05/13 Q/A Session - Jeep Commander
#61 | ||
As far as the diesel suggestion - we appreciate the feedback!
[FONT="Arial Black"][SIZE="4"]JeepEngineers[/SIZE][/FONT] "INTRODUCING THE GREATEST JEEP[SIZE="1"]®[/SIZE] LINEUP EVER" [I][URL="http://www.jeep.com/"]http://www.jeep.com/[/URL] [URL="http://www.jeep.com/en/experience/community/have_fun_out_there/"]Have Fun Out There![/URL] [URL="http://www.facebook.com/jeep"]Check out Jeep on Facebook[/URL] [URL="http://www.youtube.com/thejeepchannel"]Check out Jeep on YouTube[/URL] [URL="http://www.flickr.com/groups/jeepexperience/"]Check out Jeep on Flickr[/URL][/I] |
#62 | |
#63 | |
ESP full off turns off engine management and brake management. This is the mode in 4 low and is selectable in 4 high at low speeds. The brake limited differential part of traction control can not be turned off - it is used to provide torque to a slipping wheel when needed. This may not be considered part of the ESP portion of the system, but may be noticed. Hope that helps. ![]()
#64 | |
#65 |
[QUOTE=JeepEngineers;5212138]
The brake limited differential part of traction control can not be turned off - it is used to provide torque to a slipping wheel when needed. This may not be considered part of the ESP portion of the system, but may be noticed. QUOTE] So what are the other parts or functions of the Traction control other than "The brake limited differential"?
2007 XH Commander (International model), Green Metallic, Limited, 5.7L HEMI, Quadra-Drive II Spidertax 1.5" wheel spacer, Flowmaster 50 SUV muffler, Sylvaniya Ultra bulbs for high beam and fog lights, K&N replacement filter |
#66 |
I'll second Jeep5253's comments. Once you use the racks the reception is gone.... kinda defeating the point especially on road trips when I like to listen to the sat. radio the most. Thanks again for your time.
#67 |
Is your radio currently in 24hr format or 12 hr format?
#68 |
Astetics over-ruling functionality is a scary proposition for a Jeep. The Jeep has always symbolized to epitome of functionality. If you stray from the functionality history of the "Jeep" brand, then you defeat the entire purpose someone will buy one in the first place. Note: The most successful Jeep models ever produced have all put functionality first and astetics second. If we wanted a pretty car that didnt function worth a crap, we'd go to another company.
Useful Write-Ups: SEARCH TUTORIAL TJ Tech BOOT CAMP-A Must Read! FAQ: Cold Air Intakes & K&N's Off-Road Tips and Techniques What is a CV shaft and why do I want one? So you want a Tummy Tuck? Tire size, lift height, bumpstops & shock guide DIY Shock Shifters for Long Travel Shocks Lug nuts and bolt patterns Catalytic Converters Busted TJ Track Bar Bolt Fix Brake Knuckle Divot/Groove Repair Coconut Oil for Drilling and Machining Fabrication & Build: My Build Thread Funny: Will it fit in my Jeep? |
#69 |
24hr format
#70 | |
Mr. Hyde!
2) What is the cause of all of the excess weight when (to my understanding) a unibody is supposed to be lighter then a frame/tub vehicle? 3) Are there realistic changes (assuming money is the driving factor) that could be implemented to save a worthwhile amount of weight (not asking for future, just asking whether weight could realistically be saved)? 4) Looking forward at future government regulations on safety & performance, do you forsee any significant barriers to the Jeep brand?
'04 WJ, 6" Clayton LA's, 242 SYE, 35" BFG MT KM2's, 4.56 gears, & D44a locked |
#71 | |
[QUOTE=ahmed255;5212149]
1. Brake limited differential (BLD) 2. Engine management (torque reduction) Essentially if BLD can restore traction that's all that is used. If that is not enough, then the power is reduced until traction is restored.
#72 |
I noticed in Star Scan that there two thresholds for the Tire pressure gage sensor system, the first at 20 psi and the second was at (I think) 7 psi.
The alarm goes off at 20 psi, what happens when it reaches 7 psi (the lower threshold?
#73 | |
2) A lot of the reason is safety equipment (airbags for example) and all the creature comforts that are expected in a modern vehicle. 3) Exotic/expensive materials such as carbon fiber or magnesium are certainly an option, but of course as you said, cost is a factor. 4) There are significant barriers to achieve the 35 MPG government mandate. On the other side, FMVSS 214 has been updated and will require improved performance in side pole impacts in the future. This requires additional reinforcements which add weight. Still the problem is solvable. We are very aggressively reviewing all fuel economy improvement opportunities.
#74 | |
Mr. Hyde!
#75 |
| Thread Tools | |
Previous Thread
Next Thread
| Suggested Threads |
