01/29 Q/A Session - Jeep Wrangler and Wrangler Unlimited - Page 10 - JeepForum.com
post #136 of 189 Old 01-29-2008, 04:30 PM
Joec
Originally Posted by JeepEngineers
How much boost are you running?
6lbs max usually. I have seen it go as high as 10. I don't push the engine hard (as in drag racing... do the stoplight drags count???) Mostly, when under moderate throttle position (35-45% throttle indicated on the ScanGauge, uphill, towing, passing), it runs 1-2lbs, and maybe 5-6 when passing. The one time it hit 10 I had it floored due to a miscalculation in oncoming traffic distance.
2007 JK Unlimited Rubicon - Greystone, Auto, Power, Tow, Leather seats, Pneumatic Lumbar support, Seat Heat, GENTEX autodim mirror w/ map lights - temp - compass, AEM CAI, COOL TECH antenna mount, THULE Rack, CIBIE, Fuel Door, Grab Handles, Tuffy Trunk/Console/Overhead, Grill mod, Olympic Reversa bars,COOL TECH Magnaflow exhaust, Parking sensors,HESCO Supercharger
1972 C104 Commando - Stock
Joec is offline
post #137 of 189 Old 01-29-2008, 04:30 PM Thread Starter
JeepEngineers
JeepEngineers's Avatar
Originally Posted by rrivas
here is what is looks like
there is a cable that has been disconnected on the inside of the seat for the headrest release...which allows the head rest to fold backwards...the seat needs to be removed and the seat material slide up to get access to the cable...the cable needs to be replaced or repaired...thaks
JeepEngineers "INTRODUCING THE GREATEST JEEP® LINEUP EVER"
JeepEngineers is offline
post #138 of 189 Old 01-29-2008, 04:31 PM Thread Starter
JeepEngineers
Originally Posted by jeepsurf
I was wheeling in my 98 TJ when all of a sudden the tcase popped out of 4 low with a loud thud. Now, the 4wd light doesnt come on. There's no noise comming from the tcase, yolks, ujoints, or driveshaft. Everything seems fine
except the light. What would be the first thing you guys would suspect?
p.s. thanks for taking time to talk with us.
Bad t case switch.. or t case lever adjustment.
Easy to fix... if you like that kind of stuff
post #139 of 189 Old 01-29-2008, 04:32 PM Thread Starter
JeepEngineers
The light is actuated by the lever actually being in the 4wd position. You may not have 4wd, even though the lever is in 4wd. Take it to a competent mechanic.
post #140 of 189 Old 01-29-2008, 04:33 PM
jscherb
?? Is it in the engine or drivetrain ? noise under the vehicle ?
Not engine. Sounds like it is coming from the vicinity of the bellhousing, but that's hard to tell. But not an axle-related noise, coming from the center of the vehicle. Engine mount? Trans mount? What else would twist when you step on the gas and make a rubber-like chirp?
jscherb is offline
post #141 of 189 Old 01-29-2008, 04:33 PM
Panici
(O|||||||O)
Panici's Avatar
OH.. you're talking about it popping out of gear, right ? There was a TSB to help address this. BUT< not sure it would be covered now?
Bet its a violent pop out event, right ???
Well the gear is just beginning to engage (moving from N to 2), so i'm not sure if that would constitute 'popping out'. I wouldn't call it violent, but enough to feel. If I pause my shift for a second it just slips into gear like nothing happened.
I have the 7 year powertrain warranty, so I believe it may still be covered, but i'd rather fix it myself if possible.
_______
|_
_|
(OlllllllO)
Panici is offline
post #142 of 189 Old 01-29-2008, 04:34 PM Thread Starter
JeepEngineers
I say take it to youyr dealer.. use the warrenty. They might just swap the trans !
post #143 of 189 Old 01-29-2008, 04:35 PM Thread Starter
JeepEngineers
Originally Posted by Tadpole911
I have a 2dr 08 X model with an auto transmission. Twice, I've heard a ding / chime with no other indication of something wrong. It happened once while turning right @ ~10mph and another time traveling at a constant 45mph. The dealer says no codes have been set.... What do you think?
