Quantcast 05/13 Q/A Session - Jeep Commander - Page 6 - JeepForum.com
Go Back JeepForum.com > General Jeep Forums > Jeep Engineering - Q&A > 05/13 Q/A Session - Jeep Commander
Closed Thread
Old 05-13-2008, 05:49 PM   #76
BigPoppaJNutZ
2006 XK Commander
Originally Posted by JeepEngineers View Post
ESP partial off turns off engine management, but still uses the brakes during an ESP event. This means that the engine does not reduce torque.
ESP full off turns off engine management and brake management. This is the mode in 4 low and is selectable in 4 high at low speeds.
The brake limited differential part of traction control can not be turned off - it is used to provide torque to a slipping wheel when needed. This may not be considered part of the ESP portion of the system, but may be noticed.
Hope that helps.
Would having ESP in full off possibly have any bad effects to the rest of the system with daily driving?
BigPoppaJNutZ is offline
Old 05-13-2008, 05:50 PM   #77
JeepEngineers
Originally Posted by oH2o View Post
I had posted about this issue in a prior session but have not been able to come up with a solution. The problem is the wipers on an '08 WK, they are noisy in that they make a "clunk" sound when they reach the upper part of their travel, right as they reverse direction.
Dealer has no idea what to do, and I'm not sure if this is characteristic of the WK wiper system. In most of the other vehicles I have owned you cannot even hear the wipers at all as they smoothly and quietly swipe back and forth.
I have tried changing blades/arms but no difference. Is there any type of adjustments in the linkage I can look into? Would replacing the wiper motor help?
It's difficult to diagnose over the internet of course, but as with any mass produced product there is going to be a specification range that is considered acceptable when a part or system is designed. I've driven in WKs and XKs, some with different degrees of noise in the wiper system operation. Replacing one specific part may or may not change or improve the system. You can always try a different dealer to see if they come up with a different assessment....
[FONT="Arial Black"][SIZE="4"]JeepEngineers[/SIZE][/FONT] "INTRODUCING THE GREATEST JEEP[SIZE="1"]®[/SIZE] LINEUP EVER"
[I][URL="http://www.jeep.com/"]http://www.jeep.com/[/URL]
[URL="http://www.jeep.com/en/experience/community/have_fun_out_there/"]Have Fun Out There![/URL]
[URL="http://www.facebook.com/jeep"]Check out Jeep on Facebook[/URL]
[URL="http://www.youtube.com/thejeepchannel"]Check out Jeep on YouTube[/URL]
[URL="http://www.flickr.com/groups/jeepexperience/"]Check out Jeep on Flickr[/URL][/I]
JeepEngineers is offline
Old 05-13-2008, 05:51 PM   #78
JeepEngineers
Originally Posted by ArloGuthroJeep View Post
Carbon fiber is very difficult to weld to and every time I weld to magnesium it bursts into flame
Well, there's that too.
Old 05-13-2008, 05:52 PM   #79
ahmed255
2007 XK Commander
The transmission shifts from D to 1st directly by holding the shifter to the right (without kicking several times), it is a useful feature. But would happen if the shifter got hold to the right by mistake at high speeds?
2007 XH Commander (International model), Green Metallic, Limited, 5.7L HEMI, Quadra-Drive II
Spidertax 1.5" wheel spacer, Flowmaster 50 SUV muffler, Sylvaniya Ultra bulbs for high beam and fog lights, K&N replacement filter
ahmed255 is offline
Old 05-13-2008, 05:54 PM   #80
Texas WJ
Texas WJ's Avatar
2005 WK
Silly question, but is there anyway to permanently disable the auto-dimming mirrors? I have to do it manually every time I drive at night since they dim the second the Jeep is turned on. Just like my WJ did, but that vehicle allowed me to shut them off completely.
Thanks for your time.
Texas WJ is offline
Old 05-13-2008, 05:56 PM   #81
jeep5253
Hey ahmed255, they wanted to know what kind of radio you have so they could tell you how to change the time format.
jeep5253 is offline
Old 05-13-2008, 05:57 PM   #82
JeepEngineers
ESP Off
No, the rest of the vehicle is not adversly affected by having the ESP in Off. The brakes, engine, and other affected systems are capable of operating continously in ESP on, partial, and full off.
Old 05-13-2008, 05:58 PM   #83
gcpaul
2008 WK
Why does the 5.7 hemi sometimes have up to a 2 second flat spot on acceleration. This can make pulling out into traffic a little too exciting for my taste....... It can happen from a stand still, a slow roll or on the highway doing 65. Does not happen all the time.
gcpaul is offline
Old 05-13-2008, 05:59 PM   #84
JeepEngineers
Sorry, mixing things up. I have a Catia induced headache...
I am curious about adding more functionality to the system. I have heard about XK's that have functions like holding the lock/unlock on the remote for 3 seconds and the windows going up/down.
Is this type of thing possible on my '06 XK?
We're not sure right now what you can or can't enable since we don't have StarScan right here with us....
We'll have to get back to you after doing some research - after the thread closes, we go back and follow up on unanswered questions, so keep checking back!
Old 05-13-2008, 05:59 PM   #85
ahmed255
2007 XK Commander
What kind of radio do you have?
SALES CODE RAQ – AM/FM/CD (6-DISC) RADIO
ahmed255 is offline
Old 05-13-2008, 06:00 PM   #86
JeepEngineers
Feature is working as designed. There is no way to permanently disable auto-dimming mirrors without voiding your warranty.
Old 05-13-2008, 06:00 PM   #87
BigPoppaJNutZ
2006 XK Commander
THANKS!
Old 05-13-2008, 06:01 PM   #88
JeepEngineers
The pull & hold (to the left, not right) feature that you reference will provide the lowest gear possible without overreving the engine. You cannot damage the vehicle by using this feature. Pull and hold to the right will get you back to "D".
If you tap the shifter left it lowers the max gear (gear limiting function). Tap right raises the max gear until you get to "D". In the case of "tapping" to a lower gear, you can select 1 - no matter what speed. Still you will never get to 1 until you go slow enough to safely get a downshift to 1st. Once there, you will stay in 1st.
Hope this helps.
Old 05-13-2008, 06:02 PM   #89
JeepEngineers
Some of this is just a normal consequence of electronic "fly by wire" throttles.
The delay from a stand still or a slow roll is partly an issue of tuning and striking a balance between a throttle that is "too responsive" and one that "isn't responsive enough". We'll include your concern in future calibration discussions.
As for the concern at highway speed, it is most likely a momentary delay as your MDS system transitions from V4 mode to V8 mode.
Old 05-13-2008, 06:03 PM   #90
ArloGuthroJeep
Mr. Hyde!
ArloGuthroJeep's Avatar
Nevermind...
ArloGuthroJeep is offline
Closed Thread
Glock Forum
