03/14 Q/A session - 2007 Wrangler - Page 7 - JeepForum.com
post #91 of 330 Old 03-14-2007, 03:39 PM Thread Starter
JeepEngineers
JeepEngineers's Avatar
Originally Posted by Paul04TJ
How much investigation has been done into root causing the issue of Death Wobble? Side to side oscillation of the front axle.
It seems many people have this issue whether lifted or stock.
I can stop by CTC to show you.
I'm assuming your talking about TJ. This forum is directed to JK, but I'll give you a quick answer. Replace the steering damper with a heavier duty unit. The stock XJ damper will also do the trick.
JeepEngineers "INTRODUCING THE GREATEST JEEP® LINEUP EVER"
JeepEngineers is offline
post #92 of 330 Old 03-14-2007, 03:40 PM Thread Starter
JeepEngineers
Originally Posted by Elusive
why can we not order factory parts more easily? I would love to whip open a jeep catalog and order a roc trac transfer case without getting hammered by a dealer mark up.
Thanks for your time!
We have franchise agreements with our dealers that don't allow us to sell parts directly to customers. Even us employees have to buy parts form dealers just like you do!
post #93 of 330 Old 03-14-2007, 03:40 PM Thread Starter
JeepEngineers
Originally Posted by mrblaine
Which one of you was responsible for the different programming to provide the alternate throttle response when you shift into low range?
When I drove them up at the short lead media launch, it was very impressive.
The Powertrain engineers! Thanks for the cudos.
We worked very closely with Vehicle Development in Moab, UT and the SuperLift off-road park in Little Rock, AR developing the optimum off-road pedal feel. Since the electronic throttle control can be subjective, it really was a team effort.
post #94 of 330 Old 03-14-2007, 03:40 PM Thread Starter
JeepEngineers
Originally Posted by peje
Is there going to be a V8 engine I am thinking of 4.7L available.
Sorry - We cannot discuss future product.
post #95 of 330 Old 03-14-2007, 03:41 PM
Cody_00_XJ
i was under the assumption that the steering damper was not the cause of the death wobble and it was attributed to other facters...
2013 JK Rubicon
Cody_00_XJ is offline
post #96 of 330 Old 03-14-2007, 03:41 PM Thread Starter
JeepEngineers
Originally Posted by cruizer428
Waiting for the half doors. When will they be available? Buying a JK hinges on this option. Thanks
The half doors will be available soon ( within the next 2 months ), for both the 2 and 4-door. You won't be disappointed. Thank-you.
post #97 of 330 Old 03-14-2007, 03:41 PM Thread Starter
JeepEngineers
Originally Posted by troy_boy
thanks, but why couldnt they paint all the models, that plastic gets faded real bad. Thanks for your time here....keep up a great Jeep!
On TJ the fender flares did fade with the sun. On JK we have switched to a more Ultra Violet stable material. This should significantly help with fading. Painted flares also require the side steps in order to block the tires from kicking up stones and chipping the paint. This one reason side steps are standard on Sahara models.
post #98 of 330 Old 03-14-2007, 03:41 PM
peje
At the autoshow I saw the Black Tie edition it consist of options like leather wheels brushed alloy dash etc.
peje is offline
post #99 of 330 Old 03-14-2007, 03:42 PM
Lfoster200
Grand Cherokee Engine Swap
Can you swap an N code engine into a J code 2002 Grand Cherokee? If so, what other changes would have to be made, i.e. computer, etc.
Thanks
'98 TJ, Chili Pepper Red, 4.0, 5 speed, Hard Top
Lfoster200 is offline
post #100 of 330 Old 03-14-2007, 03:42 PM
kenskis
Was on board air ever considererd as a factory option? I think this would appeal to many consumers. I know GM has an air compressor in some of their trucks. Also it I think it would make a nice addition to the Rubicon package, which BTW is an amazing package!
|______
|l ,[____],
l---L –OlllllllO-
()_)-()_)--o-)_)
Red 03 TJ sport l OME lift l ARB's front & rear l 4.11 gears l 32X11.50" MTR's l Nth Degree Tummy Tucker l SYE & CV l Nth Degree Dana 44 slider l Nth Degree Oil Pan Skid l JKS adjustable front track bar l KC slimlights l Rock Rails l IPF H4 headlights l Dynamat
kenskis is offline
post #101 of 330 Old 03-14-2007, 03:42 PM
JeepFreak91
If this is just for the JK I am sorry but heres my questions.
Why was the Cherokee dropped from the jeep line up?
When the Patriot was beign considered, was it targeted to be more of a Cherokee replacement?
Thanks for your time.
Edit: Please skip this question, I skipped over the first page and I just noticed this was for the JK.
JeepFreak91 is offline
post #102 of 330 Old 03-14-2007, 03:43 PM
Flipside
Flipside's Avatar
Driveline / mirror vibrations
I've an 06 Unlimited - bone stock less than 2k miles. Only two issues where I'd appreciate your input:
1) I understand that the mirrors were redesigned for the 03+ models to address a number of issues. Is it acceptable that they still vibrate from buffetting?
2) When the OD kicks in, a vibration in the driveline is apparent, to the extent that the interior rearview mirror vibrates. This begins at ~45mph up to 70 (don't drive faster than that). Rumor has it that there's a 3rd order harmonic / sympathetic vibration that is going on between the transmission skid and the engine. Can you comment?
Flipside is offline
post #103 of 330 Old 03-14-2007, 03:43 PM Thread Starter
JeepEngineers
That is a Mopar accessory kit that can be added to any JK IIRC. Check www.mopar.com for more details!
post #104 of 330 Old 03-14-2007, 03:44 PM
jzmtl
jzmtl's Avatar
Not exactly jeep related, but how many if you are answer questions under the username?
jzmtl is offline
post #105 of 330 Old 03-14-2007, 03:44 PM
ronprice
ronprice's Avatar
Hello and thanks for your time:
Would JEEP ever concider marketing a stripped down Offroad ready version for the Buyers who dont have the skills to modify a JEEP for trail use? I know they are TRAIL RATED , But they are not realy so trail ready, as trail runners would want. A little less car and alot more JEEP.
Family of 5<Myself and 4 girls. Out numbered and dont care that I leave the seat UP.
-OIIIIIO-
ronprice is offline
Closed Thread
09/29 Q/A Session - Jeep Wrangler and Wrangler Unlimited JeepEngineers Jeep Engineering - Q&A Archive 300 09-29-2009 05:03 PM
7/29 Q/A Session - 2007-2008 MK JeepEngineers Jeep Engineering - Q&A Archive 108 07-29-2008 05:03 PM
01/29 Q/A Session - Jeep Wrangler and Wrangler Unlimited JeepEngineers Jeep Engineering - Q&A Archive 188 02-04-2008 09:10 PM
05/30 Q/A Session - 2005 - 2007 Grand Cherokee JeepEngineers Jeep Engineering - Q&A Archive 149 06-07-2007 06:19 PM
04/18 Q/A session - 2007 Liberty JeepEngineers Jeep Engineering - Q&A Archive 174 04-18-2007 05:14 PM
You may not post new threads
