ZJ Wont start after rain...AGAIN! - JeepForum.com
post #1 of 72 Old 02-27-2014, 01:53 PM Thread Starter
evan1395
Well, it rained, and this piece of crap wont start. This morning at the shopping center it took 15-20 turns of the ignition before something decided to work and turn the engine over. Now today, after getting back from the store, I go out to start it up and...dead! Not a light, gauge or ANYTHING! When the key is in the off position im getting a constant, quick clicking from right above the interior fuse panel. I dont know whats tucked up inside the dash right above that fuse panel, but its clicking whenever the ignition is in the off position. When turned to the on position, it stops...accompanied by NO instrumentation lights, gauges or interior lights. What the hell is going on?
I just looked under the hood, nothing is visibly wet. I noticed when I first got this thing, I checked the codes by turning the ignition 5 times. It's throwing code #12. This code has had no ill affect on the Jeep. But something gets wet or faulty when I drive around in wet weather.
Please, any input would be helpful!
J.E.E.P (Just Empty Every Pocket)
evan1395 is offline
post #2 of 72 Old 02-27-2014, 02:11 PM
zjosh93
Haven't had it happen to me but I've heard that if your cowl drains clog it can drip down the inside on the passenger side. A lot of the dashboard wiring connectors are behind the passenger kick panel. At least they are on the 93-95. Might be a thing to check.
zjosh93 is offline
post #3 of 72 Old 02-27-2014, 02:16 PM Thread Starter
evan1395
It started to rain last night, it started up fine from work, drove home the whole 1.5 miles and continued to pour alllll night. It started up fine this morning, however the 3-4 mile drive to the shopping center is what did it. Because after I got out of the store is when it acted up. So I dont think it is the cowl drain. If so, i'd think the staying still all night in the driveway would make it act up. But it's after driving it around is when it does this.
Im sooooo effin lost at this point. I just dont get the clicking noise. The only way to get it to stop is turn the key to the on position, or disconnect the negative terminal, which is what I did.
evan1395 is offline
post #4 of 72 Old 02-27-2014, 02:54 PM Thread Starter
evan1395
bump
evan1395 is offline
post #5 of 72 Old 02-27-2014, 03:00 PM
Alexandru999
if you have random clicking sounds from the interior fuse box area, followed with random electrical glitches, like, rear fog would stay on, dash out, mileage beeping on off, ETC wtv else, could be that water got in , and rusted out your interior fuse box, thats what happened to me, i had a wire for the subs going uunder the hood then beside the door under the passenger side, and water dripped down on that subs ground wire, it was a bit wet too, fuse box rusted out, many terminals, that was my problem ... might wanna inspect it for rust or any damage, idk
Alexandru999 is offline
post #6 of 72 Old 02-27-2014, 03:03 PM
HighLonesome
Belief In All Things Jeep
HighLonesome's Avatar
Don't know gen2 ZJs, but the clicking is likely a relay.
When you say totally dead, you mean the starter won't turn?
When it dries out, everything is good?
HighLonesome is offline
post #7 of 72 Old 02-27-2014, 03:04 PM Thread Starter
evan1395
Like there is zero electrical function. Like the battery isnt even under the hood.
But yeah, last time this happened, I pulled all the relays and fuses in both under hood relay box and the interior fuse box, gave it two days to dry out and it fired up just fine.
evan1395 is offline
post #8 of 72 Old 02-27-2014, 03:17 PM
HighLonesome
ok, if it acts like the battery is disconnected, then it probably is.
The starter is a separate circuit from all else and pretty simple. Good place to start. Sounds like a bad ground. When it is dead, connect a big wire from the battery ground to starter ground, motor, and body in that order and see what happens. Post back...
I need a diagram to look at, but that is later on.
post #9 of 72 Old 02-27-2014, 03:25 PM Thread Starter
evan1395
Im at work til midnight. So tomorrow morning I will give it a try.
evan1395 is offline
post #10 of 72 Old 02-27-2014, 03:25 PM Thread Starter
evan1395
And why would it JUST act up in the rain...while driving? Standing still all night in the pouring rain was fine.
evan1395 is offline
post #11 of 72 Old 02-27-2014, 03:51 PM
HighLonesome
Water getting thrown somewhere.
There is a distribution wire to the PDC from battery. That is something to look at. But I think the starter has it's own power wire, so that's why I think it might be a ground.
post #12 of 72 Old 02-27-2014, 04:02 PM Thread Starter
evan1395
Now what is a PDC?
evan1395 is offline
post #13 of 72 Old 02-27-2014, 04:32 PM
Gearhead31
PDC = power distribution center. The long black box right behind your battery. Holds fuses and relays for alarm, ECM, BCM, headlights, horn, etc. Pop the cover off it and you should see about 25 fuses/relays in there.
1995 ZJ ltd, 4.0 i6, *cough stock cough* 253,xxx and still pumping strong
1998 Chevy Cheyenne K1500, 5.7L Vortec, mostly stock
*In peace, sons bury their fathers. In war, fathers bury their sons. - Herodotus
Originally Posted by JasonStebbins
We can call it the Whoosh King Catalog System. :D
Gearhead31 is offline
post #14 of 72 Old 02-27-2014, 04:40 PM Thread Starter
evan1395
I pulled every single one of those last time this happened. I thought maybe it got wet in there. This time I checked and it is bone dry. THAT relay center along with the mini fuse panel inside the cab were clicking like crazy when the battery is connected. The PDC had stopped, but the interior fuse panel area did not. It clicks repeatedly when the battery is hooked up and the key is in the OFF position. The only way to get it to stop is to disconnect the battery, or turn.the key in the ON position. Even when the key is ON, there is ZERO electrical function anywhere.
evan1395 is offline
post #15 of 72 Old 02-27-2014, 07:19 PM Thread Starter
evan1395
Anyone got anyother ideas/input?
evan1395 is offline
