03/14 Q/A session - 2007 Wrangler - Page 3 - JeepForum.com
Closed Thread
post #31 of 330 Old 03-14-2007, 03:17 PM
BlaineWasHere
BecauseRacecar
BlaineWasHere's Avatar
I have to ask, becuase someone will.
Are there any plans to use either the 2.8 CRD in use in export JK's or the new 3.0 in the 07WK in the JK for domestic sales?
2013 FR-S
BlaineWasHere is offline
post #32 of 330 Old 03-14-2007, 03:17 PM
cruizer428
Half door availability
Waiting for the half doors. When will they be available? Buying a JK hinges on this option. Thanks
cruizer428 is offline
post #33 of 330 Old 03-14-2007, 03:17 PM Thread Starter
JeepEngineers
JeepEngineers's Avatar
Originally Posted by BlaineWasHere
How do JK's get the reading for the speedo? At the transfercase like old(er) Jeeps (TJ) or at the tone rings in the rear axel like newer Jeeps (WJ)?
Also what is the wheel to wheel mounting surface of JK axels?
There is a tone ring on the end of each axle.The tone wheel has 52 teeth per ring the information from each wheel speed sensor is sent to the ABS modual. This information is converted from a analog signal to digital signal and the message is sent out on a CAN Bus line to the cluster and engine controller.
JeepEngineers "INTRODUCING THE GREATEST JEEP® LINEUP EVER"
JeepEngineers is offline
post #34 of 330 Old 03-14-2007, 03:17 PM Thread Starter
JeepEngineers
Originally Posted by BESRK
Hi guys! Welcome!
My question to you is.. Most aftermarket suspension manufacturers offer some sort of "long arm" coil suspension as their top-of-the-line suspension kit. Just wondering if Jeep ever thought about lengthening the link arms on something like the Rubicon straight from the factory? I mean, it came with a bunch of great offroad components only to be limited by short arms. Also, what actually dictates the length of the factory arm? Street handling? Safety? Ease of production? Thanks again for being here...
Edit: man, in the time it took me to type this about 4-5 others asked questions already...
Well, the arms on JK are slightly longer than what we offered on TJ, if that helps at all. We are somewhat limited as to what we can offer off-road wise "out of the box". As you mentioned there are many safety and handling requirements that we have to stick with to sell a main-stream SUV. That's basically why the vehicle is set up the way it is.
post #35 of 330 Old 03-14-2007, 03:18 PM Thread Starter
JeepEngineers
Originally Posted by Sporer65
Is there any chance that the JK will be getting the more powerful 4.0L V6 to go along with the 3.8L?
Unfortunately , we do not discuss future product.
post #36 of 330 Old 03-14-2007, 03:19 PM
kenskis
How much freedom do engineers recieve in desigining a vehicle?
What do you especially like/dislike about the JK?
If you could design the vehicle without any constraint what would be different?
BTW Thanks for being here to answer our questions.
|______
|l ,[____],
l---L –OlllllllO-
()_)-()_)--o-)_)
Red 03 TJ sport l OME lift l ARB's front & rear l 4.11 gears l 32X11.50" MTR's l Nth Degree Tummy Tucker l SYE & CV l Nth Degree Dana 44 slider l Nth Degree Oil Pan Skid l JKS adjustable front track bar l KC slimlights l Rock Rails l IPF H4 headlights l Dynamat
kenskis is offline
post #37 of 330 Old 03-14-2007, 03:19 PM Thread Starter
JeepEngineers
Originally Posted by anticrombie
Why does jeep feel the need to switch up OEM part numbers? In all honesty, this makes no logical sense. You have to put a different number on the part, you have to update all of the FSM's, all of the online databases, etc.
Thanks,
Charlie
Charlie,
Generally we don't put any part numbers in the service literature other than TSB's. Our computer systems have "supercerdence" built into them and whenever an older part number is entered into the dealer systems, it automatically shows the current part number. Part number changes are driven by our need to be able to track the performance of an individual part, not only from sales but warranty performance.
post #38 of 330 Old 03-14-2007, 03:19 PM
ArloGuthroJeep
Mr. Hyde!
