Quantcast 05/13 Q/A Session - Jeep Commander - Page 3 - JeepForum.com
Go Back JeepForum.com > General Jeep Forums > Jeep Engineering - Q&A > 05/13 Q/A Session - Jeep Commander
Closed Thread
Old 05-13-2008, 04:50 PM   #31
BigPoppaJNutZ
2006 XK Commander
Sirius Antenna...
Discussions have been happening (on jeepcommander.com) about the location of the antenna in the back having interference from the roof rack cross member. Any chance this might be getting moved?
BigPoppaJNutZ is offline
Old 05-13-2008, 04:55 PM   #32
JeepEngineers
Originally Posted by JeepEngineers View Post
We are working up a response for you that might be helpful.
Not having a Star Scan here, we cannot confirm that the capability exists to enable the camera, however, if you find a dealer that is willing and able, here is how to activate the camera:
In the FCM, write LID $0B, Byte 14, Bit 2 = 1 Rear Camera Present
[FONT="Arial Black"][SIZE="4"]JeepEngineers[/SIZE][/FONT] "INTRODUCING THE GREATEST JEEP[SIZE="1"]®[/SIZE] LINEUP EVER"
[I][URL="http://www.jeep.com/"]http://www.jeep.com/[/URL]
[URL="http://www.jeep.com/en/experience/community/have_fun_out_there/"]Have Fun Out There![/URL]
[URL="http://www.facebook.com/jeep"]Check out Jeep on Facebook[/URL]
[URL="http://www.youtube.com/thejeepchannel"]Check out Jeep on YouTube[/URL]
[URL="http://www.flickr.com/groups/jeepexperience/"]Check out Jeep on Flickr[/URL][/I]
JeepEngineers is offline
Old 05-13-2008, 05:03 PM   #33
ds3806
I cannot wait to try the star scan with the dealer after ordering the parts and hope it all works!!! Thank you for the information and your time.
ds3806 is offline
Old 05-13-2008, 05:04 PM   #34
Hrothgar
The 4x4 Commander has a C213R (Corporate 8 1/4). The ring gear diameter is 213mm or about 8 3/8". It is a full floating design which means that the axle shaft doesn't carry the weight of the vehicle - it has a unit bearing at the wheel end. The ELSD version with QuadraDrive II has the torque capacity of a locking differential.
The suspension design is a 5-link which includes 4 control arms and a track bar.
What are the stats of the front axle? and since you mentioned that aftermarket kits are available to fit 35" tires, are these axles capable enough to withstand moderate 4wheeling on 35" tires?
'02 TJ with some useless stuff bolted on.
'93 GC 5.2 Limited, Stock
Join the Moab Offroad group
Got autonomous thought?
Originally Posted by jeepstronaut View Post
Who made you clowns pope of this dump?
Hrothgar is offline
Old 05-13-2008, 05:04 PM   #35
ArloGuthroJeep
Mr. Hyde!
ArloGuthroJeep's Avatar
Is the XK using the CAN bus? How many devices do you have communicating on it?
ArloGuthroJeep is offline
Old 05-13-2008, 05:06 PM   #36
JeepEngineers
Yes the XK uses the Can Bus. There are up to 28 modules(depending on how your vehicle is equipped) communicating on the CAN bus.
Old 05-13-2008, 05:07 PM   #37
JeepEngineers
Originally Posted by BigPoppaJNutZ View Post
Sirius Antenna...
For optimal satellite radio reception and minimum wind noise, the cross bars should be placed in the 1st (most foward) position and in the 4th (2nd from most rearward) position. There are no plans to change the location of the satellite antenna.
Old 05-13-2008, 05:09 PM   #38
BigPoppaJNutZ
2006 XK Commander
Thanks, thats the way I have mine set up.
Old 05-13-2008, 05:09 PM   #39
That1guy
2007 WK
How about a rubicon package with dana 44's?
I'm forever grateful to Speedycat and RnEmOvr for their generosity
That1guy is offline
Old 05-13-2008, 05:10 PM   #40
JeepEngineers
Can't promise anything or discuss future plans, but we appreciate the suggestion!
Old 05-13-2008, 05:10 PM   #41
jeep5253
The antenna really is in a bad place. If you use the roof racks to carry anything the antenna is blocked. As engineers you really should consider moving it up front.
jeep5253 is offline
Old 05-13-2008, 05:11 PM   #42
curleycommander
can you add the new keyless ignition system to an 06 that is available with an 08?
curleycommander is offline
Old 05-13-2008, 05:11 PM   #43
insmanblue
Can you tell us when an ipod intergration cable be available for people with 08 RER MyGig with Nav? Currently there is one for the non nav. but not nav.
2008 Grand Cherokee Limited | Light Greystone Pearl | 4.7 | MyGig | HID | Silverstar | Tow Package | Body Color Grill | LED Tail Lights | 1.25" Wheel Spacers | Goodyear Fortura Triple Tread |
insmanblue is offline
Old 05-13-2008, 05:13 PM   #44
JeepEngineers
The front axle is a C200F (Corporate 200). The ring gear diameter is 200mm (7.9") and it's a high pinion design - the pinion is above center which is generally stronger for a front axle. It also has a cast iron housing. The ELSD version again has the torque capacity of a locker.
We have built several Mopar Underground concept vehicles such as the Safari Commander which have been wheeled in Moab, Drummond Island, Pennsylvania, Washington, etc. with up to 35" tires. As with any vehicle, there are drivers that can make things live with large tires and there are drivers that wouldn't be able to get out of their driveway without breaking something.
Old 05-13-2008, 05:14 PM   #45
JeepEngineers
It is not possible to update a vehicle to the new keyless ignition system.
Closed Thread
Glock Forum
