Quantcast U-Pol Raptor Install (This stuff rocks!) - JeepForum.com
Go Back JeepForum.com > General Technical Discussions > Technical Articles & Write-Ups > U-Pol Raptor Install (This stuff rocks!)
1984-2001 Jeep XJ Cherokee Lift Kits 3-4.5" with FullIntroducing MONSTALINER™ UV Permanent DIY Roll On Bed LineSpartan Lockers FREE SHIPPING Excellent Prices
Old 09-29-2009, 10:47 AM   #1
Jeepish
1984 CJ8
The WTF-J's bare aluminum tub floor wasn't getting it anymore and needed something. I got an $800 quote from Line-X for lining the tub, but that was contingent on:
1. Stripping EVERYTHING out of the tub
2. Priming it with self-etching primer
3. Hauling it to their shop and leaving it 'til they got a round tuit
Since I was going to have to tape and mask the tub to spray the primer, it was time to look at DIY options.
Herculiner - Low cost, local availability, but so-so appearance and not UV stable without topcoat
Duplicolor - Not many enthusiastic reviews
SEM - Their paint is good, but couldn't find many Web write-ups on installs or lessons learned
Al's Liners - I would have used this 4K material if I had not found so many successful Raptor installs. Very enthusiastic following.
U-Pol Raptor - Reasonable cost (~$150 inclusive) Great DIY results.
Having picked U-Pol Raptor, here is what I learned:
* Prep is everything. Yeah, yeah, yeah, that's true with any paint job, but it's true. Resign yourself to taking the time to strip the tub carefully and use the opportunity to fix/upgrade the nit things that you've been putting off. In my case, I reworked some wiring, fixed a problem with the keeper strap on my tube doors and fabbed a bezel for the boot around the T/C shifters
* Spray Raptor in a well ventilated area and wear at least a half mask respirator, as spraying it kicks out serious fumes.
* U-Pol is a great chemical company, but their bedliner kit marketing needs work. The Raptor bedliner kit includes four .75 liter bottles of material plus a liter of catalyst. Some of their kits include the needed Schutz gun, but others do not. (It is almost impossible to know from the part number whether the kit you order includes the gun or not, and the Raptor bottle is taller and has a smaller diameter cap than the "standard" Schutz gun bottle. Lesson learned, ask your dealer! )
* If you don't have Xylene, U-Pol won't tell you, but Raptor can easily be cleaned with Acetone
* Taping and masking is the same for Raptor as it is for regular paint. (i.e. You don't need wire tape) Pull the tape 15-20 min after applying the 2nd coat and the Raptor edge will soften slightly to blend into the unpainted area.
* Keeping the gun moving and >12" from the surface provides a typical spray in bedliner texture.
* The directions say to simply top off the 750ML paint bottles to the "A" mark with the included catalyzing agent, but I never could find it. Get a graduated .5L cup from the paint store to measure a 250 ML portion; it's easier.
I started with the bare bed. Scuffed it with a DA and 50 Grit. Anything that I couldn't reach with the DA got hit with a green Scotch-brite pad. After that 2x pressure washing with Simple Green and then a wipe down with Prep-Sol (Wax/Grease Remover).
This was a great opportunity to “fix” the rivets on the tailgate before covering them with the bed liner compound. The issue is that the tailgate design requires the back side of the pop rivet to be exposed along the hinge. A hammer and dolly makes quick work of the exposed "tail"
Stripping the tub, taping and masking is a drag, and that was a big part of the decision to do it myself. (BTW, the Orange/Purple dots are ear plugs that are stuffed into threaded holes in the tub.
Since I was starting with bare metal, U-Pol's tech support wanted to see self-etching primer. (Same deal as Line-X/Rhino) I learned the hard way that the bobbed CJ-8 tub needs TWO quarts. (Fortunately, I was spraying while the paint shop was open.)
NOTE: Everything up to this point would be required even if I was ready to pay Line-X the quoted $800.
The first coat consumed the entire 4L of material. Unlike the primer, I figured that as all the Web installs were good with 4L, I would double down and use the excess for the exterior wheel wells.
After waiting the recommended 75 min flash time, it was time for the second coat. 2L later, the job was done!
Like the other guys on the Web, I was real pleased with the results.
All told, I'm into this for $275 including ALL the prep and peripheral materials. Considering that the U-Pol Raptor only added about 3 hours and $225 to the process, it was definitely worthwhile.
BTW...
Here are the quick fix items
Clean up some under dash wiring and fab a relay block (Time to activate the cruise control that exists within the Drive by Wire ECM)
Rubberized coating on the safety harness anchors (Quiet down the rattling), same deal for the base of the Hi Lift.
The open air WTF-J is tough on black oxide finished hardware. Made up a painting jig out of a scrap 2×4 and problem solved. Added a “collar” to the restraining strap post on the tube door
Fabbed a bezel for the Atlas T/C shifter boot. Bolt heads easily cut through rubber material with or without washers.
And now all the kings horses and all the king’s men will spend the weekend putting the WTF-J back together again.
Jeepish is offline   Reply With Quote
Old 09-29-2009, 08:48 PM   #2
KnacK
Good job!
Chris
'88 YJ Laredo, Hardtop
Red
4.2L Auto 190k miles
3" Body Lift, Rancho Shocks, 31" Wranglers
Sagging springs
Bald tires
Blown tranny
Dead 4.2
Empty wallet
KnacK is offline   Reply With Quote
Old 10-05-2009, 04:45 PM   #3
McKBrew
I Live, I Ride, I Am
Looks like this product is the way to go at an affordable cost. Sometime next year I'm pulling the carpet out of my 4 door JK and doing this. Jeep carpet is terrible in regards to holding in sand and dog hair, and it's next to impossible to get it all out.
