> General Jeep Forums
> Jeep Engineering - Q&A
01/29 Q/A Session - Jeep Wrangler and Wrangler Unlimited
01-29-2008, 04:41 PM
#151
Originally Posted by alik
any idea why the khaki hardtop is avail on sahara but not on rubicon models?
Thats up to the Design Office guys.. they match the colors as we engineers have no taste !
I think its to match the flairs....
Everybody knows matched colors "Wheel" better !!
LOL
[FONT="Arial Black"][SIZE="4"]JeepEngineers[/SIZE][/FONT] "INTRODUCING THE GREATEST JEEP[SIZE="1"]®[/SIZE] LINEUP EVER"
[I][URL="http://www.jeep.com/"]http://www.jeep.com/[/URL]
[URL="http://www.jeep.com/en/experience/community/have_fun_out_there/"]Have Fun Out There![/URL]
[URL="http://www.facebook.com/jeep"]Check out Jeep on Facebook[/URL]
[URL="http://www.youtube.com/thejeepchannel"]Check out Jeep on YouTube[/URL]
[URL="http://www.flickr.com/groups/jeepexperience/"]Check out Jeep on Flickr[/URL][/I]
01-29-2008, 04:45 PM
#152
Originally Posted by JeepEngineers
the CCN (Cluster) software program is working properly..I know it is annoying however the cluster does not know if you are 4wheeling or stuck in LA traffick..sorry
Yes, it is working as programmed... but what I was hoping to hear is that the program could be changed to update based on different logic when the transfer case is in 4 high or 4 low.
I doubt many people are in 4 high or 4 low when stuck in LA traffic...
2002 WJ Limited, Stone White, 4.7L H.O., Quadra Drive
OME Springs, MX6 Shocks, BFG 265/70R17 All-Terrain, Level 8 Tracker Wheels
Scottsdale, AZ
01-29-2008, 04:46 PM
#153
Originally Posted by jscherb
Not engine. Sounds like it is coming from the vicinity of the bellhousing, but that's hard to tell. But not an axle-related noise, coming from the center of the vehicle. Engine mount? Trans mount? What else would twist when you step on the gas and make a rubber-like chirp?
Engine torque will rock the engine up on the left side - put it in park, engine off, hood up and gently rock the vehicle forward and back - listen for the same noise and try to pinpoint it. There is also a normal wistle on tip in with some throttle bodys.
#154
Do all Rubicon JKs have a cooler for the auto trans or just towing packag equiped ones?
08 Flame Red 2 Door Rubicon, 5.5 Rock Krawler Longarm Coilover, Fox Rear Shocks, AEV Hood & Wheels, 35" MTZ tires, Shockworks Stubby, Fab4 Rear with Spare Swingout, JE Reel Shafts... :beer:
My Rock Krawler Longarm / Coilover Install pics! http://www.jkowners.com/forum/showthread.php?t=12697
#155
Have you guys heard of (or experienced) the glitch where pressing the unlock button on the RKE will cause the Jeep to honk and the radio to come on (I guess basically the Jeep goes into 'ACC' mode)? It has happened to many of us, but very irregularly. Does it sound like this would be the RKE communications messing up, or the main computer or what?
#156
(O|||||||O)
I have a popping noise coming from under the floor towards the passenger side of the jeep. I only get it after flexing or heavy cornering (any transfer case position). Assuming everything is at the proper torque specs, what else could cause this noise? Bad U-Joint in the front driveshaft?
01-29-2008, 04:48 PM
#157
yes all rubicon auto have trans cooler.....thanks
#158
Check the trac bar .. tighten it. Side to side is usually Trac Bar
Could be the exhaust mount on the skid plate too.... look at it, make sure the isolator is there...
01-29-2008, 04:50 PM
#159
Transparent Freedom Top panels?
Some people on the board saw transparent Freedom Top panels at the last Camp Jeep. Word was that Mopar might have something this year. Any word on when?
Re: What do I want on engine options? I'd love an efficient diesel. The 4.?L Cummins we're hearing about sounds like too much for a 4200 lb Wrangler Unlimited. Something in the 2.5 - 3.0L range with at least 300 ft lbs torque at 1800 rpm.
LIQUIDS
2008 Wrangler Unlimited 4X4 - Jeep Green - 23S - Manual - Dual tops - Power group - Limited slip - 17" wheels - Side air bags - Sirius - Born 6 August 2007
1968 CJ5 - President Red - Dauntless - Ramsey PTO winch - 1980's full top - Unrestored and running (... but not stopping)
Have Fun Out There.
Jeep
#160
10 MINUTES LEFT
Ask away now !!
#161
I had a 2000TJ before I traded for my 2006 LJ. Why is the seating position so different between the two - seems like the LJ seats are an inch or two lower than the 00 TJ seats. Was there a reason for changing it?
01-29-2008, 04:52 PM
#162
2008 Sahara 4 door and LOVE it eccept for the lack of power on long hills at 40 and above. Why do the RPMs drop over 40 mph even when the foot feed is steady. You must stuff the accelorator or down shift to keep speed up. Oh automatic trans here
thanks
Sahara 4dr, Jeep Green
Loaded...the Jeep not me.
#163
Different seat tracs.. and yes, its lower on the 06...
Was an all new seat in 2003 TJ update
Yea, some have "Mentioned" this before....
01-29-2008, 04:53 PM
#164
The freedom tops - I wanna call them "Freedom View" glass tops are in developemnt and will be available - this summer or next fall. Thanks for asking.
Dauntless 225 - sounds funny thru headers!
#165
(O|||||||O)
Thanks  Now hypothetically speaking, lets assume everything is torqued down and tight. What else could cause the popping?
Just to clarify:
I get it on the first few subsequent turns taken at a slow/normal speed, following heavy articulation (flexing, heavy cornering). Then it isn't heard again till the suspension is flexed again.
