Cruiser's Mostly Renix Tips - Page 2 - JeepForum.com
Closed Thread
post #16 of 30 Old 07-13-2013, 05:58 AM Thread Starter
cruiser54
cruiser54's Avatar
1990 MJ Comanche
Cruiser's Vacuum test for EXHAUST RESTRICTION
Your vacuum gauge should come with an instruction booklet outlining the procedure. Hook the vacuum gauge up to a source on the intake manifold. Start the engine and note the vacuum reading. Usually 17 to 21 inches of vacuum. Throttle the engine up to 2,000 to 2,500 RPM for 20 seconds or so and the vacuum reading should stabilize to the same reading you got at idle. Let the throttle snap shut. The vacuum reading should shoot up about 5 inches of vacuum higher for a second and then come quickly down to the original reading. If the vacuum reading stays high and comes down slowly with jerky needle movements, you have an exhaust restriction.
If you own a Renix Jeep, you must check this out:
My Jeep technical photos:
cruiser54 is offline
post #17 of 30 Old 07-13-2013, 05:59 AM Thread Starter
cruiser54
cruiser54's Avatar
1990 MJ Comanche
Cruiser’s HO into Renix Swap
This swap is easier than some will lead you to believe, generally those who have never done it. Those of us who have done it, like myself, will share with you the things that need to be done for a successful swap. Just think of it as swapping in a long block.
The HO and Renix have some differences but none that can’t be overcome very easily.
Any HO engine from an XJ or ZJ through 1999 can be used. One running change was that the rear of the head was no longer drilled and tapped for the temperature gauge sender beginning in the 96 model year. The sender can be relocated to the threaded hole in the thermostat housing taken from the HO engine. You’ll have to extend the wire to that location. Some brave souls even drill and tap the HO head for the sender.
You will be using the intake and exhaust manifolds from your Renix, along with all your sensors and wiring. Since the intake ports of the HO are slightly different, you use the Renix gasket. Exhaust ports are identical.
You will need to use your Renix distributor as it is different than the HO because they use different fuel management systems. The flywheel or flexplate from the Renix must be used so your CPS gets the correct signals. The valve cover from the Renix allows you to keep your CCV system intact and requires no modifications.
The HO block will have a plug in the coolant galley on the driver’s side of the block, closest to the front, which needs to be removed so your Coolant Temp Sensor can be installed in it’s place just as it is on the Renix. It requires a 5/16" square drive or a modified 3/8" drive that has been ground down to fit. Do this before installing the engine.
As for the knock sensor, which is located just above the oil pan on the driver’s side of the engine about mid way, all the blocks I’ve seen are threaded for it. If not, I’ve heard they may be drilled but not tapped. Tap the hole if that’s the case.
Revised 03/28/13
post #18 of 30 Old 07-13-2013, 06:01 AM Thread Starter
cruiser54
cruiser54's Avatar
1990 MJ Comanche
Improving the Instrument Panel Ground
The ground point for the complete instrument cluster on your XJ or MJ is located up under the driver’s side dash. If you lay on your back and look up under there with a flashlight, without wearing a hat, you will see a black wire attached to a shiny piece of metal almost directly above the hood release knob. The screw will have either a ¼" or 5/16" head on it.
This ground point is responsible for handling the ground circuit for the following items: Dome lamps, Seatbelt and key warning, trans comfort switch, wiper switch, headlamp switch and delay module, fog lamp switch, cargo lamp switch, all instrument panel grounds and illumination, power windows and door locks, cruise control dump valve, and a few more things.
The problem is that where the ground point is located does not have a good contact with the chassis where the ground should be. The solution is simple.
Make up a jumper wire with #10 gauge wire about 10" long. On one end, crimp on a ¼" round wire terminal. On the other end, crimp on a 3/8" round wire terminal.
Remove the screw from the existing ground wire and attach the small terminal of your jumper so that the original wire and your new jumper share the same attaching point, one over the other.
Look above the driver’s side plastic kick panel just forward of the top of the hood release knob. You will see an 8mm stud there. Attach the large terminal end there with a washer and nut over it tightened securely.
**Special note for Comanche owners: Make your jumper wire 12" long and attach it on the driver’s side kick panel close to the fusebox on the 8mm stud.***
Revised 11-29-2011
post #19 of 30 Old 07-13-2013, 06:03 AM Thread Starter
cruiser54
cruiser54's Avatar
1990 MJ Comanche
Cruiser’s Headlight Upgrade Harness Instructions
It's easy to install a supplemental headlight harness.
From the factory, the voltage to the headlight bulbs travels from the battery, inside the cabin, to the headlamp switch, and then back out to the lamps via undersized wire. It's not uncommon to find only 10.5 volts at the lamps.
The supplemental harness is installed so that it provides battery voltage to the lamps and is just triggered by the factory wiring. The result is about 30% brighter headlamps and headlight switches that don't melt and burn out.
Absolutely plug and play: Remove grille and headlamp bulbs. I fed my harnesses from the passenger side starting between the battery and the back of the headlamp housing, over to the driver side.
