| Wild Boar Products Cargo Rack or Front Bumper Giveaway |
| Register | FAQ | Search | Today's Posts | Mark Forums Read | Search Members |
Thread Tools |
| #1 | |||
Registered User | Reduce Underhood Temps- Exhaust Wrap
| #2 | |
Registered User | Fantastic idea. I have a question and a suggestion. 1. suggestion: If you're in need of a new exhaust manifold that's the best time to do this operation. Before you replace it, you can prep the new one in this manner and save the down time on your engine. 2. question: The floor boards get pretty hot all ready, now that you have yours installed do you notice any more heat in the area of your feet? This would be the first place along the exhaust line that wouldn't be covered and I'm guessing that a lot of the heat that used to excape in the engine compartment is now under the floor boards baking the underside of the tub? If so how do you take care of that heat issue? thanks for the article, very good, well thought out and good pics to go along with it. Meech __________________ http://www.lowcountrymudrats.com/index.html |
| #3 | ||
Member | I did this to my new pacesetter header and all the fiberglass did was become a sponge for everytime i hit deep water and seriously my two month old header rusted so badly one of the pipes fell out. So I had to replace my two month old header...Its great for heat but not if you do any water crossings __________________ Quote: "If it aint broke fix it till it is!" spinners Quote:
www.indyorv.com | |
| #4 | |
Registered User Join Date: Apr 2007 Location: Perth, Western Australia Posts: 8 | i too did the heat wrap on my stainless steel header. it rusted so bad and the tape became so brittle it fell off in chunks. eventually the header cracked and had to be replaced. |
| #5 | |
Registered User | heat problems Not sure why your having problems? We have 97 with the il6 lifted with 31's and it always runs the same. |
| #6 | |
Registered User | heat problems Not sure why your having problems? We have 97 with the il6 lifted with 31's and it always runs the same with 160k runs like new |
| #7 | |
Registered User | wow pretty sick man any outcome? |
| #8 | |
Registered User | I did this to my headers and my exhaust all the way back to the muffler in my CJ. Awsome. It dropped the under hood temps. I did the exhaust because I didnt like how close it came to some of the fuel and brake lines. Dropped the temp a lot ont pipes. I can touch them after the Jeep is running without getting burnt. Worth it 100% in my book. |
| #9 | |
Registered User | i dont have experience with header wrap on a jeep, but on the formula sae team at my school, we used header wrap on the race car until we realized that the header wrap keeps the heat in the pipe and our exhaust got so hot that we managed to crack our titanium header. After discovering this, we talked to a guy at a custom motorcycle shop in the area who said that it was almost unheard of to use header wrap on bikes. The high temps in the pipes tend to make them brittle and susceptible to cracking. hope this helps |
| #10 | |
Registered User | A lot of bikers use heat wraps on their exhaust to keep the heat in the pies as 1997TJWrangler mentioned. That heat has to go somewhere and hopefully out the back of your exhaust but it will radiate within the pipes. I imagine the reason why his headers cracked is because of the high performance engine and RPMs that come out of a racing engine. With water, yes you're going to trap the moister under the wrap and over time it will corrode the work you did so fording may be out of the question if you do this. This is common with bikers who wrap and wrap but forget that over time despite the air cooled engine/headers you still have rain that the bike was in, washes, and the constant high RPMs. Its a choice to make. I see the benefits with wrapping in reducing exterior heat radiation which affects overall immediate performance but what about the long term affects? Hopefully the OP will let us know. Great job on covering all the bases with removing the oxidation and applying a preventive coat, despite the rattle can it looks very professional and definitely would work. I'd be interested in knowing the affects of using it over time and in what conditions. |
| #11 | |
Registered User | I see that this is a little old, but in case anyone reads this in the future, I just want to make sure they make an informed descision. I've always heard that header wraps are BAD NEWS!!! They keep TOO much heat in, and the header can't handle it, and will crack. And from what I hear, the Jeep 4.0 header is already a little prone to cracking. I know, the first time I heard that I was like "whatever", but I've read plenty of articles since then that have changed my mind. In fact, most header manufacturers will VOID the warranty if there is any evidence that header wrap was used. Here's one article I managed to go back and dig up http://www.centuryperformance.com/exhaust-header-heat-wraps-do-not-use-spg-138.html I'm not saying there may not be benefits to it too, but to me the drawbacks are far worse. You make your own descision on your Jeep, but hopefully make an informed one. __________________ '97 TJ, 4.0 auto, Jeep newb, So far: RC 4" X-series lift and SYE/CV Swamper LTB 34x10.5 & Blackrock 15x8 |
| #12 | ||
Registered User | Quote:
