03/14 Q/A session - 2007 Wrangler - Page 6 - JeepForum.com
post #76 of 330 Old 03-14-2007, 03:35 PM
charlescho
charlescho's Avatar
Originally Posted by JeepEngineers
Good question. Say for instance you lift you JK and as a result, you break a u-joint because of the higher joint angles, this would not be covered. Basically, if you modify your Jeep and something breaks because of it, the warranty doesn't cover it. Also, if something external damages the vehicle, for instance the lake found it's way into your blower motor, that would be covered either. Hope this helps.
did you mean, it wouldn't be covered? just making sure
now how far does the lift void the warranty? lets say the engine blew up into 10 pieces, now is that because of the lift and possibly bigger tires? now say what if I went in with a lift but 31" tires, would they able to safely assume that I had bigger tires on because of a 6" lift? if you are not able to answer this question, that is fine, I don't want to put you in a bad position...
also when I put the key in my 2006 to ignition on(not actually turning the engine over but all the gizmo's go on), the check engine light blinks, is this normal? as soon as I turn the engine over, it goes away with the start of the I6
Thanks and I really appriciate you guys doing this!
ABC - A/Ox4 - SAMPLE - OPQRST
charlescho is offline
post #77 of 330 Old 03-14-2007, 03:35 PM
mrblaine
Wizard of Brakes
mrblaine's Avatar
Which one of you was responsible for the different programming to provide the alternate throttle response when you shift into low range?
When I drove them up at the short lead media launch, it was very impressive.
I am Savvy
blackmagicbrakes.com
mrblaine is offline
post #78 of 330 Old 03-14-2007, 03:35 PM
peje
Peje,
Engine choices are driven by a number of factors - production capacity, packaging constraints, crash regulations, and intended usage of the vehicle. For the Wrangler, the 3.8L was the best choice of our available V-6 engines due to it's low range torque being better suited to off road usage!
Is there going to be a V8 engine I am thinking of 4.7L available.
peje is offline
post #79 of 330 Old 03-14-2007, 03:36 PM
Paul04TJ
How much investigation has been done into root causing the issue of Death Wobble? Side to side oscillation of the front axle.
It seems many people have this issue whether lifted or stock.
I can stop by CTC to show you.
2013 2 door bright white Moab
White Jeep Club Member # 269
Sold!
Red Jeep Club Member # 269
'04 Wrangler 'X'
Paul04TJ is offline
post #80 of 330 Old 03-14-2007, 03:36 PM Thread Starter
JeepEngineers
JeepEngineers's Avatar
Originally Posted by tube yj
Thanks for fielding questions from the board,
I have one question I would like to toss out. Will there ever be a full size jeep (pickup or SUV) similar to the Rescue concept? 3/4 ton with a diesel would be a great tow rig/daily driver for alot of us
sorry - can't discuss future products!
JeepEngineers "INTRODUCING THE GREATEST JEEP LINEUP EVER"
JeepEngineers is offline
post #81 of 330 Old 03-14-2007, 03:36 PM
troy_boy
troy_boy's Avatar
The plastic fender followed the theme that the styling group created. It is also cheaper to repair a plastic fender than a steel one.
thanks, but why couldnt they paint all the models, that plastic gets faded real bad. Thanks for your time here....keep up a great Jeep!
Jeep is #1
LOL.....CHEERS
2007 Wrangler, 2dr. 33" Claws, Procomp Bead Sim 16", Fabtech 3" lift, 2,200 Watt Box w/Jenson Dvd/Xm Player, Dented Tailgate, Cracked Windshield, tree stump ding, I love it!
troy_boy is offline
post #82 of 330 Old 03-14-2007, 03:36 PM
Elusive
why can we not order factory parts more easily? I would love to whip open a jeep catalog and order a roc trac transfer case without getting hammered by a dealer mark up.
Thanks for your time!
I install gears!
lots of gears
gears that make you go, gears that make you slow.
Elusive is offline
post #83 of 330 Old 03-14-2007, 03:36 PM
cruizer428
What increases towing capacity?
What increases towing capacity? Is it just the addition of the 4.10 rear? If I get the automatic it comes with the 4.10 do I still need to add the tow package? I don't have the need for the tow hooks.
