Cheap Third Brake Light for Over-Size Tires ($2/No Drilling) - Page 2 - JeepForum.com
post #16 of 18 Old 04-14-2012, 10:37 PM
hightread
Wish I had seen this earlier. I bought a light (4 1/2"x2 1/4") from www.chromeshack.com and I am building a bracket to bolt on to the stock tire carrier. This will give a factory effect but the center cap idea would have been a lot cheaper.
David in TN
hightread is offline
post #17 of 18 Old 05-08-2012, 05:52 PM
Stretch2121
Just ordered the 4X4LED.com kit. I'm a little confused on disassembling the original wiring. Appears I need to cut the factory wires just short of the bulb + cut the rubber grommet where those wires enter that upper housing + pry open the lower assembly to remove the wiring bundle.
The cut wires get spliced into the ordered pigtail.
Sound right?
I figure to cut the factory wires right next to the old bulb...I can always trim off more as needed once I get it all removed.
Stretch2121 is offline
post #18 of 18 Old 05-10-2012, 06:14 PM
jeppson
Here is an image
Here is my Jeep where I put in the 3rd brake light in the center of spare wheel. Super easy to do and looks great. When you remove tire brake light stays on ofcourse
jeppson is offline
How-To: 2005-2009 Grand Cherokee (WK) Fog Light Install mjonesjr Technical Articles & Write-Ups 14 09-12-2016 11:28 AM
Cheap No Drill or Weld Interior Mount for Hi-Lift Rubi22 Technical Articles & Write-Ups 4 01-19-2013 08:35 AM
How-To: 2005-2009 Grand Cherokee (WK) Fog Light Install mjonesjr Technical Articles & Write-Ups 1 08-07-2009 05:39 AM
You may not post new threads
