U-Pol Raptor Install (This stuff rocks!) - Page 2 - JeepForum.com
Go Back JeepForum.com > General Technical Discussions > Technical Articles & Write-Ups > U-Pol Raptor Install (This stuff rocks!)
Yukon Zip Lockers FREE AIR COMPRESSOR AND ROCKRIDGE REBATEFree arb compressor with puchase of arb locker!!! Limited Nitro Gear Packages Now Available at Rockridge 4wd
Unread 08-23-2011, 06:52 PM   #16
mapitre42
after such a long time is it still holding up well?
mapitre42 is offline   Reply With Quote Quick reply to this message
Unread 08-24-2011, 08:09 AM   #17
Jeepish
1984 CJ8
Yes. Since the original install, I also used it on the radiator shell and the underside of my hood.
Well worth the money.
WTF-J - Bobbed Alu CJ-8 w/6.0L Gen-III, Atlas, AiRock, & ARB'd D60s
Jeepish is offline   Reply With Quote Quick reply to this message
Unread 08-29-2011, 04:57 PM   #18
chewy0288
looks good. this is a little off topic, but do you know the brand of the taillights you have or remember where you got them?
chewy0288 is offline   Reply With Quote Quick reply to this message
Unread 08-30-2011, 06:13 PM   #19
Jeepish
1984 CJ8
They're just 4" truck LEDs. The trick is that they're in a reflex (reflector) flange. (This is slightly different, but the same idea. http://www.uatparts.com/miva/merchan...y_Code=UAPTURN)
Unread 10-09-2011, 08:06 PM   #20
gatorjeep11
What is the best way to clean up over spray off of paint.
gatorjeep11 is offline   Reply With Quote Quick reply to this message
Unread 10-11-2011, 10:28 AM   #21
Jeepish
1984 CJ8
By the time you read this it may already be too late, but the answer is acetone.
Unread 10-11-2011, 02:42 PM   #22
04WJny
1987 YJ Wrangler
Nice write up. I definitly have to make some time to do this
2004 WJ I6 4.0L DD
1987 YJ I6 4.2L Weber 34 DGEC carb, 4in RC, Custom 1 inch BL,Custom Steering box skid, homemade rear bumper with tire carrier, 33x12.5x15 KM2's on
Cragar Soft 8's, and a few other things
In the process of putting in an 8.8, d30, 4.10's, SOA, and a homemade belly up skid
[CENTER][URL="http://www.jeepforum.com/forum/f22/sloooooow-blue-yj-build-1234350"]My YJ Build[/URL][/CENTER]
04WJny is offline   Reply With Quote Quick reply to this message
Unread 11-28-2011, 04:08 PM   #23
meangreeny
used this product one year ago, no floor mats or carpet and it still looks great.
meangreeny is offline   Reply With Quote Quick reply to this message
Unread 03-20-2012, 10:05 PM   #24
Kastraelie
1977 CJ7
So who has used this stuff AND herculiner? I did my YJ years ago with Herculiner and that stuff was awesome. Held up great with zero priming, and although it was in the Texas sun without a top on for six years I never had UV fading. I did use some armoral spray on it every now and then when I washed it (THAT didn't happen often xD).
Anyways, great writeup, OP! Just would like to know who has used/experienced both and what they recommend in the end.
Kastraelie is offline   Reply With Quote Quick reply to this message
