01/29 Q/A Session - Jeep Wrangler and Wrangler Unlimited - Page 8 - JeepForum.com
post #106 of 189 Old 01-29-2008, 05:12 PM Thread Starter
JeepEngineers
JeepEngineers's Avatar
Originally Posted by PARAGON
On 2008 JKs and the TPMS system. When upgrading to larger tires, a lower air pressure is sometimes required for proper tire wear and handling. There doesn't seem to be a way to recalibrate the TPMS for the new aftermarket tires. Has this been addressed?
We really don't have much leeway here. Tire Pressure Monitoring is part of a Federal standard and our vehicles must comply as built. Sorry!
The Specialty Equipment Manufacturers Association (SEMA) lobbies for this kind of cooperation between the Feds, Automakers, and the aftermarket - some times with better success than others.
JeepEngineers "INTRODUCING THE GREATEST JEEP LINEUP EVER"
JeepEngineers is offline
post #107 of 189 Old 01-29-2008, 05:14 PM
oH2o
On the MyGIG radio I noticed that there is no "Pause" or "Stop" control for the CD player or for the HD when playing music. Being that every CD player ever made since day one has these, uh, important buttons, I have to ask, what were the designers thinking? Or were they? The only way I have found to Pause a CD is to turn the MyGig radio off!!
oH2o is offline
post #108 of 189 Old 01-29-2008, 05:14 PM
Panici
(O|||||||O)
Panici's Avatar
Is there any way to get rid of the rattling from the 5 speed NV3550, when the clutch is out (up) in neutral? I have heard that it is normal, and that it is the clutch throwout bearing?
Also what is the cause of the shifter bump / slight grind sometimes felt if shifting slowly (or quickly) between first and second gear?
I'm switching to Royal Purple synthetic fluid in the trans in the spring, so hopefully that will help some.
_______
|_
_|
(OlllllllO)
Panici is offline
post #109 of 189 Old 01-29-2008, 05:14 PM
rayzordee
rayzordee's Avatar
2008 Sahara 4 door and LOVE it eccept for the lack of power on long hills at 40 and above. Why do the RPMs drop over 40 mph even when the foot feed is steady. You must stuff the accelorator or down shift to keep speed up. Oh automatic trans here
Thanks
Sahara 4dr, Jeep Green
Loaded...the Jeep not me.
rayzordee is offline
post #110 of 189 Old 01-29-2008, 05:16 PM
grogie
M-F: Cell Block #4533
grogie's Avatar
Originally Posted by JeepEngineers
The ABS was a stand alone option on all except rubicon due to the locker. The option rate was very low - not many ordered it!
Well let me tell you how nice ABS is on slick roads! It does a nice job keeping the rear end where it should be. Although now I kind of wish I had a Rubicon, having ABS was an option I wanted to have. I had to do a build to order to get it, as dealers just didn't have any with it. My TJ was also on hold for awhile as ABS parts were out of stock I was told.
Red Jeep Club #345
2006 TJ Sport -
2004 KJ Limited
2013 Off-Road Trailer -
from the onslaught of young idealists. -- Don Colacho
grogie is offline
post #111 of 189 Old 01-29-2008, 05:17 PM Thread Starter
JeepEngineers
Gear Rattle.. yep, it's normal and OK.. unfortunately, it is an inherant design feature. The good news is.. its a very durable trans...
As for gear clash while shifting gears.. don't shift too fast... give the syncros time to match up. Of course, the syncros could be worn..
post #112 of 189 Old 01-29-2008, 05:17 PM
sparkdr220
Thanks for this session. I have an 08 4 door unlimited X. It has been great. In overdrive at about 1200 rpm I feel some vibration, almost like the base on the radio is too high. Any Ideas what might cause this?
sparkdr220 is offline
post #113 of 189 Old 01-29-2008, 05:18 PM Thread Starter
JeepEngineers
I will forward this issue onto harmon our supplier
post #114 of 189 Old 01-29-2008, 05:18 PM
JDBerry
CMSJA
Understand. But the NHTSA rule allows for the Automaker dealers to recalibrate when a new tire and/or wheel/tire combination is selected for the vehicle. Otherwise, once the new tires, requiring a different air pressure, are added the TPMS system becomes null. Which defeats the purpose of the system.
JDBerry is offline
post #115 of 189 Old 01-29-2008, 05:20 PM
rrivas
Newbie
here is what is looks like
rrivas is offline
post #116 of 189 Old 01-29-2008, 05:20 PM
alik
Is there a shortage in supply/building of 2008 rubis? I am seemingly waiting forever (already 9 weeks) without even getting a production date for my special ordererd vehicle.
alik is offline
post #117 of 189 Old 01-29-2008, 05:20 PM Thread Starter
JeepEngineers
Thanks
Much of the 3.8L's power is made at higher revs - it takes power to keep steady speed on hills and the 3.8 needs to be kept up in the powerband.
post #118 of 189 Old 01-29-2008, 05:21 PM Thread Starter
JeepEngineers
Originally Posted by texaskev
Any word on the Gladiator making production?
We all wish... but that would be future product.... we liked it too.
Concepts tease you, eh ?
post #119 of 189 Old 01-29-2008, 05:21 PM Thread Starter
JeepEngineers
Sorry but we can't comment on future product actions
post #120 of 189 Old 01-29-2008, 05:21 PM
jscherb
On my 2006 Unlimited 6 spd 17,000 miles I've got a chirp sound when I give it the gas... I'll be driving along at say 30 mph, and if I tap the gas I get a quick chirp. The chirp doesn't continue, it only happens one time for each time I tap the gas. Only happens in gear. Sounds like rubber is making the noise, like something twisting from the torque. Only related to pushing the gas pedal, it isn't a continual noise like a u-joint might make.
Have you heard of this before?
Jeff
PS: and thanks for the link to the Dodge frame modifications, looks like it will be helpful for my project.
jscherb is offline
Closed Thread
09/29 Q/A Session - Jeep Wrangler and Wrangler Unlimited JeepEngineers Jeep Engineering - Q&A Archive 300 09-29-2009 06:03 PM
09/09 Q/A Session - Jeep Wrangler and Wrangler Unlimited JeepEngineers Jeep Engineering - Q&A Archive 160 09-10-2008 03:59 PM
05/13 Q/A Session - Jeep Commander JeepEngineers Jeep Engineering - Q&A Archive 92 05-13-2008 06:10 PM
07/12 Q/A Session - Wrangler and Wrangler Unlimited JeepEngineers Jeep Engineering - Q&A Archive 285 07-12-2007 08:22 PM
03/14 Q/A session - 2007 Wrangler JeepEngineers Jeep Engineering - Q&A Archive 329 03-22-2007 07:58 PM
You may not post new threads
