-   Technical Articles & Write-Ups (http://www.jeepforum.com/forum/f140/)
-   -   Easy way to trim Factory Flares (http://www.jeepforum.com/forum/f140/easy-way-trim-factory-flares-867293/)
diablo_331 09-28-2009 04:48 PM
This will be a writeup on how to trim factory style flares or flares of similar material.I have 7 inch factory style flares.This will be the flares used in the writeup.
The flares are quite pliable and pretty easy to work with.If they were made of a harder material(cough!!Bushwacker!!)then this method will probably not work. Anyways,on to the the writeup.
Tools needed:
-Sharp Knife(a Tanto style blade is the easiest to use here)
-Razor Knife
-Tape Measure
-150-200 grit sandpaper
-Pair of channel locks or similar
-Cold Case of Bud Light
-80's Hairband music(Whitesnake,Van Halen, Poison,ect.)
First thing is to figure out how much you want to take off of each flare.
-I removed 2 inches off of the top of the fronts and 1.5 off of the front and rear of the fronts
-I hacked 1.75 off the top of the rears and 1.5 off of the front and back of the rears.
I found that this combo flows quite smoothly and looks great.
Next take the knife and score lightly the line that you will later cut.When I say lightly I mean scratch the surface.Take your time here and measure carefully.I used the tape and held the point of the knife right in front of the tape and drug the tape and knife along the flare while holding the same distance the whole time..Tracking?
After you lightly score the outline of your cuts then the hard part is done.Take a step back and make sure everything is uniform.
This next step can be dangerous.I suggest you use gloves to avoid cutting yourself.I didn't but I am a moron. And morons tend to cut themselves.
Using just the tip or point of the knife blade make a deeper score along the line that you just made.Then after that,make it deeper.Just hold steady pressure and keep your hands steady.
This is a picture of the flare after the final scoring.It is now ready the bend and break at the score.
After the scores are fairly deep then all you simply have to do is bend the flare at the score and it will break along the score.Using the pliers here helps.
This is a few pictures and a video of the flares while I am Breaking them at the scores.
Now take your razor knife and while bending the flare ,after it is cracked along the score, finish cutting through the flare.The razor glades through the flare very easily but again,where gloves just in case.
A few pictures using the razor knife to finish cutting the flares.
This next step is optional but i didn't like how the flares simply came to a point from where i cut them.I wanted them to flow more like they did before I cut them.So I trimmed up the edges using the same method as before.
A few pictures of what I'm talking about.
All done with the cutting.Note that i left the "point" on the front of the front fenders.I think it looks better a flows more with the stock turning signal.
After you are finished cutting the flares off then its time to use a little sandpaper(150-200 grit) and smooth out the edges.
Thats it.Total time was about an hour or two.And they look great!
MlSTER_ROGERS 10-18-2009 11:18 PM
any other pictures from different angles? or pictures of what other people have done?
Hesher420 11-01-2009 08:37 PM
http://www.jeepforum.com/forum/f59/t...rimmed-679110/
ZJFABN 11-03-2009 09:28 PM
Good work! It came out nice.
TreeFrog1 12-03-2009 12:36 PM
I think I'm in agreement of additional shots. I mean, thanks for such an in-depth post, diablo, but I'd love to see "full" shots of your TJ, esp. a before and after if possible (instead of just a close-up of the wheel well).
All in all, I think it looks great, just looking to see how it looks on the whole vehicle. :2thumbsup:
Thanks a million for your post! :cheers2:
Mud-Hunter 12-09-2009 01:04 PM
Can I ask why you do this? More Clearance? Thanks!
Mud-Hunter 12-11-2009 10:08 AM
I may be new but damn am I ignored or just not seen? J/K Help a brotha learn! BTW how did you cut it SO straight?
polo196 12-13-2009 02:08 AM
Heres mine and what I used. Same results different route.
http://www.jeepforum.com/forum/f9/qu...flares-861508/
Mud-Hunter 12-14-2009 10:21 AM
Thanks! That'll help tons!
polo196 12-14-2009 06:13 PM
I was waiting for Diablo to answer you but he must be busy.
I cut mine because of the following reasons.
1. I like the way it looks.
2. I cant afford flat fenders
3. Didnt want to screw up RME flares in case I sell the Jeep.
4. Makes the Jeep look like it has a bigger lift, when it only has 3 inches.
I dont think it gives me much more clearance and if it does its only between the edge of the flare and tire, not the fender itself.
Hamms 06-26-2010 10:05 PM
Just cut my oem flares and it couldn't have gone any better! Waiting for the wind to die down so I can paint them. I cut off 1.5'' on all around and rounded the corners. Thanks Diablo the idea and write up :cheers2:
dusted7272 07-03-2010 06:02 PM
looks good. plan on doing it this weekend
MarylandJeep91 08-20-2010 05:31 PM
[QUOTE=
..Tracking?
[/QUOTE]
how could i tell you were a Marine? ha
Erik T. 10-25-2010 06:45 PM
I wonder how this would work with Sahara flares?
fishgutz 10-26-2010 10:09 PM
Saharah flares are painted. If you tape the crap out of them and use a smaller cutoff wheel, like a dremel, you might be able to get it done without huge paint chips flying. Or you could just sell the Saharah flares and buy aftermarket flare. Flat, pocket, metal, plastic. So many choices.
The time now is 04:10 PM.