Sorry to harp on the half doors, but is it production delays or other factors slowing the release? I'm just desperate.
cruizer428 is offline
post #84 of 330 Old 03-14-2007, 03:37 PM
nickusgabbard
power windows
my power windows in my 1999 jeep cherokee (chili pepper red if you were wondering) stopped working this winter and i didnt really care to look at it because it was the winter but now that its warming up and i hate AC i need to figure out if i can fix this myself.
at first it was just the passenger window but then a week later all the windows went. and i cant find a fuse for them and i dont know where the ground is located can someone give me some ideas to check out or a wire diagram would be helpful
Red1999 Cherokee Sport 4.0 HO bone stock
hopefully getting 3 inch lit kit for my b-day
nickusgabbard is offline
post #85 of 330 Old 03-14-2007, 03:37 PM
cincytj
cincytj's Avatar
hi, thanx for your time and patience answering questions. I would like to get into aftermarket manufacturing for the Jeep line. is there a resource for 3d cad data? I checked the sema database but the jeep data is really sparse. i would be interested in body and chassis files for bumper, skid plate etc....if you make them available please let me know where
Thanx
03 Patriot Blue Sport
Rubi d44 both ends, Crane Diff Covers, Rock trac t-case
Tom Woods CV DS, Alloy USA rear axles (waiting for install) ARB front bumper, Rock-it-Man Rockers
knoblock rear bumper, OBA in process,
bestop tire carrier, 35-12.5-16 trXus MT's on MOABs with 1.25 spidertrax
Currie HD steering
Nth Degree 6" LA kit. Garvin Wilderness Rack w/hi-lift mnt
HEMI & 5spd Auto
cincytj is offline
post #86 of 330 Old 03-14-2007, 03:38 PM
CoriolisSTORM
WHAT?!
CoriolisSTORM's Avatar
2010 JK Wrangler
How many of you guys are going to ask this question?
1998 TJ Wrangler SE - Stone White, 2.5Ls of screaming lifter clacking power, AX5, 31" BFGoodrich All Terrain T/A KOs
2010 Wrangler Unlimited Sahara - Deep Water Blue, 3.8Ls of oil consuming fury, NSG-370, BFGoodrich Rugged Terrain T/A 265/70/R18s
CoriolisSTORM is offline
post #87 of 330 Old 03-14-2007, 03:38 PM
Rescue XJ
What do you feel is the best way to improve the suspension of a jeep in general?
White 96 XJ Sport
Jeepforum Minister of Sarcasim
4L HO Command track Dana 30 front Chrysler 8.25 rear CarQuest XD shocks, Federal Signal emergency stuff, MCX 1000 DES-XL, TK-940, Astro Spectra W3 encrypted, Magnaflow 18" body, Medical supplies, MREs, Gatoraid, Shovel, MagLite, body armor, grappling hook, annoying squeeking sound from my door, otherwise stock for now.
White Jeep Club Member #911
Code 3 Jeep Club Member #1
Eagle Scout Jeep Club Member #2
Originally Posted by tx50cj3a
Vatozone.
Originally Posted by 92 Briarwood
I think "that look" is what they teach the chicks in 6th grade when they show them "that film" behind closed doors.
Rescue XJ is offline
post #88 of 330 Old 03-14-2007, 03:38 PM
mrblaine
Wizard of Brakes
mrblaine's Avatar
Do some research on Haltenberger linkage.
I am Savvy
mrblaine is offline
post #89 of 330 Old 03-14-2007, 03:38 PM Thread Starter
JeepEngineers
Originally Posted by kenskis
What considerations were there for the ease of soft top use while developing the new JK? I have a TJ, and one of my few complaints is that it's a little bit of a process to lower the top and remove the windows. It would be nice to be able to keep the windows in the vehicle without taking up too much room. I am surprised the JK soft top is so similar to the TJ soft top. (I know the hard top was split up into pieces to be easier to install/remove.)
Actually the hard top wasn't split into pieces for easier removal, it was to give customers the "Freedom Top" feature!
As far as the soft-top design, we had to balance cost/affordability with functionality. Also remember, soft windows, regardless of who makes them scratch easily. It's better for the longevity of your windows to remove them store them in the appropriate Mopar window storage bag. Visit www.mopar.com for more info on the window bag!
post #90 of 330 Old 03-14-2007, 03:39 PM
Tinker
Tinker's Avatar
Not so much a question as a plead, BUILD THE GLADIATOR PLEASE! thank you for your time here.
"Does this look broken to you?"
Tinker is offline
Closed Thread
09/29 Q/A Session - Jeep Wrangler and Wrangler Unlimited JeepEngineers Jeep Engineering - Q&A Archive 300 09-29-2009 05:03 PM
7/29 Q/A Session - 2007-2008 MK JeepEngineers Jeep Engineering - Q&A Archive 108 07-29-2008 05:03 PM
01/29 Q/A Session - Jeep Wrangler and Wrangler Unlimited JeepEngineers Jeep Engineering - Q&A Archive 188 02-04-2008 09:10 PM
05/30 Q/A Session - 2005 - 2007 Grand Cherokee JeepEngineers Jeep Engineering - Q&A Archive 149 06-07-2007 06:19 PM
04/18 Q/A session - 2007 Liberty JeepEngineers Jeep Engineering - Q&A Archive 174 04-18-2007 05:14 PM
You may not post new threads
