wingless' Factory Transfer Case Skid Plate Well Nut Replacement - JeepForum.com
post #1 of 4 Old 09-26-2015, 05:24 AM Thread Starter
wingless
wingless's Avatar
1994 ZJ
wingless' Factory Transfer Case Skid Plate Rivet Nut Replacement
My vehicle was special-ordered w/ the Up Country Suspension Group.
That includes the skid plates, for the front suspension, the gas tank and for the transfer case.
My transfer case skid plate has remained in my garage for years because the rivet nuts used to retain the bolts into the blind holes on the transmission crossmember and on the "frame" tube had deteriorated and failed.
My attempts to replace these rivet nuts had been unsuccessful. The factory documentation shows usage of a special tool. Without that tool, I tried using the bolt and a wrench to bulge the nut, no good.
Now the Mopar M10-1.5 rivet nut parts are almost made from unobtaineum. I found one vendor. They have only ten of the Mopar 6502 662 rivet nuts remaining in-stock (edit, they are now out-of-stock). I have not found anyone else w/ this Mopar part.
There are other vendors with an M10-1.5 rivet nut in their catalogs, in steel, stainless steel or aluminum, but I don't know the availability or the Minimum Order Quantity. The steel OEM Mopar 6502 662 rivet nut dimensions are: OD - 12.45mm; Body Length - 16.80mm; Head Diameter - 13.63mm; Head Height 0.82mm and thread size M10-1.5 ISO. Here is a vendor listing a compatible part. There are several M10-1.5 rivet nut parts available from McMaster-Carr in steel, stainless and aluminum. None of the McMaster-Carr steel parts have identical dimensions to the Mopar 6502 662 part, but could probably be made to work. The Mopar rivet nuts bulge like an inner tube when set, the low-profile McMaster-Carr parts look like they telescope instead of bulge.
A special rivet nut tool was designed and fabricated to install this M10-1.5 rivet nut. It is very similar to this tool except mine works w/ this M10-1.5 fastener.
There is now a reasonably-priced M10-1.5 rivet nut tool available from McMaster-Carr.
My custom sliding ramp tool that was fabricated worked exceptionally well! The rivet nut fasteners all seated properly into their blind holes.
My transfer case skid plate has been properly replaced and is secure. Normal vehicle service required removal and replacement of that skid plate several times and zero issues were encountered.
M10-1.5 Rivet Nut and Transmission Cross Member Blind Hole
Custom Rivet Nut Tool
Tool at Start Position
Tool at Finished / Bulged Position
Bulged Rivet Nut
Transmission Cross Member w/ Two New M10-1.5 Rivet Nuts
*GIF image credit to RivitNutTool.com
Last edited by wingless; 07-27-2017 at 09:52 AM. Reason: Replaced PB extortion w/ Flickr
wingless is offline
post #2 of 4 Old 09-27-2015, 09:11 PM Thread Starter
wingless
wingless's Avatar
1994 ZJ
The 6502 662 rivet nut is used on my 1994 ZJ Grand Cherokee to attach the factory transfer case skid plate.
This is a three-point attachment, w/ two fasteners in the transmission cross bar and the third in the driver's side "frame" tube.
wingless is offline
post #3 of 4 Old 10-19-2015, 10:14 AM Thread Starter
wingless
wingless's Avatar
1994 ZJ
When I examined the factory-installed rivet nuts, then compared them to those I installed, I found that the factory barely bulged the rivet nut and I bulged the nuts to a much greater amount.
This is determined by examining the distance from the surface to the threads on the factory-installed rivet nut and on the rivet nuts that I installed.
Also, this factory-installed rivet nut that I removed shows very little bulge. This rivet nut worked okay until I drilled it out for removal, then it spun w/ the drill bit.
My latest experience w/ my tool revealed that it is MUCH easier to bulge the rivet nut while under the vehicle and the blind hole overhead. I used my floor jack and a socket to push the tool hard up against the vehicle, then rotated the bolt pulling the wedge to bulge the nut.
That worked GREAT!
The nut was rotated until the torque increased, by feel, then I stopped attempting the bulge the nut.
All three rivet nuts were inspected and all appeared identical for the distance from the threads to the surface and the interior appearance of the bulge.
This shows the transfer case skid plate mounted back onto the vehicle.
Last edited by wingless; 07-27-2017 at 02:39 PM. Reason: Replaced PB extortion w/ Flickr
wingless is offline
post #4 of 4 Old 07-27-2017, 02:55 PM Thread Starter
wingless
wingless's Avatar
1994 ZJ
The topic was reworked to replace the PB extortion images w/ Flikr images.
wingless is offline
Closed Thread
You may not post new threads