Plug the driver side bulb into the new harness.
Attach the new harness's ground wire under one of the small bolts on the radiator support after scraping the paint off under it.
Attach the harness to the existing harness behind the grille working toward the passenger side.
Plug the new harness plug into passenger headlamp.
Plug original headlamp plug into receptacle on new harness.
Attach the ground for the passenger side just like you did the driver side under a radiator support bolt.
Attach relays with provided bracket on the passenger side inner fender. Connect power wires to battery.
Revised 12/10/2012
post #20 of 30 Old 07-13-2013, 06:04 AM Thread Starter
cruiser54
cruiser54's Avatar
1990 MJ Comanche
Shifting the Transfer case.
Here's how the factory suggests you shift the transfer case and I've been doing this since these things were new and I worked at the dealership.
Quoted from the owner's manual:
"To engage, shift the transfer case lever from 2H to 4H while the vehicle is moving at any legal speed". I let off the gas, throw the lever, and then tap the gas and let off.
4L position: " To engage, slow the vehicle to 2-3 MPH , shift the transmission to Neutral, then shift the transfer lever to the right and pull firmly rearward to 4L".
post #21 of 30 Old 07-13-2013, 06:07 AM Thread Starter
cruiser54
cruiser54's Avatar
1990 MJ Comanche
Testing the EGR Valve for 87-90 4.0 engines
Valve Opening Test
1) With engine at normal operating temperature and at idle, rapidly open and close throttle. Open throttle sufficiently to obtain at least 1500 RPM. Movement should be noticed in EGR diaphragm.
2) If diaphragm does not move, probable causes are: faulty vacuum signal to EGR, defective EGR diaphragm or defective backpressure sensor diaphragm (if equipped), or leaks in vacuum lines or connections.
Valve Closing Test
1) With engine at normal operating temperature and at idle, manually depress EGR valve diaphragm. RPM should immediately drop, indicating that EGR valve is not leaking and had been properly cutting off exhaust gas flow at idle.
2) If there is no change in RPM and engine is idling properly, exhaust gases are not reaching combustion chamber. Check for plugged passage between EGR valve and intake manifold.
3) If engine idles poorly and RPM is not greatly affected by manually moving diaphragm up, EGR valve is not closing off exhaust gas flow. Check for carbon between pintle, leaking EGR valve gasket or bad EGR valve.
post #22 of 30 Old 07-13-2013, 06:09 AM Thread Starter
cruiser54
cruiser54's Avatar
1990 MJ Comanche
Renix Vacuum Harnesses
The vacuum harness that attaches to the front of the valve cover and includes the grommet/fitting, and is called the front harness, is Napa part number BK 715-1367
The vacuum harness that is closest to the air cleaner, EGR etc, and is called the rear harness, is Napa part number BK-715-1366.
The tube from the rear of the valve cover to the intake manifold is part number 715-1365.
Revised 09-11-2012
post #23 of 30 Old 07-13-2013, 06:11 AM Thread Starter
cruiser54
cruiser54's Avatar
1990 MJ Comanche
Cruiser’s Renix CPS Advance Mod
The sensor portion of the CPS needs to slide up the perforated bar towards the top of the engine.
Mark the perforated bar's top end with paint or marker.
Place the CPS in a vice, just not quite clamping the bar, the sensor resting on the vice jaws, with the Top part protruding.
Place a bolt that fits tightly into the hole at the Top part of the bar.
With a hammer, tap the Top part of the bar and it will slide through the sensor portion of the CPS. Stop when the sensor portion is about 3/8" from the edge of the bolt hole
post #24 of 30 Old 07-13-2013, 06:13 AM Thread Starter
cruiser54
cruiser54's Avatar
1990 MJ Comanche
The date code is on the passenger side of the engine, on the block, just forward and up from the distributor on a machined flat surface.
The digits of the code identify:
•1st Digit = The year (8 = 1998).
•2nd & 3rd Digits = The month (01 - 12).
•4th & 5th Digits = The engine type/fuel system/compression ratio (MX = A 4.0 Liter (242 CID) 8.7:1 compression ratio engine with a multi-point fuel injection system).
•6th & 7th Digits = The day of engine build (01 - 31).
FOR EXAMPLE: Code * 801MX12 * identifies a 4.0 Liter (242 CID) engine with a multi-point fuel injection system, 8.7:1 compression ratio and built on January 12, 1998.
post #25 of 30 Old 07-13-2013, 06:14 AM Thread Starter
cruiser54
cruiser54's Avatar
1990 MJ Comanche
Most early and even later Renix 4.0s could be bothered by excessive oil in the air cleaner box. A fix from my old days as Service Manager at a Jeep dealership follows. Information was provided to me from a buddy at JeepTech during those days. I don’t believe it ever came out in a Technical Service Bulletin.
