Which zj's came with 3.73 rears? - JeepForum.com
Go Back JeepForum.com > Models > Jeep Grand Cherokee & Commander Forums > ZJ Grand Cherokee Forum > Which zj's came with 3.73 rears?
FS: Wranger BRIGHT License Plate LED! Just $3! Great valueIntroducing MONSTALINER™ UV Permanent DIY Roll On Bed LineFS: Jeep Fog Light LED Bulbs! Several Brightness Options!
Unread 06-18-2012, 01:05 PM   #1
dj_justice
I need to replace my rear in my 98 limited that has the d35 with 3.73 gears. Which other zjs came with 3.73 gears from the factory?
dj_justice is offline   Reply With Quote Quick reply to this message
Unread 06-18-2012, 01:09 PM   #2
ajmorell
I think all v8 ZJ's had 3.73s. 93-95 will have a d35, 96-98 had the 44a. Also 4.0s with the tow/tow-prep package had 3.73s.
ajmorell is offline   Reply With Quote Quick reply to this message
Unread 06-18-2012, 01:24 PM   #3
sevenscrew
my 97 5.2 full time 4wd with tow package came with the 3.73 in the d44a.
1997 Limited 5.2L Nelly - SOLD
1997 Limited 5.2L - new project
sevenscrew is offline   Reply With Quote Quick reply to this message
Unread 06-18-2012, 01:30 PM   #4
PolkaPower
Yes all of the v8's came with 3:73's. either 44a or d 35.
PolkaPower is online now   Reply With Quote Quick reply to this message
Unread 06-18-2012, 05:49 PM   #5
greyhnd
I have a 96 ZJ Laredo 4.0L with the towing package. According to my build sheet it's equipped with 3.73 gears and Dana 35C.
greyhnd is offline   Reply With Quote Quick reply to this message
Unread 06-18-2012, 07:03 PM   #6
pincheburro956
try getting the axle out of a 96+ v8 zj...get that d44a with 3.73..nice simple upgrade...
if you can weld, find you an 8.8 with 3.73 and call it a day.
"Not a single **** shall be given."
99 WJ, 2" BB, 245/75/16 Falken Rocky Mountain ATS.
pincheburro956 is offline   Reply With Quote Quick reply to this message
Unread 06-18-2012, 07:12 PM   #7
Scopez
1994 ZJ
I think the 96-98 V8s had the D44a with 3.73s. 96-98 I6 had a D35? Not 100% sure about the I6s.
94 ZJ Laredo. 5.2 Crate engine. 6in JKS SA Lift. 33in Destination MTs. ARB Front Bumper.
Scopez is offline   Reply With Quote Quick reply to this message
Unread 06-18-2012, 07:50 PM   #8
Pugulis
All tow package option ZJ's have 3.73 gears.
[_][]☺[][][]☺[][_] 96' Grand Cherokee Laredo 265,000 miles and still going strong.
Pugulis is offline   Reply With Quote Quick reply to this message
Unread 06-18-2012, 08:50 PM   #9
Texas ZJ1
Jeep Jedi Master
Texas ZJ1's Avatar
1994 ZJ
All the V8s had the 3.73s.
Hunter
00 4.7 Laredo...KYB gas shocks, ADDCO rear sway bar and Firestone Destination tires.
08 Z71 Suburban, front leveling kit with rear spacers. 285/65 18s Nitto TerraGrappler G2s
94 5.9 Laredo 6.5 RE lift with 35 Maxxis Bighorns
and 33 Bridgestone Duelers
Detroit and true trac
Red Jeep Club Member
REDNECK JCM
Texas Jeep Owner #6
USN Jeep Club #4
http://www.kevinsoffroad.com/
602.841.3355
For your performance needs:
kolak@kolakperformance.com
480.998.3661
Texas ZJ1 is offline   Reply With Quote Quick reply to this message
Unread 06-21-2012, 01:21 PM   #10
dj_justice
Is the dana44a a direct swap? Do I need to change driveshafts?
Unread 06-21-2012, 01:27 PM   #11
PolkaPower
The D35 is shorter than the 44a so you would need to adjust your drive shaft unless you have a 249 TC and you might be able to just get a DS from the doner vehicle with the 44a.
Unread 06-22-2012, 03:50 PM   #12
jdj624
if your 98 zj has the 5.9L motor it came with a dana 44a and 3:73 gears. if your thinking of find some gears out of a junk yard, your better off just getting new ones. a new ring and pinion will set you back any where between 150.00-250.00. the dana44a is different the a regular dana 44 the bearing's are not interchangeable, i don't know if the ring and pinion are the same. which ever way you go make sure it's for the 44a. if your rear end is making noises and that,s the reason for putting new gears in, unless there are teeth missing or ground down on the ring and pinion, then i new bearing set should cure the problem and cheaper. your zj also has a trac-lock in it which could be your noise problem. one other bit of advice unless you know how to set up a rear (or front) end properly let a pro do it. you need a dial caliper to set the backlash correctly. if you are wanting to swap the whole rear end to a regular dana44 hen i think but am not 100% sure a dana 44 rear end out a wrangler tj has the same track width or maybe a cherokee xj. you might have move the coil pads to match your zj .if you want PM me and i can tell you what i have done with my 98zj,there are several options for that type of rear end. but because it has a aluminum center section you are limited.
jdj624 is offline   Reply With Quote Quick reply to this message
Unread 06-22-2012, 04:02 PM   #13
PolkaPower
All V8's from 96+ have the D44a and 3:73 gears. The 5.9 have a thicker rear drive shaft though. Did all v8'scome with a track lock after 96? I know every option was on the 5.9 standard.
Unread 06-22-2012, 05:32 PM   #14
jdj624
i don't think they did, it may have been an option. but was standard on the 98 5.9l.
Unread 06-23-2012, 01:44 AM   #15
Texas ZJ1
Jeep Jedi Master
Texas ZJ1's Avatar
1994 ZJ
Not all V8s after 96 had the trashlock.
They did all have the 3.73s.
BTW, if they had 3.73s in the rear diff, they had them in the front diff as well....unless you had a 2wd which didn't have a front diff.......or a YJ front bumper.
Hunter
REDNECK JCM
Texas Jeep Owner #6
USN Jeep Club #4
602.841.3355
480.998.3661
