01/29 Q/A Session - Jeep Wrangler and Wrangler Unlimited - Page 9 - JeepForum.com
post #121 of 189 Old 01-29-2008, 04:22 PM
sparkdr220
My wife wants to know why the passenger floor heater is so much hotter than the drivers side. She has to tuck her feet back under her seat to keep her toes from burning....while I am quite comfortable. We are wondering if there is a deflector or a diffuser that could be put in place to fix this issue.
sparkdr220 is offline
post #122 of 189 Old 01-29-2008, 04:23 PM Thread Starter
JeepEngineers
JeepEngineers's Avatar
Originally Posted by jscherb
On my 2006 Unlimited 6 spd 17,000 miles I've got a chirp sound when I give it the gas... I'll be driving along at say 30 mph, and if I tap the gas I get a quick chirp. The chirp doesn't continue, it only happens one time for each time I tap the gas. Only happens in gear. Sounds like rubber is making the noise, like something twisting from the torque. Only related to pushing the gas pedal, it isn't a continual noise like a u-joint might make.
Have you heard of this before?
Jeff
PS: and thanks for the link to the Dodge frame modifications, looks like it will be helpful for my project.
?? Is it in the engine or drivetrain ? noise under the vehicle ?
JeepEngineers "INTRODUCING THE GREATEST JEEP LINEUP EVER"
JeepEngineers is offline
post #123 of 189 Old 01-29-2008, 04:25 PM Thread Starter
JeepEngineers
Originally Posted by sparkdr220
Thanks for this session. I have an 08 4 door unlimited X. It has been great. In overdrive at about 1200 rpm I feel some vibration, almost like the base on the radio is too high. Any Ideas what might cause this?
Hard to tell over the inter! but it sounds likea engine droan caused by the high load of overdrive and the low engine speed of 1200 rpm. It seems that the trans should shift at 1400 or so. But I would ask the dealer and compare your vehicle to others - I really can't give an accurate answer here.
post #124 of 189 Old 01-29-2008, 04:25 PM
Panici
(O|||||||O)
Panici's Avatar
Originally Posted by JeepEngineers
Gear Rattle.. yep, it's normal and OK.. unfortunately, it is an inherant design feature. The good news is.. its a very durable trans...
As for gear clash while shifting gears.. don't shift too fast... give the syncros time to match up. Of course, the syncros could be worn..
Thanks I'm not sure what the previous owner put my jeep through, hopefully he wasn't trying to shift it like a sports car!
Problem is intermittent, and even when shifting slowly the shifter sometimes jumps in my hand (happens when the shifter is moving from Neutral to 2nd). I'll try double clutching my upshifts, then if the problem is gone, I have worn syncros right?
If it's still there, do you have any ideas what else it might be?
_______
|_
_|
(OlllllllO)
Panici is offline
post #125 of 189 Old 01-29-2008, 04:27 PM
jdrogers
I would like to ask about the outside temperature in a different situation.
When I have been on full day off roading trails (like the Canyon de Chelly Jeep Jamboree) and spend the entire day running less the like 15 mph, the temperature doesn't ever change. In the afternoon, when it was clearly like 70 degrees outside, the display still showed something silly like 45 degrees which was the temperature in the morning when we started.
Can you guys correct the programming to sense the temperature all the time when in 4 wheel drive?
2002 WJ Limited, Stone White, 4.7L H.O., Quadra Drive
OME Springs, MX6 Shocks, BFG 265/70R17 All-Terrain, Level 8 Tracker Wheels
Scottsdale, AZ
jdrogers is offline
post #126 of 189 Old 01-29-2008, 04:27 PM Thread Starter
JeepEngineers
OH.. you're talking about it popping out of gear, right ? There was a TSB to help address this. BUT< not sure it would be covered now?
Bet its a violent pop out event, right ???
post #127 of 189 Old 01-29-2008, 04:27 PM Thread Starter
JeepEngineers
Originally Posted by alik
Is there a shortage in supply/building of 2008 rubis? I am seemingly waiting forever (already 9 weeks) without even getting a production date for my special ordererd vehicle.
