05/30 Q/A Session - 2005 - 2007 Grand Cherokee - Page 8 - JeepForum.com
Closed Thread
post #106 of 150 Old 05-30-2007, 04:33 PM
TRZ
2008 WK
CRD fuel economy
Car and Driver tested the CRD WK and got 17 MPG overall. This seems pretty low compared to the 20/24 EPA estimates. Does the CRD engine require a long break-in period, during which optimum fuel economy should not be expected?
TRZ is offline
post #107 of 150 Old 05-30-2007, 04:33 PM Thread Starter
JeepEngineers
JeepEngineers's Avatar
Originally Posted by MacAttack
I like to keep "overdrive" off at all times when city driving.
Any harm in doing this?
Am I shortening the life of the tranny by doing this?
This won't hurt anything, but just keep in mind, your fuel mileage may be slightly lower because of it.
JeepEngineers "INTRODUCING THE GREATEST JEEP LINEUP EVER"
JeepEngineers is offline
post #108 of 150 Old 05-30-2007, 04:35 PM Thread Starter
JeepEngineers
Originally Posted by Muddy Cherokee
Why was the decision made to use IFS instead of a solid front axle? I heard rumors of Jeep testing an IFS/IRS GC before the WK was released, but they couldn't make it handle as well as a GC on solid axles. Is this true? Are there any chances of a return to solid front axles or is car-like ride more important than off road ability to too many people?
IFS was chosen for the improved steering feel and the improved ride and comfort that it provides.
Unfortunately, we can't discuss the specifics of our future products.
Thanks for participating!
post #109 of 150 Old 05-30-2007, 04:35 PM
Arkansas_WJ
Arkansas_WJ's Avatar
Originally Posted by JeepEngineers
I assume you're driving a WJ. Manually shifting the transmission won't harm it, as long as you're running the engine at resonable RPM levels(ie. not reving it too high). Often times, if you're driving in hilly terrain and you find the transmission "hunting" for gears, it's better to lock out overdrive so you elliminate unecessary shifting. As far as driving with overdrive off all the time, it's not really going to do much for you other than decrease your fuel mileage.
Mitch
2000 WJ Limited - 4.7l, 4x4, pioneer HU w/ ipod interface, upgraded front calipers, yakima lowrider system, uniden cb w/ 4 ft firestick, 3.5" tweeter upgrade
Arkansas_WJ is offline
post #110 of 150 Old 05-30-2007, 04:37 PM Thread Starter
JeepEngineers
Originally Posted by blankster
Is there a specific mileage range when one would consider a 5.7 fully broken in? Do synthetics effect (extend) break-in. Is there a mileage point for the drive train? I remember the first 100 miles on my '07 Overland the drive train seemed very stiff.
It's really totally dependent on duty cycle. For example, towing will accelerate the break-in process. Synthetics by nature of their composition and the wear reducing effects can extend this interval. Most gasoline engines if driven normally will break in within a few thousand miles.
Remember, we don't have any specific oil type (other than weight and API certification) requirments, but we also don't recommend extending your change intervals just because you're using synthetic.
post #111 of 150 Old 05-30-2007, 04:37 PM Thread Starter
JeepEngineers
Originally Posted by Colo.kid
Do the clutches in the ELSDs require any maintenance after extensive use? The reason I ask is my '05 "bucked" a far amount in low range with making tight turns offroad. At 35,000 miles it no longer does this and I wonder if the ELSDs are still engaged properly?
For severe off-roading, Schedule B recommends axle service every 12,000 miles. Be sure to use the recommended lube as well as the friction modifier. Also be careful to clean the old RTV from the housing and cover plate and don't allow any stray bits to fall into the sump. Also, when reassembling, don't use an excessive amount of RTV on the rear cover plate. In both circumstances, small pieces of hardened RTV can easily clog the small oil passages of the ELSD system, preventing proper operation.
The Final Drive Control Module (FDCM) does detect situations in which the T-Case or ELSD does not appear to be functioning properly. In this situation, a fault code would be stored and the "Service 4WD System" indicator would turn on.
Thanks for your question!
post #112 of 150 Old 05-30-2007, 04:37 PM Thread Starter
JeepEngineers
Originally Posted by TRZ
In the past Jeep has installed stronger front axles to accomodate local conditions (i.e. Venezuela ZJs had D44 front axles). Did Jeep ever produce a WK with a solid front axle? Any thoughts on level of difficulty of replacing the WK's IFS frontend with a JK D44?
No, there has never been a WK built with a solid front axle. If no one else has done it already, a creative fabricator/welder can do anything. I've seen pictures of KJs significantly lifted and fitted with a solid front axle.
post #113 of 150 Old 05-30-2007, 04:39 PM
CDN WK
Why is it that it seems that the WK's are being plagued with bad axle bearings again, my previous ZJ and WJ's all had the front and rear differentials rebuilt because of noise, and now my WK is going down the same road.
CDN WK is offline
post #114 of 150 Old 05-30-2007, 04:41 PM
grogie
M-F: Cell Block #4533
grogie's Avatar
There is a guy at LOST that did so to a KJ. Very cool, but I recall he spent something like close to 10k to do it.
Red Jeep Club #345
2006 TJ Sport -
2004 KJ Limited
2013 Off-Road Trailer -
from the onslaught of young idealists. -- Don Colacho
grogie is offline
post #115 of 150 Old 05-30-2007, 04:41 PM
oH2o
Is friction modifier required for either of the axles on the Jeep SRT8?
oH2o is offline
post #116 of 150 Old 05-30-2007, 04:43 PM Thread Starter
JeepEngineers
The only break-in we recommend for the vehicle is to drive moderately for the first 300 miles. As with any engine, average fuel economy does tend to increase with mileage. I can say from experience the EPA ratings for this engine are pretty realistic.
post #117 of 150 Old 05-30-2007, 04:44 PM
oH2o
On the WJ you can retrieve CEL codes vai the key on/off/on/off/on method, is there a reason that you cannot do this on the WK?
oH2o is offline
post #118 of 150 Old 05-30-2007, 04:44 PM Thread Starter
JeepEngineers
SRT-8 Axles
There is no limited slip device in the SRT-8 front or rear axles therefore no friction modifier is required.
The transfer case uses a special lube that also doen't require any additional friction modifier.
post #119 of 150 Old 05-30-2007, 04:46 PM
oH2o
The Trailhawk is a kick-*** design, how has the feedback/interest level been so far, say compared to the popular 1999/2000 Commander concept?
oH2o is offline
post #120 of 150 Old 05-30-2007, 04:47 PM Thread Starter
JeepEngineers
We typically don't see many bearing failures on WK axles. However, we do regularly monitor warranty repairs for purposes of continuous quality improvement.
Closed Thread
7/29 Q/A Session - 2007-2008 MK JeepEngineers Jeep Engineering - Q&A Archive 108 07-29-2008 05:03 PM
10/24 Q/A Session - Grand Cherokee JeepEngineers Jeep Engineering - Q&A Archive 123 11-03-2007 12:30 PM
08/29 Q/A Session - Commander JeepEngineers Jeep Engineering - Q&A Archive 132 08-31-2007 09:43 PM
04/18 Q/A session - 2007 Liberty JeepEngineers Jeep Engineering - Q&A Archive 174 04-18-2007 05:14 PM
03/14 Q/A session - 2007 Wrangler JeepEngineers Jeep Engineering - Q&A Archive 329 03-22-2007 06:58 PM
You may not post new threads
