Quantcast 01/29 Q/A Session - Jeep Wrangler and Wrangler Unlimited - JeepForum.com
Go Back JeepForum.com > General Jeep Forums > Jeep Engineering - Q&A > 01/29 Q/A Session - Jeep Wrangler and Wrangler Unlimited
Closed Thread
Old 01-29-2008, 03:54 PM   #1
JeepEngineers
PLEASE READ BEFORE POSTING
This Q/A Topic: Jeep Wrangler and Wrangler Unlimited
· Direct your questions to the JeepEngineers team
· Let the JeepEngineers team supply the answers
· Keep all questions on topic and related to the Jeep Brand. Off-topic posts run the risk of being removed by forum moderators
· Limit each post to one question. This makes it a lot easier for us to manage during the session and a lot easier for readers to digest afterwards.
· Review existing posts to avoid repeat questions.
· Questions aren’t answered in order of post; you’ll need to allow some time for us to respond.
· There is no need to repost a question. At the end of the session, we check for unanswered posts. An answer will be posted in reply IF the question is on topic and is not redundant.
· If you have something to say to one another we ask that you communicate via PM or within another thread discussion.
· We can’t answer questions regarding Specific Dealer concerns or Future Products
· We’ll do our best to help, but we are not always able to diagnose specific vehicle issues over the internet
Go ahead and post your questions!!
[FONT="Arial Black"][SIZE="4"]JeepEngineers[/SIZE][/FONT] "INTRODUCING THE GREATEST JEEP[SIZE="1"]®[/SIZE] LINEUP EVER"
[I][URL="http://www.jeep.com/"]http://www.jeep.com/[/URL]
[URL="http://www.jeep.com/en/experience/community/have_fun_out_there/"]Have Fun Out There![/URL]
[URL="http://www.facebook.com/jeep"]Check out Jeep on Facebook[/URL]
[URL="http://www.youtube.com/thejeepchannel"]Check out Jeep on YouTube[/URL]
[URL="http://www.flickr.com/groups/jeepexperience/"]Check out Jeep on Flickr[/URL][/I]
JeepEngineers is offline
Old 01-29-2008, 03:58 PM   #2
scottyc
Selec-Trac (full-time 4wd) in the JK fits with the Jeep image better than 4x2, and that is already offered. Would you guys like to see a full-time option for the Wranglers or do you feel the part-time 4x4 is option enough for the model?
scottyc is offline
Old 01-29-2008, 04:00 PM   #3
jeepsurf
Hey guys.
I've recently aquired a 1990 2.5L YJ. There's the remnants of what looks like a metallic pipe comming from the exhaust manifold and maybe going to the air box. Is this something I need to replace or can I just cap it off?
jeepsurf endorses this post. Most of the time
Admin, nightcrew.org
1990 2.5 YJ / 1997 2.5 TJ
USAF VET
My YJ build thread HERE.
Nightcrew alive and well, now on VB 4.0 HERE.
Food mailed 3ooo milesHERE.
jeepsurf is offline
Old 01-29-2008, 04:03 PM   #4
JeepEngineers
Originally Posted by jeepsurf
Hey guys.
This is the hot air supply tube that helps the engine run better in cold weather. They're relatively inexpensive to replace, and we'd recommend doing so. On the the air cleaner end of the tube, there should be a vacuum solenoid that closes off the hot air supply once it's warm enough. Make sure this works too.
Old 01-29-2008, 04:05 PM   #5
JeepEngineers
Hey guys.
Is the tube about 2 1/2 inches in diameter.......mark
Old 01-29-2008, 04:05 PM   #6
Timothy
2008 Jeep Wrangler Sahara
Hello Gentlemen:
Regarding the hard top design flaw in the 2007 and 2008 Jeep Wrangler Sahara models---water is pooling on the dashboard, I would like to know:
Are you aware of this problem?
Is there a plan to fix this flaw?
Thank you.
