Electronic Speedo Correction - Page 2 - JeepForum.com
Go Back JeepForum.com > General Technical Discussions > Technical Articles & Write-Ups > Electronic Speedo Correction
Rough Country Deals at JeepHut.comIntroducing MONSTALINER™ UV Permanent DIY Roll On Bed LineEngo winches available at www.rockridge4wd.com! Free shipp
Unread 03-08-2011, 08:04 PM   #16
jamm5266
Originally Posted by Mark_R View Post
Are you happy with the results? With 4:88 gears and 315 75 R16 MT/R's my speed reads high, would really like to get it back to near stock without to much fuss.
Mark R, the physical installation is very easy. Once installed you need to calibrate the unit which is also easy. Basically you compare your dash speedo at 60 MPH against a GPS for actual MPH. You find that difference on a supplied conversion chart that comes with the Speedohealer and input the new calibration factor into the unit and you're done. It doesn' matter what gears or tires you have on the vehicle.
[B]'05 LJ Rubi, starting off with 3" lift and 33 BFG KM2s[/B]
jamm5266 is offline   Reply With Quote
Unread 07-22-2012, 11:04 PM   #17
ColoWJ
I really liked this article. . . How much did this all cost? Do you think it would work for my '04 WJ on 33s?
ColoWJ is offline   Reply With Quote