The Rubicon continues to be very popular and we're doing everything we can to meet demand, especially this year. We very much appreciate your interest and hope you'll continue to be patient. The Rubi will not disappoint you ! Thank-you !
post #128 of 189 Old 01-29-2008, 04:28 PM
jeep'd
I recently purchased an 08 unlimited with the freedom top. Did you guys experiment with deferent types of tops and the chose that one, or was this the only one on the drawing board and you were just perfecting it? Did you concider a 5 for the unlimited to give more removal options or no?
Because I'm interested in buying the JK as soon as it comes with a diesel, and a 5 piece hard top would be nice as well
jeep'd is offline
post #129 of 189 Old 01-29-2008, 04:28 PM
1fastR
1fastR's Avatar
How much input do you guys have on what future products are released?
1fastR is offline
post #130 of 189 Old 01-29-2008, 04:28 PM Thread Starter
JeepEngineers
Originally Posted by PARAGON
Understand. But the NHTSA rule allows for the Automaker dealers to recalibrate when a new tire and/or wheel/tire combination is selected for the vehicle. Otherwise, once the new tires, requiring a different air pressure, are added the TPMS system becomes null. Which defeats the purpose of the system.
There are different thresholds for the Rubicon tires, but we can't possibly plan for every tire combination. Again, we have to meet the legislation as the vehicle is built.
We did change the operation in low range such that it only chimes once on start up.
We do understand the dilema and wish we could do more.
post #131 of 189 Old 01-29-2008, 04:28 PM
jeepsurf
I was wheeling in my 98 TJ when all of a sudden the tcase popped out of 4 low with a loud thud. Now, the 4wd light doesnt come on. There's no noise comming from the tcase, yolks, ujoints, or driveshaft. Everything seems fine
except the light. What would be the first thing you guys would suspect?
p.s. thanks for taking time to talk with us.
jeepsurf endorses this post. Most of the time
1990 2.5 YJ / 1997 2.5 TJ
USAF VET
My YJ build thread
Nightcrew alive and well, now on VB 4.0
Food mailed 3ooo miles
jeepsurf is offline
post #132 of 189 Old 01-29-2008, 04:29 PM Thread Starter
JeepEngineers
This is not a known problem. my only advice is to create your own outlet cover to suit your comfort level. Sorry!
post #133 of 189 Old 01-29-2008, 04:29 PM
Tadpole911
I have a 2dr 08 X model with an auto transmission. Twice, I've heard a ding / chime with no other indication of something wrong. It happened once while turning right @ ~10mph and another time traveling at a constant 45mph. The dealer says no codes have been set.... What do you think?
Tadpole911 is offline
post #134 of 189 Old 01-29-2008, 04:29 PM Thread Starter
JeepEngineers
Some.. we listen to you guys and try to get cool stuff into production !
post #135 of 189 Old 01-29-2008, 04:30 PM Thread Starter
JeepEngineers
Originally Posted by JeepMan1975
Most people who come on this site with a new JK often complain about a bad odor that emits once they engage in four wheel drive or when they're just driving along, but then disappears after a few uses.
Assuming that it's not the driver or passenger's body odor, can you guys comment on this? What's burning off to produce the smell?
Without smelling it, it could be a lot of things...some thoughts:
Many new parts have various coatings on them to protect them in shipment from the supplier to our factory. Given time and exposure to heat (if a part is near the exhaust for example) the coating cures or dissipates, which may explain why it goes away after a bit of use, just like the way that "new car smell" goes away after time.
It could be a misrouted axle vent tube that is too close to some body opening.
It could be mold in the air conditioner, though not likely.
There are some folks here in the room that suggest some odors can come in throught the shift boot, more so with a manual.
Good luck!
Closed Thread
09/29 Q/A Session - Jeep Wrangler and Wrangler Unlimited JeepEngineers Jeep Engineering - Q&A Archive 300 09-29-2009 05:03 PM
09/09 Q/A Session - Jeep Wrangler and Wrangler Unlimited JeepEngineers Jeep Engineering - Q&A Archive 160 09-10-2008 02:59 PM
05/13 Q/A Session - Jeep Commander JeepEngineers Jeep Engineering - Q&A Archive 92 05-13-2008 05:10 PM
07/12 Q/A Session - Wrangler and Wrangler Unlimited JeepEngineers Jeep Engineering - Q&A Archive 285 07-12-2007 07:22 PM
03/14 Q/A session - 2007 Wrangler JeepEngineers Jeep Engineering - Q&A Archive 329 03-22-2007 06:58 PM
You may not post new threads
