technical docs available on the 2006 wrangler A/C system?
is there pressure balancing going on in the compressor? is it straight orifice tube? is there 1 or 2 orifice tubes? is it variable orifice?
thank you for your help. the reason for all this is that the factory A/C on my 06 wrangler and the late model liberties(it doesnt appear to be just my unit I have test driven several with same results) as well seems to be very lackluster in relation to my previous 3 wranglers.. (a 97,an 00, and an 02)..
-Christopher
OK.. maybe you know more than me !! [ grin ] The systems are pretty much the same on 00 to 06. Some minor changes in the blower moter setup.
It should perform the same ? Kind of hard to guess without seeing/testing it. The system is a fixed orifice tube setup.
There is no stock adjustable switch.. but there might be an aftermarket one? No HEVAC engineer here tonight... I assume you are trying to keep the compressor running longer ??
#72
Any way to correct the speedo for tires larger than the largest OE 32"?
Thanks
2007 Red Rock Sahara - 15X8 Cragar soft 8s w/ Toyo OP M/T 35/13.5R15, 2" BB w/Superlift Shocks.
2007 Stone White Unlimited X - 15X8 Cragar soft 8s w/ Toyo OP M/T 33/12.5R15, 2" BB w/Superlift Shocks.
1982 CJ-7 Renegade - Dissasambled and waiting for an infusion of $$$$
*SOLD* 2006 Silver SW Rubicon
*Crashed* 1997 White TJ Sport
#73
Sorry...will 33" Tires fit a Stock 2008 Rubicon nad does the 2008 Rubicon have additional lift compared to the Sahara or X Model?
Originally Posted by JeepEngineers
What year Rubicon
#74
Originally Posted by Happy Joe
The commercials that I see on newer Jeeps show extremely limited articulation, even on Rubicons.
Is there a technical reason for limiting the wheel travel?
Thanx!
Bad lighting?
Seriously, the Rubicon has more articulation than any Jeep ever. The front stabilizer bar disconnect system is standard on the Rubicon and is available as an option on the X or as a Mopar accessory.
#75
Originally Posted by fish4life
Has jeep ever considered offering a rear locker option on non-Rubicon models, something Toyota has been doing recently on some of their models. I think this would be a great option on new Jeeps for someone who may not be into a Rubicon.... Is this option being limited by the infamous Dana 35 by any chance???
Yes, we will offer a rear only locker for the 2008 MY vehicle. This will be available in models other than the Rubicon. You will be required to order the front sway bar disconnect with the locker option. All 2008 Wrangler will feature a Dana 44 rear axle.