ArloGuthroJeep's Avatar
Is that the same as the WJ tone rings? I thought the WJ's has 48 teeth
'14 WK2 Limited w/5.7L, ORAI, & Tow Package
ArloGuthroJeep is offline
post #39 of 330 Old 03-14-2007, 03:20 PM
Rescue XJ
What drove the switch from the straight 6 in the wranglers? The performance gains are slight when looking at the numbers.
White 96 XJ Sport
Jeepforum Minister of Sarcasim
4L HO Command track Dana 30 front Chrysler 8.25 rear CarQuest XD shocks, Federal Signal emergency stuff, MCX 1000 DES-XL, TK-940, Astro Spectra W3 encrypted, Magnaflow 18" body, Medical supplies, MREs, Gatoraid, Shovel, MagLite, body armor, grappling hook, annoying squeeking sound from my door, otherwise stock for now.
White Jeep Club Member #911
Code 3 Jeep Club Member #1
Eagle Scout Jeep Club Member #2
Originally Posted by tx50cj3a
Vatozone.
Originally Posted by 92 Briarwood
I think "that look" is what they teach the chicks in 6th grade when they show them "that film" behind closed doors.
Rescue XJ is offline
post #40 of 330 Old 03-14-2007, 03:20 PM Thread Starter
JeepEngineers
4 door half door is launching soon! It will be worth your wait!
post #41 of 330 Old 03-14-2007, 03:21 PM
jzmtl
jzmtl's Avatar
Are there any plan to use mercedes' (or anyone else's)diesel in JK (specifically 2 dr rubicon?
jzmtl is offline
post #42 of 330 Old 03-14-2007, 03:21 PM
STW
back seat access in 2 door
Getting in and out of the back of the new two door JK was really difficult. Much tougher than with my 2000 TJ--the JK seat didn't come all the way forward like my TJ. JK forum guys said this just how it is. Are you going to address this in 2008? Is there a way to fix it for a 2007? Thanks, from Utah.
2000 2.5 TJ, 5spd, 33s, 8274
STW is offline
post #43 of 330 Old 03-14-2007, 03:21 PM
jeepers3
Can you give any idea how much it will cost to buy a set of half doors for the JK Sahara I already have? And if you can buy them after the fact, do they come painted, or do you have to get them painted, and IF SO, does the price reflect painting by the local dealer or what?
jeepers3 is offline
post #44 of 330 Old 03-14-2007, 03:22 PM Thread Starter
JeepEngineers
Originally Posted by franx
But it scratches so easily !! you just run your nail on it a little bit and its going to scratch !!
Mine is already full of scratches and I only have 3000km on it.
Thanks, Frank
Frank,
We hear you - just remember that we are always evaluating alternate materials for future products/changes.
post #45 of 330 Old 03-14-2007, 03:23 PM Thread Starter
JeepEngineers
Unfortunately we can't comment on specific future product plans!
Thanks!
Closed Thread
09/29 Q/A Session - Jeep Wrangler and Wrangler Unlimited JeepEngineers Jeep Engineering - Q&A Archive 300 09-29-2009 05:03 PM
7/29 Q/A Session - 2007-2008 MK JeepEngineers Jeep Engineering - Q&A Archive 108 07-29-2008 05:03 PM
01/29 Q/A Session - Jeep Wrangler and Wrangler Unlimited JeepEngineers Jeep Engineering - Q&A Archive 188 02-04-2008 09:10 PM
05/30 Q/A Session - 2005 - 2007 Grand Cherokee JeepEngineers Jeep Engineering - Q&A Archive 149 06-07-2007 06:19 PM
04/18 Q/A session - 2007 Liberty JeepEngineers Jeep Engineering - Q&A Archive 174 04-18-2007 05:14 PM
You may not post new threads