McKBrew is offline   Reply With Quote
Old 10-07-2009, 08:36 PM   #4
mscottz
2011 JK Wrangler
I did mine a few weeks ago. While I was spraying it, I went ahead and pulled the headlight rings off and sprayed them too. Looks pretty cool.
Colorado Jeep Club member #1969
mscottz is offline   Reply With Quote
Old 10-13-2009, 12:38 PM   #5
KDog223
I really like the bad-***, all business look of your interior.
KDog223 is offline   Reply With Quote
Old 10-19-2009, 02:00 PM   #6
Zone
Vendor
Zone's Avatar
I'm glad it worked out for you and you're happy with the results, but when comparing to LINE-X, you're not really talking apples to apples.
Raptor's VOC content is fairly high, like 30 or 40% (if I remember correctly) meaning that one gallon only has about 70% bedliner solids, the rest evaporates away. You paid about $150 for a one gallon kit. OK, so, Raptor states one gallon will do 125 sqft. Using a universal formula, the thickness will be 14.76 mils assuming Raptor is 30% solvents.
LINE-X does not contain any solvents. Any LINE-X dealer would plan on spraying at least 1/8" or 125 mils. So, to get the equivalent thickness in Raptor, you'll need to buy 8.47 gallons of Raptor which is going to be $800-$900. To get 125 mils of LINE-X, 19.48 gallons would be applied (9.74 gallons of resin and 9.74 gallons of isocyanate).
OK, maybe you didn't want to spend $800 and maybe you don't want 125 mils, but you can't really compare a one-gallon Raptor job to a 125 mil LINE-X job.
Zone is offline   Reply With Quote
Old 10-21-2009, 10:45 AM   #7
cormac827
wow they were taking you to cleaners. I got a quote for them doing my jk...if i removed interior, no prep just removing everything except drivers seat they quoted me 600. and that was for a four door jk. i wanna get my yj done but id prolly do myself if i could get the time! i love your dash.
cormac827 is offline   Reply With Quote
Old 10-30-2009, 12:35 AM   #8
default_user2
I've had it on mine for a few weeks and I really wish I would have done Linex. While it looks good, it scratches very easily and if it's metal on it, it will gouge it. Nothing in comparison to the durability of linex. I'll just baby it I guess, but kinda defeats the purpose of bed linering it.
default_user2 is offline   Reply With Quote
Old 03-15-2010, 01:32 PM   #9
dmcfla
1978 CJ5
Raptor
Used Raptor myself. In fact if it wasn't painted and that was just the body, it was sprayed with Raptor. One heck of a easy to use product.
dmcfla is offline   Reply With Quote
Old 04-06-2010, 07:40 AM   #10
JeepJeep01
Looks great ! I have been looking into U-Pol Raptor, I have a 99 TJ, any down side to lining the tub and going carpetless ?
JeepJeep01 is offline   Reply With Quote
Old 04-06-2010, 11:43 AM   #11
2006_Sport
Tip, if you guys ever get the raptor really dirty, spray off as much as you can with a hose, let dry then apply armor all foaming tire cleaner. It works wonders. I applied it yesterday my raptor was brownish and dirty, i applied let sit for 2 mins and wiped off and it was black again.
SUPPORT THE TROOPS
2006 Jeep Wrangler|BDS|BFGoodrich|Uniden|Upol|HiLift|Cragar| Hella|Alpine|JKS|PoisonSpyder|Delta|Aussie Locker|Bluetorch Fab|Novak|Trail Gear
-Zach
2006_Sport is offline   Reply With Quote
Old 04-07-2010, 05:15 AM   #12
dmcfla
1978 CJ5
I just don't understand. I used Raptor at a cost of $118.00 (gun included). It's been on the Jeep for about 9 months now and had the h*** beat out of it with no problems. In fact like I said before - if it wasn't painted it got sprayed with Raptor. I'm talking of the complete bottom, inside and every thing you can bolt on to it. The front bumper has pushed down small trees and been through just about everything. We also painted my son's front & rear bumper. This was one kit and we had about 1/3 bottle left so I painted my riding mower.
Old 09-30-2010, 01:12 PM   #13
JimmieTJ
Newb
JimmieTJ's Avatar
I just bought this stuff and am excited to get it done. This will be the first thing in long build, so I will probably start a thread and post the pics.
/l ,[____],
l---L -OlllllllO-
()_)-()_)-o-)_)
Low Output 4 Cylinder Jeep Club member #213
Gun Metal Blue Jeep club member #22
My build thread - http://www.jeepforum.com/forum/f22/my-gun-metal-monster-1110683/
Originally Posted by 1222 View Post
Not sure if this is in the owner’s manual, (too lazy to look – just being honest) but how would you get out of your Jeep if the power went out and you were locked inside? Assuming you have the power windows and locks of course.
:dunno:
JimmieTJ is offline   Reply With Quote
Old 10-31-2010, 02:11 PM   #14
kirkmoody
1979 CJ7
it does work great just dont stack it on it will peel off in big sheets
kirkmoody is offline   Reply With Quote
Old 12-07-2010, 06:14 AM
andreabra5
This message has been deleted by AmbuGrl. Reason: spam
Old 12-16-2010, 09:57 AM   #15
CarbRage
2009 JK Wrangler
I just did the inside cab of my plow truck with the SEM Primer and U-POL and it came out great. The kit came with 4 bottles wich was good for me but i cant see 4 being enough for an 8ft bed.
Civil Disobedience Is Still Disobedience ---Maddox
CarbRage is offline   Reply With Quote
Old 03-30-2011, 02:12 PM
D3sycwd410
This message has been deleted by AmbuGrl. Reason: Spam
Old 04-08-2011, 12:55 AM
bssnike001
Glock Forum
