03/14 Q/A session - 2007 Wrangler - Page 2 - JeepForum.com
Closed Thread
post #16 of 330 Old 03-14-2007, 03:14 PM
dakuda
Admin
dakuda's Avatar
Originally Posted by JeepEngineers
The CV style joint is better for noise, vibration and harshness. Or NVH as we call it.
However, this is susceptible to problems when lifting the vehicles. The slip-joint issue is resolved with a double cardon on the TC side, from what I understand. Now, this issue seems to replace the old slip-joint problem of the past.
You can do things the right way or the wrong way.
Or you can do it MY way...which is like the wrong way, only faster.
dakuda is offline
post #17 of 330 Old 03-14-2007, 03:14 PM
anticrombie
anticrombie's Avatar
Why does jeep feel the need to switch up OEM part numbers? In all honesty, this makes no logical sense. You have to put a different number on the part, you have to update all of the FSM's, all of the online databases, etc.
Thanks,
Charlie
Charlie
anticrombie is offline
post #18 of 330 Old 03-14-2007, 03:14 PM
10achik
I ate what?
10achik's Avatar
True but in our circles when putting them to the test they tend to fail more often than the U-jointed style, is there a posibility of having an upgrade for future models at the time of purchase.
Ken
99 GC Limited - 4.7L HO V8, 6.5" IRO HC LA lift, F&R D44s locked & trussed, 242HD, IRO TC Skid, KMA Bumper, 35's
2006 Saturn Redline -2.0L Eaton supercharged I4, GMPP Stage 2, Custom Tune, AEM CAI, Ebiach Pro Kit w/ swaybars, EVO Ventus V12s (13.76 @ 103.85)
2006 Pontiac G6 GTP
2012 Nissan Juke - (hers)
2000 SV650 - naked, integrated tail light, sliders, corbin, pilot roads, RK chain & sprokets, D&D full exhaust, FactoryPro Stage I jet kit, +4 Ignition Advancer, Barnett race clutch
2006 Triumph America 900 - Full Dresser
January 2009 Grand Cherokee of the Month (GCOTM)
10achik is offline
post #19 of 330 Old 03-14-2007, 03:15 PM
jeepers3
edit* I have wanted a Wrangler for many years, but you know, 2 doors is just not enough. So good job on that (:
The heated seats from Check Corp should be standard on Sahara by the way (:
I would second the above question on towing capacity v. Liberty.
How is it possible that this thing does not get better in city mileage than my old, crappy, 15 year old Isuzu Trooper with the even more crappy (and infamous) GM 2.8L V6 engine in it? I have the JK Sahara with auto in it by the way.
How much can I trust the rain gutters on the hard top? Can I put a ski rack or something like that on there without worrying about breaking those rain gutters?
jeepers3 is offline
post #20 of 330 Old 03-14-2007, 03:15 PM
franx
No problem. The interior was designed to be durable and easy to clean, and to maintain the image of the Wrangler as a simple, functional vehicle.
You're welcome for the 4-door BTW!
But it scratches so easily !! you just run your nail on it a little bit and its going to scratch !!
Mine is already full of scratches and I only have 3000km on it.
Thanks, Frank
got my first jeep on Feb 7th 2007 !!
4dr Unlimited X red rock crystal !!
franx is offline
post #21 of 330 Old 03-14-2007, 03:15 PM Thread Starter
JeepEngineers
JeepEngineers's Avatar
Originally Posted by rchs.band
Also, I am at BG status due to materials shortage? Hardtop for Unlimiteds? Thanks.
We knew that the new hard top would be popular and its been even more popular. There have been some minor delays due to the high demand but please be patient - - we are catching up. You won't be disappointed I think. Thank-you !
JeepEngineers "INTRODUCING THE GREATEST JEEP LINEUP EVER"
JeepEngineers is offline
post #22 of 330 Old 03-14-2007, 03:15 PM
ArloGuthroJeep
Mr. Hyde!