I would look at the TPM (tire pressure monitor) will ding and not set a code I would recommend that the dealer make sure the WCM antenna is properly routed in front of the shifter ,,,,there is a TSB on the antenna routing
post #144 of 189 Old 01-29-2008, 04:36 PM
Photojeep
Photojeep's Avatar
Just out of curiosity, what departments or sections of the jeep do you guys work on? Like, are some of you in the room engine or tranny or suspension engineers or do you all wear all of the hats?
Driving a Wrangler makes going to work feel like you're going camping.
Photojeep is offline
post #145 of 189 Old 01-29-2008, 04:37 PM Thread Starter
JeepEngineers
Several areas.. PR , Vehicle Development.. Mopar Jeep Performance, Electrcal, powertrain.
A real misfit crew !
post #146 of 189 Old 01-29-2008, 04:39 PM Thread Starter
JeepEngineers
Originally Posted by jdrogers
I would like to ask about the outside temperature in a different situation.
When I have been on full day off roading trails (like the Canyon de Chelly Jeep Jamboree) and spend the entire day running less the like 15 mph, the temperature doesn't ever change. In the afternoon, when it was clearly like 70 degrees outside, the display still showed something silly like 45 degrees which was the temperature in the morning when we started.
Can you guys correct the programming to sense the temperature all the time when in 4 wheel drive?
the CCN (Cluster) software program is working properly..I know it is annoying however the cluster does not know if you are 4wheeling or stuck in LA traffick..sorry
post #147 of 189 Old 01-29-2008, 04:39 PM Thread Starter
JeepEngineers
Originally Posted by JeepMan1975
I have in my disposal a salvaged production Hemi powertrain with MDS from an '08 RAM. I don't mind making my YJ drive by wire, so my question is would this be a good engine to use or should I sell it and get a mopar crate Hemi engine (though it's not street legal)?
The next question would be about how to get the Jeep to pass emissions successfully (I know the parts required of an exhaust system, just am not sure which model year parts to use). Any help is greatly appreciated.
Sorry, But we don't have ready access to the laws in your state, so I can't answer that question. The engine would be a great project to build, but if you are going to use it on the street, check with your local DMV first about registering it!
post #148 of 189 Old 01-29-2008, 04:39 PM Thread Starter
JeepEngineers
Originally Posted by jeep'd
I recently purchased an 08 unlimited with the freedom top. Did you guys experiment with deferent types of tops and the chose that one, or was this the only one on the drawing board and you were just perfecting it? Did you concider a 5 for the unlimited to give more removal options or no?
Because I'm interested in buying the JK as soon as it comes with a diesel, and a 5 piece hard top would be nice as well
Our group here consists of various disciplines and some of us are involved with future product but as you are probably aware, we cannot talk about future products or ideas. We can say that we looked at different ideas for the top before coming up with the Freedom Top and we're very pleased with the tremondous success it is having in the marketplace. We are always considering new ideas and appreciate your suggestions. Thank-you !!
post #149 of 189 Old 01-29-2008, 04:39 PM
alik
any idea why the khaki hardtop is avail on sahara but not on rubicon models?
alik is offline
post #150 of 189 Old 01-29-2008, 04:41 PM Thread Starter
JeepEngineers
Originally Posted by 1fastR
How much input do you guys have on what future products are released?
Although we can't comment on future products, I can tell you designing the vehicle is a team approach with input from many groups ....all with the goal of satisfying our customers. And since all of us are Jeep advocates, you can be sure our voice is heard!
Closed Thread
09/29 Q/A Session - Jeep Wrangler and Wrangler Unlimited JeepEngineers Jeep Engineering - Q&A Archive 300 09-29-2009 05:03 PM
09/09 Q/A Session - Jeep Wrangler and Wrangler Unlimited JeepEngineers Jeep Engineering - Q&A Archive 160 09-10-2008 02:59 PM
05/13 Q/A Session - Jeep Commander JeepEngineers Jeep Engineering - Q&A Archive 92 05-13-2008 05:10 PM
07/12 Q/A Session - Wrangler and Wrangler Unlimited JeepEngineers Jeep Engineering - Q&A Archive 285 07-12-2007 07:22 PM
03/14 Q/A session - 2007 Wrangler JeepEngineers Jeep Engineering - Q&A Archive 329 03-22-2007 06:58 PM
You may not post new threads
