Quantcast 01/29 Q/A Session - Jeep Wrangler and Wrangler Unlimited - Page 4 - JeepForum.com
Go Back JeepForum.com > General Jeep Forums > Jeep Engineering - Q&A > 01/29 Q/A Session - Jeep Wrangler and Wrangler Unlimited
Closed Thread
Old 01-29-2008, 04:34 PM   #46
Joec
Originally Posted by JeepEngineers
Would a full-time 4WD system be something that would be of interest to you? If so, why?
I have driven several Chevy blazers with the P/T F/T 4wd option and have used both. The F/T option is very useful in marginal road conditions where the surface goes from dry to slick and back. I was disappointed when I reviewed the specs for the JK and found it was not an option. I still bought one anyway (33k+ miles ago now) but that would have been a nice addition. I vote for the F/T option!
2007 JK Unlimited Rubicon - Greystone, Auto, Power, Tow, Leather seats, Pneumatic Lumbar support, Seat Heat, GENTEX autodim mirror w/ map lights - temp - compass, AEM CAI, COOL TECH antenna mount, THULE Rack, CIBIE, Fuel Door, Grab Handles, Tuffy Trunk/Console/Overhead, Grill mod, Olympic Reversa bars,COOL TECH Magnaflow exhaust, Parking sensors,HESCO Supercharger
1972 C104 Commando - Stock
Joec is offline
Old 01-29-2008, 04:35 PM   #47
JeepEngineers
Originally Posted by scottyc
I use my JK for work, which requires fairly frequent starting and stopping (for less than 2 hours). No this question is not about oil.
The outside air temperature sensor is set up with logic that I guess is intended to keep it from reading too hot from radiant engine heat. However, the way I use my Jeep, it will occasionally be 3:30pm and 70 degrees and the Jeep will still display 45 degrees (from 7am--the last time the requirements for updating were met).
Is there some way I can fool the temp sensor into rereading? Momentarily grounding some wire or something?
No there is no way to bypass this system ...the buffer is installed in the CCN (cluster) software...
[FONT="Arial Black"][SIZE="4"]JeepEngineers[/SIZE][/FONT] "INTRODUCING THE GREATEST JEEP[SIZE="1"]®[/SIZE] LINEUP EVER"
[I][URL="http://www.jeep.com/"]http://www.jeep.com/[/URL]
[URL="http://www.jeep.com/en/experience/community/have_fun_out_there/"]Have Fun Out There![/URL]
[URL="http://www.facebook.com/jeep"]Check out Jeep on Facebook[/URL]
[URL="http://www.youtube.com/thejeepchannel"]Check out Jeep on YouTube[/URL]
[URL="http://www.flickr.com/groups/jeepexperience/"]Check out Jeep on Flickr[/URL][/I]
JeepEngineers is offline
Old 01-29-2008, 04:36 PM   #48
JeepEngineers
Hallelujah! (Good move.) If I don't care to pay to have them color-matched, do I need a protective clear coat or will the primed state they come in be okay?
Thanks for doing this. I hope Cerberus accountants keep the price down...
Paint will depend on what you want to do - they come e-coated so they will fade in the sun unless you paint them. The price will be pretty good, considering you are buying 2 complete doors....
Old 01-29-2008, 04:37 PM   #49
JeepEngineers
Originally Posted by jeep'd
When I start my 03 TJ in very cold weather (around 20 or below), and I have everything turned off besides the engine, I hear a sound that almost sounds like a sputter or knocking which also sounds like it could be an exhaust leak where ther head meets the manifold. But as soon as it starts to warm up the sound goes away.
Is this common? And is better for the engine if I let is warm up to about 130 or so before I start the drive it, or does it even make a difference?
Sounds like an exhaust leak for sure... Not too uncommon unfortunately. As the vehicle heats up, things expand, closing the leak. Try to tighten uo the bolts carefully.. don't snap them off ! If its the header to teh block, try installing a new gasket. And take a look at the "Y" intersection of the header.. thats known to crack sometimes.
I think the service part has a flex pipe in it if the headers cracked. This helped some....
Good luck.
Oh, better to start the Jeep, idle for 15 seconds or so.. and drive it away. But not at high throttle.. just normal throttle.....
Old 01-29-2008, 04:38 PM   #50
Joec
Is there a way to disable the "LIGHTS ON WITH UNLOCK" feature? I have had both low beam elements fail within a week of each other (14 months, 33k+ miles) and I feel that feature is one reason for their early demise.
Joec is offline
Old 01-29-2008, 04:38 PM   #51
scottyc
For the left side, and 2 more for the right!
scottyc is offline
Old 01-29-2008, 04:40 PM   #52
Joec
Now that MOPAR PARTS is offering the HESCO supercharger option, is/will jeep work on a 'supercharger program' for the ECU to eliminate the TPS lamp under certain throttle transition events?
Joec is offline
Old 01-29-2008, 04:42 PM   #53
JeepEngineers
Originally Posted by JeepMan1975
I have in my disposal a salvaged production Hemi powertrain with MDS from an '08 RAM. I don't mind making my YJ drive by wire, so my question is would this be a good engine to use or should I sell it and get a mopar crate Hemi engine (though it's not street legal)?
The next question would be about how to get the Jeep to pass emissions successfully (I know the parts required of an exhaust system, just am not sure which model year parts to use). Any help is greatly appreciated.
Well, this certainly is a big project, and we are aware that there are various vendors out there offering wiring harnesses and other parts to make the swap possible.
As far as the emissions question, we can't really answer that one.....we've never certified the YJ (much less the TJ or JK) with a Hemi installed. You may also want to check your state laws to see if you are able to do this - some states won't allow a completely different powertrain from what was available stock, even if it is newer.
Old 01-29-2008, 04:42 PM   #54
JeepEngineers
this can be reconfiquered in the TIPM (total intergrated power module) this will be under the cutomer confiq section..the dealer can do this with a star scan tool..thanks
Old 01-29-2008, 04:42 PM   #55
texaskev
Haven't seen it asked here yet so here goes... Any additional motor options coming for the JK in the next year or so?
texaskev is offline
Old 01-29-2008, 04:43 PM   #56
1fastR
What would be your first "upgrade" to a TJ?
By the way, thanks for being here!
1fastR is offline
Old 01-29-2008, 04:43 PM   #57
JeepEngineers
We are not offering a HESCO supercharger.
Old 01-29-2008, 04:44 PM   #58
JeepEngineers
Uh.. well that would be future product.. can't comment.
So, what do you want ? Tell us !
[ like we cant guess lol ]
Old 01-29-2008, 04:44 PM   #59
JeepEngineers
Can't speak for everyone here, but my first upgrade to my TJ was armor...
Old 01-29-2008, 04:44 PM   #60
texaskev
I'll take a Hemmi with fries please
texaskev is offline
Closed Thread
Glock Forum
jeeppartsdept.com
Get your jeep parts here. Full line Jeep dealer. HUGE DISCOUNTS!
