Send Message Advertisers Vendors Announcements
Jeep Forum Classifieds JeepSpace Reviews Gallery Blogs Clubs Groups Videos Wiki Links Events Articles
Jeep Home Jeep Forum Jeep Classifieds JeepSpace Jeep Reviews Jeep Gallery Jeep Blogs Jeep Clubs Jeep Groups Jeep Videos Jeep Wiki Jeep Links Jeep Events Jeep Articles
Wild Boar Products Cargo Rack or Front Bumper Giveaway
Go Back   JeepForum.com > General Technical Discussions > Technical Articles & Write-Ups
Register FAQ Search Today's Posts Mark Forums Read Search Members
Old09-29-2009, 09:18 AM #1
mjonesjr
Junior Member
mjonesjr's Avatar
2006 WK
How-To: 2005-2009 Grand Cherokee (WK) Fog Light Install
Author: mjonesjr
Difficulty: 2 out of 10
Time to install: 30 minutes
Disclaimer: JeepForum.com, JeepForum.com Staff, nor the author are responsible for you doing this modification to your vehicle. By doing this modification and following this how-to you, the installer, take full responsibility if anything is damaged or messed up. If you have questions, feel free to PM the original poster or ask in the appropriate section of JeepForum.com forums.
Brief Explanation:
This is a step by step with pictures on how to install the factory fog lights on a 2005-2009 Grand Cherokee (WK). The instructions from the factory are very vague and don't go into very good detail.
Tools Needed:
- T15 Torx Screw Driver
- T20 Torx Screw Driver
- Small Phillips Screw Driver
- 10mm wrench
Parts Needed:
If you buy the Mopar kit, all of these parts will be included in that kit. I got my parts from a wrecked '06 Grand Cherokee (WK) for 1/2 what the Mopar Kit cost.
- 2x Fog Light Assemblies
- 1x Headlight Multi-Function Switch w/ Fog Light Switch
- 1x Fog Light Relay (Mopar Part #: 4671168E)
- 1x 20A Mini Fuse
Steps:
1. Start by unhooking the negative battery cable with the 10mm wrench.
2. Install the Fog Light Relay into spot 25 in the under hood power distribution box.
3. Install the 20A fuse into location 15 in the power distribution box.
4. Remove the 3 screws in the steering column trim with the T20 Torx Screw Driver and remove the trim from the steering column.
5. Remove the 2 screws holding the Multi-Function Switch with the T15 Torx Screw Driver. Slide the switch backwards and off the steering column.
6. Slid the new Multi-Function Switch into the steering column. Before re-installing the screws, make sure it functions properly by turning the headlights on/off and the turn signals on/off. Once you know it functions properly, re-install the 2 screws using the T15 Torx Screwdriver.
7. Re-install the steering column trim. Be sure to put the 2 longer black screws on either side across from each other. The smaller grey screw is the odd ball closest to the driver.
8. Remove the black plastic fillers from the front bumper. You will have to push on the tabs on the inside of the bumper to get them to come out.
9. Slide the fog light assembly into position. While holding the fog light assembly into place, screw in the 2 screws from the inside of the bumper using the T20 Torx Screw Driver. If you don't have the factory screws, any screw and washer of the same size will work.
10. Install the new bulb into the fog light assembly. Remove the wiring harness plug from its holder and plug it into the fog light assembly.
11. Repeat step 10 for the opposite side.
12. Using a T20 Torx Screw Driver, adjust the fog lights to desired position. Be sure they are not aimed too high or they will blind on coming motorist.
13. Now schedule an appointment with a local dealership to have them program the PCM to activate the relay when the fog light switch is in the on position.
Before Pictures:
After Pictures:
mjonesjr is offline   Reply With Quote
Old11-03-2009, 09:32 PM #2
ZJFABN
Do you know the OD measurement of those lights? I like them for a custom bumper im doing. Thanks
ZJFABN is offline   Reply With Quote
Old11-11-2009, 01:26 PM #3
PS_Jeep
Thumbs up
Very nice post! The quantity and quality of the pictures is excellent. Thanks for taking the time to put this together.
PS_Jeep is offline   Reply With Quote
The time now is 09:03 AM.
Jeep®, Wrangler, Cherokee, Grand Cherokee, and other models are copyrighted and trademarked to Jeep/Chrysler Corporation.
JeepForum.com is not in any way associated with Jeep or the Chrysler Corp.
