Head Gasket Replacement - Page 2 - JeepForum.com
post #16 of 30 Old 08-03-2011, 10:35 PM
Jeepdude22
Thanks for all the info! Hopefully it helps!! I get to do my head gasket this weekend on a 04 4.7 Grand cherokee. I dont know how chrysler managed to put all that **** under the hood. I almost **** the first time i had to change my spark plugs.
Jeepdude22 is offline
post #17 of 30 Old 09-21-2011, 12:10 PM
JStMarie
JStMarie's Avatar
2.5l ?
This is a great write-up. I've got a 2.5L '98 TJ that will likely need the head gasket replaced. Is there anything significantly different about the 2.5L I need to know about?
I'll take pics and post the 2.5L head gasket replacement job when I get around to doing it, which should be within a month or two.
JSt.Marie
'06 Jeep Wrangler, 65th Edition, stock.
'98 Jeep Wrangler, stock.
JStMarie is offline
post #18 of 30 Old 10-15-2011, 04:09 PM
Pickneters
I think you may have inspired me to handle this!
Pickneters is offline
post #19 of 30 Old 11-08-2011, 12:50 PM
jonifun
So are the valves self adjusting? I have a spare head that is 200miles old. I was going to put this on my 200000+ zj. Will I need to do anything different on reassembly with valve adjustment shimming or is it magical. ??
jonifun is offline
post #20 of 30 Old 02-02-2012, 02:11 PM
mitchj01
Bump on this question- I have an 89 2.5l
1989 YJ 2.5L, stock
mitchj01 is offline
post #21 of 30 Old 03-06-2012, 04:46 PM
CherokeeInn
When I go to loosen the rocker arms they move with it. What do I do?
CherokeeInn is offline
post #22 of 30 Old 04-08-2012, 05:39 AM
blazepsi
I need to do this to my 98 GC. Tnx for the write up...
blazepsi is offline
post #23 of 30 Old 06-18-2012, 07:06 AM
TJ-Tim
Just about finished with my 01 head replacement. AWESOME WRITE UP!!! Was extremely helpful, thank you for posting it. I'm sure this will help/has helped a lot of people.
ɹǝʌo ǝɯ 11oɹ 'sıɥʇ pɐǝɹ uɐɔ noʎ ɟı
TJ-Tim is offline
post #24 of 30 Old 10-02-2012, 08:41 PM
Pfeifer30
Awesome Right up, Helped me get things apart in a timely manner. Only question I have : Do I need to find TDC during the reinstall process?
Pfeifer30 is offline
post #25 of 30 Old 06-29-2013, 06:31 PM
Elitexx187
Great write up. I'm currently in the process of changing the head gasket in my '93 cherokee and I've been using this write up and it's helped a lot. But does anyone know where I can find the torque specs for the head and rocker bolts?
Elitexx187 is offline
post #26 of 30 Old 07-02-2013, 07:44 PM
JStMarie
JStMarie's Avatar
2.5l
Just a follow-up, I did end up replacing the head on my '98 4 cylinder. The procedure is the same; very little difference except more room to work in.
You do not have to find TDC for this procedure. Also, the rocker arms require no adjustment, just tighten each side of each individual rocker arm 1 turn until tight then torque to spec (21 foot-lbs for the '98 TJ).
Use copious amounts of PB blaster to spray down the exhaust and intake manifold bolts. I sprayed them several times over the course of 3 or 4 days and they all came off with no issue at all. I've heard a lot of nightmares of broken bolts and with a jeep as old as mine I took them to heart. PB blaster was a Godsend.
JSt.Marie
JStMarie is offline
post #27 of 30 Old 11-30-2013, 08:37 PM
Jasoncwrd2002
I am doing my 98 Jeep 4cyl right now. The header bolts about got me to the point of throwing in the towel though.
Jasoncwrd2002 is offline
post #28 of 30 Old 02-12-2014, 11:29 AM
JStMarie
JStMarie's Avatar
Any luck on this? How did it turn out?
JSt.Marie
JStMarie is offline
post #29 of 30 Old 04-09-2015, 05:51 AM
Hewaznumber1
awesome write up. exactly what i needed, now im just waiting for my head to come back from the machine shop so i can put everything back together and finally use my torque wrench
Hewaznumber1 is offline
post #30 of 30 Old 04-06-2016, 09:54 AM
kdelik
I just wanted to tell you what a great job you did on this post. Thank you! You encouraged me to attempt this repair on my 97 Jeep Grand Cherokee Laredo. I hope there is as good a post as yours for that model.
kdelik is offline
You may not post new threads
