05/30 Q/A Session - 2005 - 2007 Grand Cherokee - Page 6 - JeepForum.com
post #76 of 150 Old 05-30-2007, 04:05 PM Thread Starter
JeepEngineers
JeepEngineers's Avatar
Originally Posted by Colo.kid
I have an 05 and have had 3 failures of my power steering unit. Have there been any design changes 06-08 relative to this unit so it can better handle the cooling demands of the hydraulically-driven fan as well as steering?
Thanks for taking the time to interact with us like this--it is really appreciated!
We appreciate your feedback. Our engineers are constantly reviewing warranty data and field return parts so we can improve our component designs.
Thanks again for your input.
JeepEngineers "INTRODUCING THE GREATEST JEEP LINEUP EVER"
JeepEngineers is offline
post #77 of 150 Old 05-30-2007, 04:08 PM Thread Starter
JeepEngineers
Originally Posted by vtbert3
That being the case, how would one go about making their Hemi sound like most and not make a clicking noise when between 1/4 to full throttle? It sounds horrible and not a way to attract new customers when they hear a Hemi clicking loudly when pulling away from a stop light. I mean I think it is interesting that Jeep/Chrysler/Dodge will not fix this issue on the engines that make this noise and they actually say its normal. I have been in several Hemi's that do not make this noise and would just like my Hemi to sound the same but dealer said NO...
As with any mass-produced product there will be some normal variation. Also, depending on the vehicle acoustics, some may transmit the noise more than others. Rest assured it won't harm anything.
post #78 of 150 Old 05-30-2007, 04:09 PM Thread Starter
JeepEngineers
Originally Posted by GoGadgetWK
Thanks, I've seen the after market lifts you mentioned but was told by my dealer that anything over 2.5 will void the tranny and suspension warranty. Was wonder ing why you can't get a rubicon type lift from the factory like the Wrangler has and drive off the lot with it?
For legal reasons, all packages we offer have to pass rigorous limit handling tests. Lifting a vehicle jeopardizes the vehicle's ability to safely handle under emergency maneuvers. The Rubicon JK and TJ did not have any suspension lifts. They were slightly taller than the standard models solely due to the larger tires fitted to them and they were able to pass all handling tests.
post #79 of 150 Old 05-30-2007, 04:10 PM
MGrobe
Man In Black
MGrobe's Avatar
How does the aurea portion of the Bluetec work, in terms of replenishing and frequency of this schedule. Additionally what is the lifespan of the catalytic convertors or particulate filters and how does the warranty handle the replacement?
-Marc-
Sweet Pea 1998 - XJ
For Sale: (4) AR 767-5766 Wheels (used) 15x7, 5x4.5, 4.5BS - for local pickup in the Chicago-area
MGrobe is offline
post #80 of 150 Old 05-30-2007, 04:11 PM
CDN WK
The chrome clad wheels, up here in Canada the outer aluminum lip is corroded after 1 winter, this is my 6th GC and I never had any issues with my previous models
CDN WK is offline
post #81 of 150 Old 05-30-2007, 04:13 PM
CEPCNC
2005 WK
The body shop manager told me that they would have to prove that the lift added caused the failure or accident to void any warranty. Just dont drive wrecklessly.
CEPCNC is offline
post #82 of 150 Old 05-30-2007, 04:13 PM
coloradowk
What is Jeep doing to help the reliability ratings of the WK?
AKA DurangoZJ
2011 WK2 | 2007 Superlifted WK on 33s
coloradowk is offline
post #83 of 150 Old 05-30-2007, 04:15 PM
InIt4TheFun
Originally Posted by JeepEngineers
The 5.7L was optimized around mid-grade but will run fine on 87 (or 85 in high altitude). Naturally, it runs the best on the fuel it was optimized for since we can make best use of timing/spark advance. Lastly, unless you own a 6.1L SRT Hemi, premium is definitely not needed nor will you get any benefit from it - save your pennies!
Great to hear it from an engineer!!!
