Quantcast Herculining Interior w Drains - JeepForum.com
jeeppartsdept.com
Get your jeep parts here. Full line Jeep dealer. HUGE DISCOUNTS!
Go Back JeepForum.com > General Technical Discussions > Technical Articles & Write-Ups > Herculining Interior w Drains
GR8TOPS Introduces the Exogate HD Tire CarrierRUBICON EXPRESS Lift Kits and Accessories Available at BasSpartan Lockers FREE SHIPPING Excellent Prices
Old 08-26-2008, 09:35 AM   #1
bmyohn
Youngin'
bmyohn's Avatar
As many of you have heard I am Herculining the interior of my XJ and I promised a write-up…so here it is
Its my first write-up so bare with me…lol
1. Tools Needed
a. Herculiner Kit
i. Gallon Paint
ii. Bristle Pad
iii. Brush
iv. Rollers (not completely necessary)
b. Basic Wrench/Ratchet Kit
c. Screwdrivers
d. Acetone
e. Rags
f. 1-1/8" Hole saw and 3/8" Drill Bit
2. Begin by removing the seats
3. Remove the rear seats using a 16mm ratchet to remove the back of the rear seats, there is one on each side.
4. The front seats each have four bolts. The fronts of the brackets have two 13mm bolts.
The rears of the brackets have two different style bolts. The outsides have bolts that are removed with a 13mm bolt, mine were pretty tough to get out. (they are easiest removed with the seat pushed as far forward as possible) The insides of the brackets are nuts that are removed with a 11/16” ratchet.
5. Next, you can remove the seat belts, I chose not to. They are removed with a Torx Head
7. Once all the seats are removed you can take out the center console, to remove that you must take out the plates at the bottoms of the shifters and unscrew the 6 screws that are there.
8. Pull out all carpet (trunk and front section pulls out in two sections
9. Next, you must remove the sound deadener material (silver metal). The sound deadener is located under the bench seats, on the ground infront of the bench seats and buckets as well as on the tranny hump (I didn’t remove the tranny hump material)
I found that the herculiner went over the rubbery/glue type stuff fairly well and it wasn’t worth spending the time getting all of it out. The herculiner doesn’t apply well to the metal though.
10. I also drilled some holes to use as drains, I took two of the drain plugs from the trunk and used them for the front. I took a 1 – 1/8” hole saw to fit the plug
Finished product:
I also added some to under the bench seats using a 3/8” bit
There are also these drains that came stock, they get pulled out with a flat head screwdriver pretty easily
The trim can be removed as well at this time.
11. Once vacummed and cleaned out I went around with the bristle pad that came with the kit and scratched the surface, make sure to take care of any rust issues at this point.
12. Apply Acetone to the surface to clean all the shavings up.
13. Apply a coat of herculiner to the entire floor.
14. While still tacky go ahead and apply a second coat to the floors, I did three coats total (maybe a little overkill, but better safe then sorry)
15. Reinstall all trim and seats, the center console should go on first and then trim and then seats.
bmyohn is offline   Reply With Quote
Old 03-13-2009, 03:16 PM   #2
VTFlora
I'm looking to do the exact project on my TJ. How long did the entire project take you?
My TJ is my daily (and only) driver. I just need to make sure I'm not stuck without a driver seat Monday morning
VTFlora is offline   Reply With Quote
Old 11-20-2009, 09:10 AM   #3
jashbrook
1980 CJ7
Building a 80 CJ7, looking to Herculine the interior, is it still holding up.
jashbrook is offline   Reply With Quote
Old 02-15-2010, 02:39 AM
sandyhei820
This message has been deleted by Gramps. Reason: spam
Old 02-23-2010, 05:44 AM   #4
anferney1323
Nice write up, i am doing mine as soon as spring time comes around here.
anferney1323 is offline   Reply With Quote
Old 03-03-2010, 12:35 PM   #5
drummer31779
1978 CJ5
Sweet. I am looking to do my CJ5 when I get back from deployment. I was planning on going with the Dupli-Color Truck Bed Coating. They used it on Xtreme 4x4. To my understanding most of the work should be in the prepping. Spend the time doing that and the application should be better. I'm considering using the Spray Gun vs the Roller. Not sure though.
How much sanding, if any, did you do? How long did you wait in between coats? What was the overall cost?
Here's a link to the stuff I'm considering:
Truck Bed Coatings
e/Learning :: Truck Bed Coating
drummer31779 is offline   Reply With Quote
Old 03-31-2010, 10:18 AM   #6
U2RA-WINNER
1994 XJ Cherokee
Herculining Interior w Drains in XJ Article
Thx for taking the the time & effort to post your project.
My teen son & I are at the point that a Herculining Interior makes scene.
My basic questions are:
1) since adding the lining have you discovered any surprises?
2) would you have done anything different?
3) any other comments?
Your opinion is greatly appreciated.
Best wishes,
Steven & Michael
fathersNsons.com
94 XJ, Ford Rearend with Detroit Locker, Lockright front
33" BRG Mud TR's, WARN = Rear Bumper w/ Tire holder, WARN = Sliders' Snorkel, Frnt Farm Bumper w/ Winch,
4 1/2 " Superlift, ROCKHARD Fulll Interior Roll Cage,
Plus, Plus
& its never done
U2RA-WINNER is offline   Reply With Quote
Old 06-19-2010, 01:23 AM
nopq084
This message has been deleted by FPKites. Reason: spam
Old 11-06-2010, 01:24 PM
anastabra26
This message has been deleted by AmbuGrl. Reason: spam
Old 03-14-2011, 04:45 AM
nopq430
This message has been deleted by AmbuGrl. Reason: Spam
Glock Forum
