How to replace and axle shaft and/or a wheel hub bearing assembly - Page 2 - JeepForum.com
post #16 of 28 Old 03-07-2012, 11:35 AM
BoostinChick
Bringing this up from the dead. First wanted to say great write-up and pictures! My only question regarding this is did you guys put a dab of grease on the axle spindle where it meets the hub?
1998 Jeep Grand Cherokee 5.9L
BoostinChick is offline
post #17 of 28 Old 03-12-2012, 09:40 PM
VikingR1
Yeah. I did. Just to ease it in.
VikingR1 is offline
post #18 of 28 Old 09-03-2012, 03:12 AM
Tulp
thanks this was super helpful. did both of mine today. hubs that is...
was a weird thing. lots of wawa noise and some vibrations but no wheel play. it fixed it though.
now time for new tires.
Tulp is offline
post #19 of 28 Old 10-28-2012, 10:26 AM
papitt
Thanks for that link .. Those pictures will help a lot. Good write up .
.I should be cble to do that with no problem other than breaking loos the 36MM . I understand how that could cause issues . I do have a CP 1/2 air wrench and also a 3/4 drive air wrench . But my compress is getting weaker . So I now have a 2nd compressor I can plug both together if need .
.. Also Back at work a lot of those wheel bearing hubs were a bugger to get out . Anyone had that Issue .
papitt is offline
post #20 of 28 Old 11-23-2012, 09:35 PM
eastcoastcam
If the knuckle won't let go of the hub, stick a deep socket between the ear of the outer axle and the inner C of the knuckle and turn the steering wheel. Do this to the othet side of it, alternating it until the hub is free. This makes getting getting a stubborn hub out almost effortless.
eastcoastcam is offline
post #21 of 28 Old 11-25-2012, 03:10 PM
jthayer0715
Would this be the same for a 98 ZJ ???
jthayer0715 is offline
post #22 of 28 Old 03-02-2013, 05:29 PM
2000jeeps
I changed out both axles on my 2000 grand cherokee and it drove great for about two months. Now when I turn left I get a bad grinding noise from the passenger front. Is it possible one of the new axles are bad already?
2000jeeps is offline
post #23 of 28 Old 10-19-2013, 03:27 AM
Muzramp
Thanks, this helped me out a great deal. Here's a tip if you can't get the axle nut off. I spend several hours trying remove the nut. Get the biggest breaker bar home depot has. I used a five foot steel pipe, have someone apply brakes with engine on. And it should come right off.
Muzramp is offline
post #24 of 28 Old 02-20-2014, 12:24 PM
oldred95
thanks to this post , I replaced the axles on my 95 ZJ ! Been great help!
oldred95 is offline
post #25 of 28 Old 02-22-2014, 09:06 AM
ajm3377
Nice!
Great write up with pictures! helped me out a ton! thanks man
ajm3377 is offline
post #26 of 28 Old 03-15-2014, 02:37 PM
zuluzulu
Wow great post
After reading your post it looked easy so my son and I (he did most of the work) gave it a whirl. Biggest job I've tackled. We changed both front axles and hubs in three hours. I think spraying the bolts with PG Blaster for two days prior helped a lot.
zuluzulu is offline
post #27 of 28 Old 03-16-2014, 10:04 PM
ajm3377
awesome write up
thanks! this helped a ton!
ajm3377 is offline
post #28 of 28 Old 03-23-2014, 01:49 PM
ajm3377
thanks! this was a huge help! changed out stock parts with 245xxx miles. they were a bit stubborn..
ajm3377 is offline
U-Joint Axle Shaft Overhaul w/ Upgrade zaq123 Technical Articles & Write-Ups 5 08-26-2012 12:20 AM
You may not post new threads