Thanks for being here today.
I love my jeep,
Will
InIt4TheFun is offline
post #84 of 150 Old 05-30-2007, 04:15 PM
CDN WK
Why does the WK's paint have so much orange peel compared to other makes like the 300C
CDN WK is offline
post #85 of 150 Old 05-30-2007, 04:16 PM Thread Starter
JeepEngineers
The Diesel Grand Cherokee does not use Urea. The diesel particulate filter and catalytic convertors used have been extensively tested, and pass all the Jeep durability requirements.
Thanks for your interest!
post #86 of 150 Old 05-30-2007, 04:17 PM Thread Starter
JeepEngineers
He's right. We don't automatically "void" a warranty because of modifications, but if something fails as a result of the modifications, repairs for those failures would not be covered.
post #87 of 150 Old 05-30-2007, 04:18 PM Thread Starter
JeepEngineers
Whats with the cloth seats and water stains? I saw my buddies 2006 WK when it was only a month old it the seats looked awful! Only thing that happened was some rain got in on them. Looked worse than his 6 year old car seats did.
There is a Technical Service Bulletin regarding this specific issue: TSB 23-015-06. The bulletin describes the procedure used to clean the white residue from the seats.
If under warranty, a dealer can perform this work. Otherwise, use the following procedure (text pulled from the service bulletin):
1. Vacuum the cloth seat fabric.
2. Mix a solution of dish water detergent and WARM water. Do not use hot or cold water.
3. With a clean sponge, wet the vehicle cloth seat fabric. Dampen the cloth seat fabric.
Do not allow to cloth seat fabric to become soaking wet or too dry.
4. With a soft brush, agitate the soap solution and the loose residue material. The intent
is to mix and suspend the loose residue material into the soap solution.
5. With COOL water, rinse the cloth seat fabric to remove the soap and residue solution.
6. With a shop vacuum, vacuum the cloth seat fabric of any excess moisture.
7. Repeat the cool water rinse and vacuum.
8. Allow the cloth seat fabric to dry.
Thanks for your question!
post #88 of 150 Old 05-30-2007, 04:18 PM
MGrobe
Man In Black
MGrobe's Avatar
I am a diehard Cubs fan (something you can't help me with) and a fanatical Jeep owner.
I hate to think that the JK is the only live axle Jeep as some of us prefer a wagon like a XJ/WJ and now WK. I know my current idea is a screw loose question, but why couldn't the UpCountry package on the WK be more meaningful like the Rubicon package is to the TJ/JK?
I wish the UC package included a solid front axle in place of the IFS. Not that it is that evil, but someone that buys the Up Country package would understand that the trade-off is a vehicle that is more off-road oriented than street. Then guys like me can buy a CRD WK in UC trim and have a vehicle that meets my preferences.
Any large reason why the uniframe can't be adapted for both scenarios?
Mod Edit: No one can help you with your misguided Cubs fandom. Go Sox! -dakuda
-Marc-
Sweet Pea 1998 - XJ
MGrobe is offline
post #89 of 150 Old 05-30-2007, 04:20 PM Thread Starter
JeepEngineers
Originally Posted by blankster
What was the purpose of the trim piece that was in the rear wheel wells front lower that was removed for '07. The reason why I asked the question is when I went from my '04 to '07 I noticed that the noise emitted from the rear wheels when driving in the rain seem louder than our '04 WJ. I was thinking of adding some undercoat spray to the wheel wells to deaden the sound a bit.
The trim piece was removed for aesthitics(sp) only. I am not sure if the spray would deaden the sound, but if it does, please return to the forum and let us know or
post #90 of 150 Old 05-30-2007, 04:21 PM Thread Starter
JeepEngineers
Originally Posted by diegom6
Hi,
First of all, I would like to intorduce my self, I'm Diego, a owner of a Jeep/Dodge/Chrysler dealer for Peru. I don't have a 07' GC but since I sell them I have few details/compliments about my customers that I would like to share, also ask some technical questions.
1) Drivetrain & Electrical (Specially talking about 05'-06' and some 07' WH 4.7L V8)
  • Stall , die from the nowhere engine problems. Why happens this? Even with the propper upgrade software for FCM, PCM/TCM and rest of module from the DelaerConnect, wich I have acces as well. No TSB is present at this time at the DealerConnect for this big problem. We think sometimes has to be with something inside of the transmission or either with the SKREEM module.
Here are some links you may want to check for this issue.
  • Front Suspension. Why is so soft the fromt suspension? Can't be upgraded to something bit stiffer? Every customer that bought me a WK 4.7L V8 complimnets about it. On the highways with non flat surface at all, the Jeep will give you a "float" sensation and it creates some fear in drivers.
  • Driveshaft. Not much issues over here, just couple of WK/H's had to replace from new in warranty due making noise and vibration at high speeds. Maybe Jeep engineers could check for strenght of this piece and make it more solid to prevent this issue.
  • MPG. Many customers had the previous GC WJ 4.7L V8, they say with their new WK/H's 4.7L , the MPG dropped quite a bit. I know this is a heavier plataform, but it's substancial the decrease in MPG it give us the new paltaforms vs the WJ. We have from 90, 95, 97 and 98 octane fuel over here, using any of these won't help to get more decent MPG. Most are about 10-11 MPG in cit and no tmore than 14 MPG in highway. I know this depends on traffic, driving habits/style and other couple of things but it's too low for in my opinion. Exist any upgrade?
  • Exhaust Resonator. I notied the 4.7L and 5.7L HEMi V8 engines are loud compared with the old WJ exhaust system. Sounds like a old V8 with leaky exhaust. Many customer noticed this and don't like it.
2) Comfort and Interior
  • A/C vent slots. They can't seal enought decent while the blower is activated. Previous model seal very good but WK's not. I'm not the first person pointing this, I have read in some foerums about the same. If someone want the cockpit fresh/cold but don't want the air hitting agaisnt your face or any othe part of your body, you close the a/c vent slots so the blown air slowly go can fresh the cabbin.
  • Try this... put slow blower fan speed with A/C, seat in the back seat and wait some minutes, you will freeze. Why? Because the rear vent slots can't seal enough. While the driver/copilot want A/C , the rear passengers could not want A/C. One customer told me every time he took some passengers in the back seat, he had to add a little toilet in the arms rest to block the blown air comming from the vent slot to prevent freeze of the passengers.
Seats. Why are the seats for thw WK/H's too rigid? They don't offer ennough lateral support like the previous WJ models, wither comfortable at all. Many new customer of the GC compliments about comfort for long trips. Pain in the back.
Some has troubles with the height , agaisnt the roof. The distance it's too short even with full lowered seats.
Why the copilot electrical seat doens't have anymore the option to to adjust in altitud? Just forward-backward and back reclinable ?
A reference Thread HERE
That's all for now. If I have other question I will get back here. Hope you can read all, not be a pain to asnwer all this.
Thank you in advance.
-Diego
Diego -- Thanks for your note of concern. However, for tonight's purpose, I would have to suggest that you contact your local dealer support network to help resolve these issues. Thank you.
Closed Thread
7/29 Q/A Session - 2007-2008 MK JeepEngineers Jeep Engineering - Q&A Archive 108 07-29-2008 05:03 PM
10/24 Q/A Session - Grand Cherokee JeepEngineers Jeep Engineering - Q&A Archive 123 11-03-2007 12:30 PM
08/29 Q/A Session - Commander JeepEngineers Jeep Engineering - Q&A Archive 132 08-31-2007 09:43 PM
04/18 Q/A session - 2007 Liberty JeepEngineers Jeep Engineering - Q&A Archive 174 04-18-2007 05:14 PM
03/14 Q/A session - 2007 Wrangler JeepEngineers Jeep Engineering - Q&A Archive 329 03-22-2007 06:58 PM
You may not post new threads
