Zone 4" WJ Lift+other Q's - JeepForum.com
post #1 of 69 Old 12-22-2009, 12:05 PM Thread Starter
BHand89
Ok so I have basically decided I am going with the 4" kit from Zone for my dub. I have been following Apollo's build and he said he got the IRO upper adjustable CA's and the rear Addco sway bar. By question is, within somewhat of a budget, what other stuff do you recommend I get to have the best success with the lift. It is going to be my daily driver and occasionally some wheelin' and trail riding. I figure the lift will be $700 give or take, Addco sway bar will be $140 or so, IRO front upper adjustables another $140 or so. I'd like to do everything for less than $1200 or so, that gives me a little wiggle room for add-ons and stuff. Let me know what you guys think, thanks!
BHand89 is offline
post #2 of 69 Old 12-22-2009, 12:07 PM
xJoshxx
2012 WK
What drive shaft do you have? in the front. that may need replacing
Sold4" Hybrid lift TeraFlex coils IRO Adjustable LA's Jks tracbar 1.25spidertrax spacers 265/75/16 Dura-tracs
Originally Posted by moPowered View Post
The SRt-8's are a liberty design.
2011 WK2 ORA2 sold
2012 WK2 SRT8 - Current
99 WJ Limited Lifted.
2001 WJ stock 4.0 304k miles
xJoshxx is offline
post #3 of 69 Old 12-22-2009, 12:12 PM Thread Starter
BHand89
It's stock. I have Quadra-Drive if that helps at all. Sorry still a noob to this stuff.
BHand89 is offline
post #4 of 69 Old 12-22-2009, 12:19 PM
xJoshxx
2012 WK
No problem i was too.
which one of these driveshafts do you have?
2011 WK2 ORA2 sold
xJoshxx is offline
post #5 of 69 Old 12-22-2009, 12:21 PM
GraKee99
Rapist Wit
GraKee99's Avatar
It is probably the cv style. You need to get under and look. If it is (about a 100% chance on a 99 ), it will need to be replaced with a u-joint style.
Brian
WJ, WK, CJ5
GraKee99 is offline
post #6 of 69 Old 12-22-2009, 12:31 PM Thread Starter
BHand89
Looks like the Rezeppa-Rezeppa
BHand89 is offline
post #7 of 69 Old 12-22-2009, 12:32 PM
xJoshxx
2012 WK
And looks like $300 will be added to your list.
2011 WK2 ORA2 sold
xJoshxx is offline
post #8 of 69 Old 12-22-2009, 12:34 PM Thread Starter
BHand89
Damnit, really that much? I am going to a pick and pull tomorrow, should I look for a U-Joint style one there?
BHand89 is offline
post #9 of 69 Old 12-22-2009, 12:35 PM
zippome
your going to want to replace the front shaft. either you can get a new one built by a local shop, tom woods, or carolina. or if you want a temp fix, you can get a shaft and both yokes out of an 02+ which will mosty likely be a single/double cardan. i have gone through 2 cv shafts until i swapped in the u-joint shaft. so far so good
Im 20 with a 2000 Grand SOLD!
4" Zone Offroad Kit, 16x7 Cragar Soft 8's, 265/75/16 Maxxis Bighorns, Rock-It Sliders, Rancho SS, Yakima Load Warrior, Flowmaster Super 40, Reverse Lights, 2 Lights Up Front, Custom 6 Switch Plate, Cobra 76 XTR CB with PA, Lightbar, Custom Hitch Tire Carrier, Fleabay Warm Air Intake
zippome is offline
post #10 of 69 Old 12-22-2009, 12:35 PM
GraKee99
Rapist Wit
GraKee99's Avatar
That will need to be replaced. The cheapest and easiest fix is to call carolina driveline and get a custom shaft made that has special plates that will bolt on the cv output. This will be a bolt in replacement. About $300.
The other way is to go to u-joint yokes for the t-case and axle ends, get a shaft with u-joint ends and bolt that in. Will be more expensive but has its advantages over the carolina direct bolt in.
Brian
WJ, WK, CJ5
GraKee99 is offline
post #11 of 69 Old 12-22-2009, 12:36 PM
xJoshxx
2012 WK
You will Have to Swap the YOKES which means you could possibly mess up your pinion bearing because you have to Torque it Damn near Exact to keep it from messing up.
Carolina Makes a Direct Swap in tho No changin yokes.
2011 WK2 ORA2 sold
xJoshxx is offline
post #12 of 69 Old 12-22-2009, 12:37 PM Thread Starter
BHand89
So what would you recommend for pretty much a daily driver with occasional offroading... the Carolina?
EDIT: Ok then I'll go the Carolina route. Thanks for the help guys. Do they have a site to order from or should I call them directly?
BHand89 is offline
post #13 of 69 Old 12-22-2009, 12:39 PM
xJoshxx
2012 WK
http://www.jeepforum.com/forum/f13/w...ctures-806580/
2011 WK2 ORA2 sold
xJoshxx is offline
post #14 of 69 Old 12-22-2009, 12:39 PM Thread Starter
BHand89
Hey I noticed you are running the 4" zone kit. Got any pics?
BHand89 is offline
post #15 of 69 Old 12-22-2009, 12:41 PM
zippome
true. but i managed to do it myself and didnt screw anything up. its pretty straight forward. there are plenty of writeups out there. if you are willing to put in a little time and effort its not hard. plus i learned a lot when doing this. so i saved over $200 by just putting in a little more work. sounds good to me.
obviously its up to you whether or not you spend the money on a new shaft or get a used shaft but i wouldnt rule out getting a jy shaft. mine has been holding up great.
zippome is offline
Zone 4" Wj Lift myjeeplovesmud WJ Grand Cherokee Forum 149 07-03-2014 07:52 PM
Zone Offroad WJ 4" Lift kit BigFire WJ Grand Cherokee Forum 40 07-09-2010 02:09 PM
Zone 4" lift Twarlick ZJ Grand Cherokee Forum 7 10-04-2009 09:29 PM
RC 4" vs. Zone 4" lift - Casual offroading Axi0m ZJ Grand Cherokee Forum 27 08-03-2009 09:07 AM
4" zone lift, i want to go 6.5! Twarlick ZJ Grand Cherokee Forum 19 02-28-2009 01:57 PM
