Quantcast Easy way to trim Factory Flares - JeepForum.com
Go Back JeepForum.com > General Technical Discussions > Technical Articles & Write-Ups > Easy way to trim Factory Flares
3/8" Amsteel Blue Winchline Available in Blue, Green,Brand new! XJ Rear DIY Bumper from JcrOffroad!Spartan Lockers FREE SHIPPING Excellent Prices
Old 09-28-2009, 04:48 PM   #1
diablo_331
This will be a writeup on how to trim factory style flares or flares of similar material.I have 7 inch factory style flares.This will be the flares used in the writeup.
The flares are quite pliable and pretty easy to work with.If they were made of a harder material(cough!!Bushwacker!!)then this method will probably not work. Anyways,on to the the writeup.
Tools needed:
-Sharp Knife(a Tanto style blade is the easiest to use here)
-Razor Knife
-Tape Measure
-150-200 grit sandpaper
-Pair of channel locks or similar
-Cold Case of Bud Light
-80's Hairband music(Whitesnake,Van Halen, Poison,ect.)
First thing is to figure out how much you want to take off of each flare.
-I removed 2 inches off of the top of the fronts and 1.5 off of the front and rear of the fronts
-I hacked 1.75 off the top of the rears and 1.5 off of the front and back of the rears.
I found that this combo flows quite smoothly and looks great.
Next take the knife and score lightly the line that you will later cut.When I say lightly I mean scratch the surface.Take your time here and measure carefully.I used the tape and held the point of the knife right in front of the tape and drug the tape and knife along the flare while holding the same distance the whole time..Tracking?
After you lightly score the outline of your cuts then the hard part is done.Take a step back and make sure everything is uniform.
This next step can be dangerous.I suggest you use gloves to avoid cutting yourself.I didn't but I am a moron. And morons tend to cut themselves.
Using just the tip or point of the knife blade make a deeper score along the line that you just made.Then after that,make it deeper.Just hold steady pressure and keep your hands steady.
This is a picture of the flare after the final scoring.It is now ready the bend and break at the score.
After the scores are fairly deep then all you simply have to do is bend the flare at the score and it will break along the score.Using the pliers here helps.
This is a few pictures and a video of the flares while I am Breaking them at the scores.
Now take your razor knife and while bending the flare ,after it is cracked along the score, finish cutting through the flare.The razor glades through the flare very easily but again,where gloves just in case.
A few pictures using the razor knife to finish cutting the flares.
This next step is optional but i didn't like how the flares simply came to a point from where i cut them.I wanted them to flow more like they did before I cut them.So I trimmed up the edges using the same method as before.
A few pictures of what I'm talking about.
All done with the cutting.Note that i left the "point" on the front of the front fenders.I think it looks better a flows more with the stock turning signal.
After you are finished cutting the flares off then its time to use a little sandpaper(150-200 grit) and smooth out the edges.
Thats it.Total time was about an hour or two.And they look great!
diablo_331 is offline   Reply With Quote
Old 10-18-2009, 11:18 PM   #2
MlSTER_ROGERS
any other pictures from different angles? or pictures of what other people have done?
MlSTER_ROGERS is offline   Reply With Quote
Old 11-01-2009, 08:37 PM   #3
Hesher420
!!! SLAYER !!!
Hesher420's Avatar
http://www.jeepforum.com/forum/f59/tjs-w-stock-fender-flares-trimmed-679110/
FOR SALE*NIB*TJ CHOME GRILL OVERLAYCLICK HERE
**'06 Blacked Out LJ**
> > > LJ Owners Group < < <
Black Jeep Society
"We are one. One society. Digitless."
"I am not a number, I am a free man!"
Hesher420 is offline   Reply With Quote
Old 11-03-2009, 09:28 PM   #4
ZJFABN
Good work! It came out nice.
ZJFABN is offline   Reply With Quote
Old 12-03-2009, 12:36 PM   #5
TreeFrog1
I think I'm in agreement of additional shots. I mean, thanks for such an in-depth post, diablo, but I'd love to see "full" shots of your TJ, esp. a before and after if possible (instead of just a close-up of the wheel well).
All in all, I think it looks great, just looking to see how it looks on the whole vehicle.
Thanks a million for your post!
TreeFrog1 is offline   Reply With Quote
Old 12-09-2009, 01:04 PM   #6
Mud-Hunter
Can I ask why you do this? More Clearance? Thanks!
Mud-Hunter is offline   Reply With Quote
Old 12-11-2009, 10:08 AM   #7
Mud-Hunter
I may be new but damn am I ignored or just not seen? J/K Help a brotha learn! BTW how did you cut it SO straight?
Old 12-13-2009, 02:08 AM   #8
polo196
polo196's Avatar
Heres mine and what I used. Same results different route.
http://www.jeepforum.com/forum/f9/question-trimming-fender-flares-861508/
Wow, I'm a member. Thats not the word I'm normally called.
Yellow Jeep Club Member #196
polo196 is offline   Reply With Quote
Old 12-14-2009, 10:21 AM   #9
Mud-Hunter
Thanks! That'll help tons!
Old 12-14-2009, 06:13 PM   #10
polo196
polo196's Avatar
I was waiting for Diablo to answer you but he must be busy.
I cut mine because of the following reasons.
1. I like the way it looks.
2. I cant afford flat fenders
3. Didnt want to screw up RME flares in case I sell the Jeep.
4. Makes the Jeep look like it has a bigger lift, when it only has 3 inches.
I dont think it gives me much more clearance and if it does its only between the edge of the flare and tire, not the fender itself.
Old 02-10-2010, 02:34 AM
limited92
This message has been deleted by rustywrangler. Reason: Spammity Spammer
Old 02-10-2010, 03:40 AM
Bweardx32
This message has been deleted by BESRK. Reason: Die Spammer
Old 03-23-2010, 09:50 PM
haoyunok
This message has been deleted by rustywrangler. Reason: spammer
Old 05-13-2010, 05:20 AM
9589wowh2f60
This message has been deleted by BESRK. Reason: Spam
Old 06-26-2010, 10:05 PM   #11
Hamms
Just cut my oem flares and it couldn't have gone any better! Waiting for the wind to die down so I can paint them. I cut off 1.5'' on all around and rounded the corners. Thanks Diablo the idea and write up
Hamms is offline   Reply With Quote
Old 07-03-2010, 06:02 PM   #12
dusted7272
looks good. plan on doing it this weekend
dusted7272 is offline   Reply With Quote
Old 08-20-2010, 05:31 PM   #13
MarylandJeep91
[QUOTE=
..Tracking?
[/QUOTE]
how could i tell you were a Marine? ha
Oorah!!
LCpl/0311/USMC
MarylandJeep91 is offline   Reply With Quote
Old 10-25-2010, 06:45 PM   #14
Erik T.
Bullet Sponge.
Erik T.'s Avatar
I wonder how this would work with Sahara flares?
-Erik.
Hack work? :rofl: You just described half the modified jeeps on this board.
Erik T. is offline   Reply With Quote
Old 10-26-2010, 10:09 PM   #15
fishgutz
2010 JK Wrangler
Saharah flares are painted. If you tape the crap out of them and use a smaller cutoff wheel, like a dremel, you might be able to get it done without huge paint chips flying. Or you could just sell the Saharah flares and buy aftermarket flare. Flat, pocket, metal, plastic. So many choices.
fishgutz is offline   Reply With Quote
Glock Forum