ArloGuthroJeep's Avatar
If you can pick your diff gearing, why not the yolk & drive shaft joint style as well.
'14 WK2 Limited w/5.7L, ORAI, & Tow Package
ArloGuthroJeep is offline
post #23 of 330 Old 03-14-2007, 03:15 PM
Elusive
why does jeep not use a high pinion front axle in the JK?
I install gears!
lots of gears
gears that make you go, gears that make you slow.
Elusive is offline
post #24 of 330 Old 03-14-2007, 03:16 PM
peje
I am wondering why factory has decided to use the Mini Van engine V6 3.8L where they had a truck engine V6 3.7L that is used on Liberty, Dakota Ram and now Nitro.
thank you in advance
Peje
peje is offline
post #25 of 330 Old 03-14-2007, 03:16 PM Thread Starter
JeepEngineers
Originally Posted by BlaineWasHere
How do JK's get the reading for the speedo? At the transfercase like old(er) Jeeps (TJ) or at the tone rings in the rear axel like newer Jeeps (WJ)?
Also what is the wheel to wheel mounting surface of JK axels?
Wheel to wheel mounting surface of JK axles is 65.4 inches.
post #26 of 330 Old 03-14-2007, 03:17 PM Thread Starter
JeepEngineers
Originally Posted by ArloGuthroJeep
What was the reason to switch away from the more popular 5x4.5 bolt pattern to the 5x5 bolt pattern?
Since the vehicle was made wider, the ends of the axles are farther out so we wanted to upgrade to a larger/stronger bolt pattern.
post #27 of 330 Old 03-14-2007, 03:17 PM
Sporer65
Sporer65's Avatar
Location: Powder Springs, Georgia/University of Tennessee
Is there any chance that the JK will be getting the more powerful 4.0L V6 to go along with the 3.8L?
Ben
1993 Jeep Grand Wagoneer ZJ V8: Rear Aussie, 3.5" Lift, 31" M/Ts
Sporer65 is offline
post #28 of 330 Old 03-14-2007, 03:17 PM
franx
I am wondering when the half doors will be available for purchase from dealers in Canada.
thanks, Frank
franx is offline
post #29 of 330 Old 03-14-2007, 03:17 PM
troy_boy
troy_boy's Avatar
why plastic fenders?
Jeep is #1
LOL.....CHEERS
2007 Wrangler, 2dr. 33" Claws, Procomp Bead Sim 16", Fabtech 3" lift, 2,200 Watt Box w/Jenson Dvd/Xm Player, Dented Tailgate, Cracked Windshield, tree stump ding, I love it!
troy_boy is offline
post #30 of 330 Old 03-14-2007, 03:17 PM
tube yj
tube yj's Avatar
1949 CJ3A
Thanks for fielding questions from the board,
I have one question I would like to toss out. Will there ever be a full size jeep (pickup or SUV) similar to the Rescue concept? 3/4 ton with a diesel would be a great tow rig/daily driver for alot of us
tube yj is offline
Closed Thread
09/29 Q/A Session - Jeep Wrangler and Wrangler Unlimited JeepEngineers Jeep Engineering - Q&A Archive 300 09-29-2009 05:03 PM
7/29 Q/A Session - 2007-2008 MK JeepEngineers Jeep Engineering - Q&A Archive 108 07-29-2008 05:03 PM
01/29 Q/A Session - Jeep Wrangler and Wrangler Unlimited JeepEngineers Jeep Engineering - Q&A Archive 188 02-04-2008 09:10 PM
05/30 Q/A Session - 2005 - 2007 Grand Cherokee JeepEngineers Jeep Engineering - Q&A Archive 149 06-07-2007 06:19 PM
04/18 Q/A session - 2007 Liberty JeepEngineers Jeep Engineering - Q&A Archive 174 04-18-2007 05:14 PM
You may not post new threads