Timothy is offline
Old 01-29-2008, 04:06 PM   #7
grogie
Too little time
grogie's Avatar
I have read here at JF about getting "angry sparrows" and that it's typically caused by the center ball joint on the front drive shaft. On rough roads this winter I am starting to hear those chirping birds up front on my '06 TJ (with 12,000 miles), but not so much on smooth pavement. So if it is the center ball joint, would I begin to hear it more on a rough road then on smooth pavement?
Thanks!
Red Jeep Club #345
2006 TJ Sport
2004 KJ Limited
grogie is offline
Old 01-29-2008, 04:06 PM   #8
JeepEngineers
Would a full-time 4WD system be something that would be of interest to you? If so, why?
Old 01-29-2008, 04:07 PM   #9
jeepsurf
yep the opening is. the tube is totally gone.
USAF VET
jeepsurf is offline
Old 01-29-2008, 04:09 PM   #10
jscherb
Guys,
I'm planning on stretching my LJ and building a retro-looking stepside pickup out of it.
To stretch the frame, I've got a second LJ frame; but cutting the two frames in different places and joining the longer "halves", I will gain 24". The vehicle frame will be cut just before the frame turns up to go over the rear wheels; the second frame will be cut just before the frame rails bend in (about 24" ahead of the first cut).
The Brute kit stretches the TJ frame 24" and apparently then don't have issues with excessive frame flex; this would stretch the LJ frame 24" (roughly the equivalent of stretching the TJ frame 34-36").
Do you have an opinion on the flex and strength of the frame that will result from the lengthening I've described? Do you think I should plan an additional crossmember to stiffen the longer frame?
Some photos of the concept model for my conversion are shown below...
Jeff
jscherb is offline
Old 01-29-2008, 04:10 PM   #11
BlueRidgeJK
The 2007 and 2008 Wranglers including the Unlimited have had a lot of problems with leaks in the soft tops, hardtops, door seals, header seals. Does Chrysler/Jeep recognize these problems and are they actively addressing them?
BlueRidgeJK is offline
Old 01-29-2008, 04:10 PM   #12
JeepEngineers
Thanks!
Generally - A "Squeaking" noise in the front driveshaft is a U joint having issues. I am assumming this is not a Rubicon ? Correct? Check the U joints for water/mud intrusion.
Old 01-29-2008, 04:13 PM   #13
grogie
Too little time
grogie's Avatar
Personally, my wife and I use the Selec-Trac's full-time in our Liberty often, anytime the roads are wet. In fact we recently drove 2,600 miles to Colorado and back with our Liberty, and kept the "full-time" engaged for 70% of the trip do to mixed winter road conditions. It's a great option to have, and I can see why it would be nice to offer Selec-Trac in the JK's.
Red Jeep Club #345
2006 TJ Sport
2004 KJ Limited
grogie is offline
Old 01-29-2008, 04:13 PM   #14
JeepEngineers
this tube is for emmissions and also for proper choke operation...the hot air tube is made of corregated aluminum and makes the thermac work properly in the air cleaner assy...when the vehicle is cold the flap door on the aircleaner intake is closed and draws the hotair past the exhaust manifold until the sensor reaches a predetermined tempature and actuates the vacuum to open the door in the air cleaner intake...this will help on fuel economy on cold starts
Old 01-29-2008, 04:14 PM   #15
scottyc
I've already got my 4x4 JK Unlimited and I'm planning on holding on to it for a long time, but, yes, I think a full-time option would be of interest to the market. The JK is reaching new markets with the nicer ride, nicer interior (relatively speaking), four doors, etc. I think there are definitely buyers who would never mess with the part-time 4wd, but would like to be able to say power goes to all four wheels. I think Jeep agrees that such a 'demographic' exists, since the KK/WK/XK all offer a full-time system.
Obviously, as long as the JK is selling like hot cakes, there's not much of a business case for a new transmission. I was really just curious about what you guys as engineers thought about having a full-time option.
scottyc is offline
Closed Thread
Glock Forum