Remove the valve cover and turn it over. Next, remove the fluted tubes that are now facing you by removing three screws on each. Chop 1 inch off each of them. Then, about a half inch up from the area where you just sawed them off, drill a half inch hole in the tubes so the holes will face the rear of the valve cover. Clean and de-burr/sand all rough edges nicely, clean with solvent, and reinstall. Don’t be concerned about the chintzy gaskets that will probably crumble into oblivion when you remove the fluted tubes. They can go back together without gaskets.
post #26 of 30 Old 07-17-2013, 06:03 AM Thread Starter
cruiser54
cruiser54's Avatar
1990 MJ Comanche
Oily Valve Cover fix
We all get tired of the oil film/leak on top of our 4.0 Jeep aluminum valve covers. Many times the biggest culprit is the loose fitting oil filler cap. Here’s a real easy fix:
Remove the plastic oil filler cap and wrestle the original rubber gasket from it using a small pick or screwdriver.
Make a duplicate of the gasket out of an old bicycle inner tube using scissors and a knife or razor blade.
Install the duplicate on the cap first, and then the original over top of it.
It will be a tight fit on the valve cover the first time, and may require some persuasion with a pair of pliers, but will get easier with time.
post #27 of 30 Old 07-17-2013, 06:03 AM Thread Starter
cruiser54
cruiser54's Avatar
1990 MJ Comanche
C101 connector elimination
Unbolt the 2 halves of the C101 using a ¼” socket. On each half there is a plastic cover where the wires enter. They are removable but you'll probably end up busting them off. Lightly bolt the C101 back together, away from the firewall. Peel back the split-loom covering from the body side of the C101 connector down to where the harness splits and goes toward the firewall, pretty much below the MAP sensor. On the engine side, remove the split loom about the same distance. *See first photo.
Now you can see from one side of the C101 to the other. Beginning at the top row, closest to the motor, be absolutely sure you cut the matching wires on each side of the connector off to about 1/2 inch. This will allow you to verify the original position of each wire color in case of mistakes or confusion. CUT AND SOLDER ONE PAIR AT A TIME. The wires may be wound a bit in their looms. See the first photo. Get them unwound neatly and do the following, ONE AT A TIME.
Slide your shrink tube over one wire. In a well ventilated area, solder the wires together and then slide the shrink tubing over the solder joint. Heat the shrink tubing so it seals your completed solder joint. Keep going until you've done all 22 or so connections.
Both sides of the C101 connection have a wire that is brown with white tracer. Follow each of these wires back until you come to a point where three wires are crimped together. *See the second photo.
What you want to do here is cut the crappy factory crimp out of each set of three and bring both sets of three wires together and solder them together, using shrink tubing as well. All 6 wires. These particular wires will not end up in your normal C101 elimination loom. See the third photo.
After all the soldering and shrink tubing is done, bundle the wires together in a new piece of 3/4" split loom. Tape it up and secure it to the C101 connector's original bolt hole or somewhere else along the firewall so it will be protected. *See the third photo.
Revised 03-06-14
C101 Elimination 1-final.jpg   C101 Elimination 2-final.jpg   C101 Elimination 3-final.jpg
post #28 of 30 Old 07-17-2013, 06:04 AM Thread Starter
cruiser54
cruiser54's Avatar
1990 MJ Comanche
Improving Blower Motor performance
On 87 to 90 MJs and XJs, the blower motor’s factory grounding point is on the driver side inner fender under the sheet metal screw. This ground is shared with windshield wipers, front windshield washers, rear windshield washers, AC clutch relay, fan control relay, fog lamps, fan motor, headlamps, front turn signals, front side markers, and park lamps.
So your blower motor has its ground point 10 feet away from where it is located!!
What we’re going to do is leave that ground intact and also ground the blower motor on the passenger side inner fender much closer to the blower motor itself. This will also benefit the other components on the factory ground circuit. Take this opportunity to refresh the factory ground as a matter of course. Remove the screw, scrape the surface to bare metal and reinstall the screw securely.
Here’s what I do to get the ground much closer to the blower motor and add another ground point to this overloaded ground circuit.
Find the blower motor connector on the passenger side. Red and Black two wire connector.
Find a location where the black wire can be made to reach the passenger side inner fender, and cut the wire. You may have to do some rerouting of the harness to achieve this.
Take both cut pieces of wire and put them together into a yellow eyelet and crimp. Fasten the eyelet to a place on the passenger side inner fender with a sheet metal screw. There’s probably one on there that you can use. Be sure to scrape the attaching point on the fender to bare metal first.
Your blower motor will now turn faster and last longer, and the other electrical components on the circuit will benefit from a better ground path.
Blower motor factory ground:
Blower motor new ground:
post #29 of 30 Old 07-17-2013, 06:04 AM Thread Starter
cruiser54
cruiser54's Avatar
1990 MJ Comanche
Cruiser's Renix Tips discussion thread:
This thread is locked to keep it clean and easy to find information.
Feel free to post any questions or comments here in the discussion thread. > Cruiser's Renix Tips discussion thread
post #30 of 30 Old 11-23-2013, 08:44 AM Thread Starter
cruiser54
cruiser54's Avatar
1990 MJ Comanche
More to come...
Closed Thread
You may not post new threads
