ZJ to XJ high pinions swap, Control arm mounts. - JeepForum.com
post #1 of 4 Old 09-26-2012, 08:18 AM Thread Starter
Trick440
1994 ZJ
Will I have any problems doing this swap with a 5.5 lift?
"XJ and ZJ front axles DO NOT have the same mounting positions for the control arms. The ZJ long arms WILL bolt up to the XJ axle, but you will not have a desirable range of caster adjustment."
Heres my front end again...
Trick440 is offline
post #2 of 4 Old 09-26-2012, 08:34 AM
Midnightluckey
You have adjustable short arms to adjust your caster, so you don't need to worry about that. Get that puppy in there!
95 Limited Chargold ZJ 5.2L -5.5" lift (IRO, Ironman, and RC parts), 33" BFG M/T's, 15x8 procomp crawlers, 242 swap, 2 12" subs, 1000w amp, cherry bomb, full skid package, Kevins rear stealth bumper clone w 3/4" D rings, Rlcwelding front bumper w 3/8" D rings, XRC-8, front tow hooks, 2 daylighter fairlead lights, 2 daylighter windsheild lights, 2 55w driving lights, OBA, Cobra 18 CB, dual 4' whips, RC disconnects, smittybuilt jack, optima yellowtop.
Built not bought #512
Midnightluckey is offline
post #3 of 4 Old 09-26-2012, 08:37 AM
Midnightluckey
Edit: just make sure if you upgrade to long arms in the future, get the xj arms.
post #4 of 4 Old 09-26-2012, 09:33 AM
ratmonkey
R.I.P.
ratmonkey's Avatar
That only applies in the case of iro long arm lifts. The mounts ARE IN THE SAME PLACES. The caster vs pinion angle set with the way the knuckles are welded on is different. Iro's hokey iron y can't be adjusted enough and will make contract with the high pinion. No one else's lifts have this problem.
ratmonkey is offline
climate control high setting sporadic caveman5055 ZJ Grand Cherokee Forum 9 05-02-2012 11:40 PM
upper rear control mounts JERSEY5.0YJ ZJ Grand Cherokee Forum 3 12-16-2010 07:17 PM
High Performance Motor Mounts for ZJ? 93zjer ZJ Grand Cherokee Forum 0 11-30-2010 11:12 AM
2004 GC steering wheel radio control quit and blower only works on high Kabraham ZJ Grand Cherokee Forum 2 11-26-2009 11:41 PM
Control arm mounts Texas ZJ1 ZJ Grand Cherokee Forum 2 01-04-2004 06:27 PM
